Super rare Set of 4 s84fm fiesta and escort 1.6d conrods as required when building a 2.2 pinto
These rods when used with a offset ground crank and a 93mm bore and piston set of either accrelite sc302/93 or 2.8 pistons will give you a 2.2 pinto used rods in good used condituin see pics what you see is what you get
I Can help with getting bearings as well if needed
Would like £185 posted
