Yep. You will have to dip them. There is no gel type stripper that would be man enough the DCM just evaporates off too quickly.
Search out a company called Blast Wash UK. They do an alloy wheel stripper. It's mostly Dichloromethane with a bit a Hydrofloric acid in it so it's the proper stuff and requires respect when in use (full face mask, arm length gloves etc.) Works great tho!
It's about 80quid for 25L.
