I have a Fiat 132 2L twin cam engine and gearbox for sale. The engine has been rebuilt with the following parts:
Full gasket set
New oil pump
New cam belt
New cam belt tensioner
New core plugs
New piston rings
The bores have been deglazed/ honed.
The original sump has been refitted. It’s showing signs of use but is still functional. A new sump which would need modifying to suit the engine is included.
An alternator is required and the starter motor needs a new solenoid, these are readily available.
The clutch plate is in good condition.
The engine has a homemade inlet manifold, proper manifolds are readily available.
The engine has the original distributor cap, points and rotor fitted. I’ve not included plug leads so that you can choose your ignition setup and routing, new spark plugs are fitted.
The engine has an interface plate for remote oil filter fitting.
Gearbox comes with a prop shaft.
Lots of photos taken during the engine rebuild.
Price £850.00.
Buyer collects.
Payment by paypal or bank transfer.
I have an engine hoist to lift the engine on collection.
Full gasket set
New oil pump
New cam belt
New core plugs
New piston rings
Price £850.00.
Buyer collects.
