Alpina99
Apr 14, 2021 15:17:17 GMT
Hi Gazzam, I saw the first entry of this thread and my first thought, (obviously other than beautiful car,) was this will probably be a "cheque book" restoration so didn't really look in again, How wrong I was, (lesson for future,) this is brilliant, Your work ethic and skill levels are amazing, your abilities are to be admired, Definitely looking forward to seeing future updates, Nigel
I almost bookmarked this just on the strength of the thread title, but not knowing what to expect.
Reading through, bloody incredible work!
I lift my hat to the commitment and craftmanship (and afford to learn that craftmanship) you're putting into this. After finding all this bodge under the paint I would have probably ran away screaming like a maniac and hiding in a fridge in Minnesota for the rest of my life.
Really looking forward to see the progress on this.
Love this. You're a wizard mate.
11/10
This defines the Built not Bought ethos.
flyingphil
Excellent work and thank you for sharing it with us....why was I not surprised to see that you are in Australia...."Can do" attitude is characteristic!
maf260
Wow! Great attitude, even better results.
gazzam
Apr 15, 2021 12:20:52 GMT
Geez, they only make welding helmets in one size, you guys are going to have to tone down the compliments. Still its great to have praise from people who know what they’re talking about. It’s very encouraging. Thank you all. Anyway back to the project. Now that the tonneau was back in place the channels for the boot seal could be put in. These were were made by folding strips into a u shape and then stretching the edge to put a curve into it. The tonneau was then drilled and channels rosette welded in... Next the boot floor and the shelf above the spare tyre were fabricated. I reused the spare tyre holding bolt and a stiffener, just to keep some original metal. Other than those, I’ve had to remake everything rearward of the leading edge of the bootlid. Then the rear section could be taken off the chassis. And mounted on a rotisserie so I could get better access to the battery boxes. These had been replaced before and it must be said that welding them in from underneath was a hell of an achievement. I’m surprised the welds weren’t even worse. Made up a new pair of boxes and welded them in I like this little detail on the corners of the battery boxes: and that was pretty much the end of the rear section. There were lots of other small and not so small bits to fix, but I haven’t got photos of much of it. Things like the bumper mounts, rust areas on the top of the b pillars etc. Too much to list. That’s all for now. Any comments or questions welcome. Cheers Garry
Last Edit: May 7, 2021 1:02:10 GMT by gazzam
1952 Jaguar XK120 restoration glenanderson
@glenanderson
Club Retro Rides Member 64
Apr 15, 2021 12:51:48 GMT
Nice work. Bookmarked. 👍👍👍
Apr 15, 2021 13:07:32 GMT
Amazing panel making and tool fab skills.
Apr 15, 2021 14:37:28 GMT
Wow, fantastic work!
teaboy
Make tea, not war.
Apr 15, 2021 15:37:18 GMT
Half tidy job you're doing there, very impressive work.
Rob M
Club RR Member Number: 41
Apr 15, 2021 15:50:41 GMT
Simply incredible skills there. You are an absolute craftsman, that car is going to be just amazing when it is finished! I shall continue to watch with open jawed.
Last Edit: Apr 15, 2021 15:51:59 GMT by Rob M
rob
Apr 15, 2021 21:53:51 GMT
Nice work! I restored the frame on one of the early ones a few years ago (the doors and rear were entirely ash frame with aluminium skin). I had to replace about 80% of it, someone had been there before me with plywood so it was a bit of a challenge working out exactly how it was supposed to be. The laminating was a pig of a job and there was a few trial runs but really rewarding once I got the hang of it. How thin did you get your strips and what wood did you use?
Last Edit: Apr 15, 2021 21:55:33 GMT by rob
gazzam
Wow Rob, there’s some nice work in that. I see that the boot latches go through the lid frame.Which is how I thought mine was but I was told they are meant to go through small steel retainers screwed to the frame. If that makes sense. My car is an early one so through the frame may have carried over from the alloy cars. I cut my strips at about 1/8 inch out of an old wardrobe (probably period!) I think it is Tasmanian oak. Garry
Love this, this is the kind of thing we like on retro rides. BOOKMARKED
rob
I don't own it but the manual has holes for the catch to go through the frame. However with coach built cars a lot can depend on the mood of the person who was making them on the day.
gazzam
Apr 16, 2021 15:38:04 GMT
Again, thanks for the very kind words. I found a photo of one of the tasks that I mentioned at the end of the last post. I needed to make a dozen or more captive nuts. Difficult little buggers to get right so they look factory. So I made a little press tool and it worked pretty well. Anyway it was time to start on the front of the body. Lifted it off: A large go kart was left Then mounted the body onto the rotisserie so I could sandblast it Didn't waste time blasting this bit, I knew it wasn’t staying Made a replacement piece as this looked like a good place to start Then cut the eyesore bit away I must have taken a brave pill that day as I decided to take the left hand (good) guard off Not much left now. I was a bit shell shocked - I’ve never been this far into a car before. The rot you can see in this photo was what ultimately made me remove the guard - pretty much impossible to fix properly with the guard in place. Repair tacked in place After the same piece was done on the right side, lifted the cowl section of the rotisserie so I could work on it on the bench. Leaving only the sills on the rotisserie. Ultimately all this was scrap. That's all for now. Comments and queries welcome. Cheers Garry
Last Edit: May 7, 2021 1:06:37 GMT by gazzam
Apr 16, 2021 17:45:33 GMT
This is absolutely brilliant. Serious skills and attention being lavished on a simply beautiful car. Bookmarked and awaiting further installments 🙂
Thanks so much for sharing this.
John
