I'm updating and extending the existing cable loom of my 65' Volvo Duett (adding overdrive, rear fog light, relay for headlamp main supply etc.). The original sleeves are made of a rubber/plastic material that was slightly shirked around the bundles. So impossible to replace or add cables.
Anybody an idea of a good alternative prefarable splitable so you can sleeve also existing bundles with connectors on the ends. I recon the ribble plastic ones as too modern and the self bonding tape is also not my favourite.
Thanks!
Thom
Thanks!
Thom
