As above really Does anyone know what model gearbox was fitted to the BOA Engined cars? Iām guessing its an A4LD, i think the C3 was an essex unit? Tia
mk2cossie
Club RR Member Number: 77
BOA engined Granada Scorpio had an A4LDe fitted. Easiest way to find out if thats what you are looking at is it will have the electronic speed sensor on the left of the tailshaft housing, AND a speedo cable drive on the right hand side further forward Also have electronic kickdown on the left, and a vacuum solenoid on the same side as the speedo cable (The little e is important, as later boxes are A4LDE and have more electronics to them)
Thanks for that mk2cossie, just got to find someone who needs it now š
Just a thought, it looks like we might have a BOB coming in too, is that the same box?š¤
mk2cossie
Just a thought, it looks like we might have a BOB coming in too, is that the same box?š¤ Casing is kind of. The BOB has full electronic control of gears, and no speedo cable drive. That should be A4LDE attached to it
