Jun 26, 2021 12:25:53 GMT
Jun 26, 2021 13:07:33 GMT
You work really is brilliant and educational, Can't wait to see the finished article, Nigel
gazzam
Jun 26, 2021 20:22:23 GMT
Pleased you had a good day. Now if that TIG behaves itself…
Jun 26, 2021 20:54:56 GMT
I'm certain this deserves an 11/10. Very educational and entertaining.
Jun 27, 2021 15:32:32 GMT
A change of scene today after the euphoria of yesterday; a bit of hammer forming. I need to add a curve to the door frame mirroring the shape of the roof so to start with I played around with a length of welding wire to give the desired curve. This was tacked in place and the curve transferred onto a piece of thin ply. Two pieces of 12mm ply were cut out using as a pattern the curve on the thin piece. These two pieces are the basis of the hammerform which I'm using to tap over the flange. A left and right hand piece will be made for each side and welded to form a U section with square corners. The final internal width will equal the diameter of the round tube so that they can be slid upwards and welded in place.
Jun 27, 2021 19:00:45 GMT
I'm confused John , isn't that heavy tube above the door going to follow that curve too ?
Jun 28, 2021 16:32:17 GMT
I'm confused John , isn't that heavy tube above the door going to follow that curve too ? This is a classic example of what happens when there has been no planning and no drawings. As I have mentioned before I'm useless at drawing so the shape has evolved over time. It wasn't until horrido came up with the artist's impression that I realised the door frame needed to follow the curve of the roof. The 33.7mm diameter pipe frame is unfortunately cast in stone and cannot be bent. At one time I was considering sculpting it which is probably where the confusion has come from but I felt that in doing this a lot of strength would be lost. So that's why I came up with this solution which loses a bit of headroom when getting into the car but retains the integrity of the cage. So following on from yesterday I cut a length of 1mm flat 33.7(ish)mm wide and tacked it to one of the hammer forms I then offered it up and realised that I hadn't taken into account the fact that the screen frame splays out from the roof to the scuttle. Fortunately I hadn't welded the other side at this point so it was easy enough to cut out a cheese wedge and put in the bend. The second piece was then added and tacked in place. It's difficult to gauge the full impact of putting in this curve without having the bodywork in place but I'm hoping it will have the desired effect. At the same time I do have doubts because of the vertical drop from the roof to the door aperture where a subtle curve is needed so I am bracing myself in case it has to be rethought.
Jun 28, 2021 16:57:41 GMT
Ah i see , gotcha . i wonder if the red line addition would work ?
Jun 28, 2021 17:22:39 GMT
Ah i see , gotcha . i wonder if the red line addition would work ? I really appreciate your thoughts, thank you. I think it's marvellous that folk are sufficiently interested in this project to get involved themselves and offer their thoughts and suggestions. I've just covered the area with paper and I can see at a glance what's wrong. Take a look at these pics. The last one says it all. Rather than being vertical the piece should angle out and follow the line of the B post. ie angled in towards the roof or out towards the floor. The only bit that's correct is the section on the windscreen frame. It should be possible to form the aluminium so that it has a curve rather than following the a crease of the steel and fitting flat against it. So, we're looking at removing it to make way for the MK2. Fortunately I haven't made the second side so it could be worse.
Jun 28, 2021 18:07:50 GMT
i have to say i am very nervous making any suggestions to someone who is so far ahead of me when it comes to metal manipulation , and offer any suggestions to be catalogued under the heading of "this is probably nonsense but may be useful" in the workshop of the mind.
regards robert
Jun 28, 2021 18:34:13 GMT
I can't see a way to transition the curve of the roof skin around that straight line above the door. Touring seem to have formed the window frames without any additional internal roof support. Wow, there's really nothing to these is there!
Last Edit: Jun 28, 2021 19:03:33 GMT by horrido
Jun 28, 2021 19:16:03 GMT
i have to say i am very nervous making any suggestions to someone who is so far ahead of me when it comes to metal manipulation , and offer any suggestions to be catalogued under the heading of "this is probably nonsense but may be useful" in the workshop of the mind. regards robert The problem that I have is that I am working on my own, close to the project and can't always see the best way forward, but somebody who is not so involved is able to stand back and see the big picture and possibly spot a better solution. So please keep the suggestions coming. I may not always take them up but it gets me thinking.
Jun 28, 2021 20:08:53 GMT
I can't see a way to transition the curve of the roof skin around that straight line above the door. Touring seem to have formed the window frames without any additional internal roof support. Wow, there's really nothing to these is there! Now that really is Superleggera. I'm sure because Touring designed it then there is no problem with rigidity but if I'd done it I would be really concerned partly about not having put sufficient strength in the structure as a firm underpinning of the aluminium skin but mainly from a safety aspect and how much protection it would offer in the event of a crash. If you are right about there not being a curve from the roof to the window frame this could cause some serious thinking about how to progress. The shape you have drawn is really beautiful and I'm striving to copy it as well as I can. I said earlier, the two main tubes are set in stone because they are fundamental to the structure of the cage and cannot easily be altered but you have opened my mind to the possibility of cutting them out altogether. I'd be prepared to sacrifice a little rigidity and strength if it meant that it would contribute to the stunning creation that you have realised and that I desperately want to produce. Nick perhaps we can talk structural engineering when you come over
Jun 28, 2021 22:14:56 GMT
I'm not quite sure exactly the cage problem, but I think you mean the flat pieces of cage over the doors? If this is the case then just chop them out and either bend some new tube or get someone to bend some and then weld in a curved piece instead? It's only metal after all
I'm not quite sure exactly the cage problem, but I think you mean the flat pieces of cage over the doors? If this is the case then just chop them out and either bend some new tube or get someone to bend some and then weld in a curved piece instead? It's only metal after all When I first read your post I thought NO, but having given it more thought, you are absolutely right. Those two rails have to be bent to follow the curve of the roof and anything else is just a fudge and would ruin the shape. And it's something I would always regret not doing properly when it was too late to change it. A good call. Thank you blackpopracing.
I know little about metalwork, but maybe make the whole side window shape, including the rear quarter window in one go, just to avoid any sort of disjoint in the shape? The rear quarter windows need some curve adding too. Would it be worth getting some plywood and cutting a template of the side windows, to get the shape dialled in?
Last Edit: Jun 29, 2021 12:47:58 GMT by horrido
I'm not quite sure exactly the cage problem, but I think you mean the flat pieces of cage over the doors? If this is the case then just chop them out and either bend some new tube or get someone to bend some and then weld in a curved piece instead? It's only metal after all When I first read your post I thought NO, but having given it more thought, you are absolutely right. Those two rails have to be bent to follow the curve of the roof and anything else is just a fudge and would ruin the shape. And it's something I would always regret not doing properly when it was too late to change it. A good call. Thank you blackpopracing. That is what i was getting at with the red line .
Jun 29, 2021 10:47:20 GMT
I think you need to drop the window line down a bit and imagine the A pillar sweeping along a 3D curve all the way to the boot area. These kind of curves have to marked out in a 3/4 view, it's really hard to get nice pure sweeps in elevations. The top of the B pillar seems to be a bit high from this angle [where I wrote lump]
Jun 29, 2021 10:48:31 GMT
could you do a short video of a fly past of this area, it's hard to understand the form fully from these pics.
Jun 29, 2021 10:55:00 GMT
Just wondering what you are doing about arches?
