Sept 9, 2023 17:33:39 GMT
Yup, thought so. It's too short on the wheel end. Don't quite know how I managed that.
I'll splice a section in to fix it.
Edit: Went out and looked at how I had managed to screw that up: I managed to not use the same datum. Well, ain't that smart of me. Oops.
I can insert a slice of metal and bring it to where it needs to be. Just sucks as that's extra welds I didn't want to do.
Last Edit: Sept 9, 2023 18:05:38 GMT by PhilA
Sept 11, 2023 1:09:29 GMT
Cut the panel off, and hammered it to a better profile. Bottom corner was too sharp and the arch return was too straight. Added an infill section on the arch end and brought the back end up a touch. Now, per measurements that's correct. Ignoring the hole which I'll fill in, that looks alright in profile and at quarters. Phil
Sept 11, 2023 7:31:20 GMT
looking better and better , i cant remember phil, is the boot floor and rear quarters the end of the rust , then you can get on with the cheap scrapyard turbo conversion ?
Sept 11, 2023 12:14:52 GMT
*ahem* Twin turbo my good man!
Sept 11, 2023 16:03:00 GMT
Nah, not adding extra power to this engine.
The answer there is add capacity.
Sept 11, 2023 18:26:28 GMT
Mail arrived in. That makes me happy. Phil
Sept 12, 2023 0:09:57 GMT
Welded up. Managed to create a springy warp, nothing that cannot be fixed with a bit of bodywork. Phil
Sept 12, 2023 20:21:54 GMT
Space ship! Unfortunately someone (bodyshop guy) decided not to pull the lower front trim off, instead smash it with a DA sander fitted with 12½ grit paper then paint over it. I pulled the corner piece off, cleaned the paint off and then carefully smoothed it down with a diamond file, varying grades of wet-n-dry and metal polish. Unfortunately the anodized finish is long gone, so I'll have to work out how to protect the bare aluminum. Phil
Last Edit: Sept 12, 2023 20:22:30 GMT by PhilA
Sept 13, 2023 12:04:23 GMT
If you use a mopping wheel then the polishing wax will keep the ally good. If not then a good coat of car wax regularly will keep it shiny.
Sept 13, 2023 18:31:12 GMT
If you use a mopping wheel then the polishing wax will keep the ally good. If not then a good coat of car wax regularly will keep it shiny. Also, aluminum apparently nickel plates readily. I might experiment.
Sept 13, 2023 22:34:21 GMT
This carburetor is a turd and is due to be launched into low Earth orbit soon
Sept 14, 2023 18:00:22 GMT
I've decided to not let it defeat me.
Pulled the thing apart, found my can of Chem Dip and the first parts of the carb are currently stewing.
Sept 15, 2023 15:00:30 GMT
I've decided to not let it defeat me. Pulled the thing apart, found my can of Chem Dip and the first parts of the carb are currently stewing. Cleaned it all up. Put all the bits back on. Does it work right? Does it hell
Sept 15, 2023 15:26:11 GMT
Found the problem.
Would have found it eventually.
Car runs now
Sept 15, 2023 16:17:14 GMT
You're leaving us hanging! What was it ?
Sept 15, 2023 17:01:14 GMT
I had cleaned it out but in the interim a couple flies made nests in the vent tubes.
Sept 15, 2023 21:31:44 GMT
Started getting things adjusted. Carburetor has two sets of levels, two sets of everything apart from idle circuit stuff. Shut it down because it was not quite right and was getting a bit hot. Progress is progress. Phil
Sept 26, 2023 3:56:29 GMT
Had taken a few steps back from the car, think that was a good idea. I was beginning to burn myself out and make poor judgements. Five minutes tonight and I popped the worst of the kink out of the lower quarter, size 8 and a long prybar. It's even vaguely approaching the correct profile now. Phil
Last Edit: Sept 26, 2023 3:57:24 GMT by PhilA
Sept 26, 2023 14:15:31 GMT
Forgot how much panel beating I'd done. Same-angle comparison from when I had just removed the filler to now.
Sept 26, 2023 14:28:09 GMT
That's got to make you feel like you've accomplished something! Looking good!
