jgtr
Apr 12, 2021 17:13:33 GMT
Hi all, I’ve got to leave my VW van on a mate’s drive while we’re having building work done.
What are the options regarding steering locks, wheel locks etc? Can anyone recommend something?
Cheers
Jay
gte86
Apr 12, 2021 18:45:38 GMT
Remove the steering wheel if it's not got an airbag and stick in on a pair of axle stands. Make it look like it's not worth the effort to move it.
jgtr
Apr 12, 2021 19:23:28 GMT
Remove the steering wheel if it's not got an airbag and stick in on a pair of axle stands. Make it look like it's not worth the effort to move it. Will still be using it so not really ideal, was looking for something that can easily be removed and refitted
Apr 12, 2021 19:54:09 GMT
Nothing will stop the determined but if you can delay that may put them off. Something visible like a steering wheel lock or a wheel clamp type and remove an easily accessed relay, fuel pump or similar. Traka type kit is pricey but they can usually recover it afterwards if the TGB's haven't found it with cheap Chinese software and a laptop!
shin2chin
Apr 13, 2021 19:13:10 GMT
Second for Disclock, I've got one for each of my cars. Always park at full lock before putting it on too. If someone really wants it they'll just hiab it tho but it's a diterant
Apr 13, 2021 20:31:05 GMT
Disklok Tracker Wheel clamp Security post if parked in a driveway Hidden kill switch SelectaDNA marking kit
Apr 13, 2021 20:31:47 GMT
Discloks are good. You need a grinder if you lose your key. Not cheap though. Not cheap but still the best on the market
jgtr
Apr 13, 2021 20:57:57 GMT
Cheers all, went for a Stoplock Pro. Had similar reviews to the disc lock
Security - steering locks etcballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Apr 13, 2021 21:21:37 GMT
Discloks are good. You need a grinder if you lose your key. Not cheap though. I forgot about the wheel clamp I had for my imprezza
jmsheahan
Club RR Member Number: 121
Security - steering locks etcjmsheahan
@jmsheahan
Club Retro Rides Member 121
Anyone ever used one of the pedal Safe T bar locks? That combined with a disklock seems a reasonable combo. Not cheap though!
bricol
Apr 19, 2021 15:40:35 GMT
I've used a Bullock pedal lock on my integrale for the last 20 plus years. 50 quid from a stand they had at the Motor Show one year. Still works perfectly every time.
Locks the brake and clutch pedal together, and holds both off the floor.
