Fitting a 5 speed to my MGB later this year, seems like a good opportunity to upgrade the rear axle, ive got a complete spare axle with 3.07 gears which are a good match to the gearbox i plan to fit, was going to simply fit this thought it might be time for an LSD, and the tyres are catching the rear arches on bigger bumps, so...
Plan is to source a wire wheel axle which is narrower, fit a set of 3.07 gears and an LSD, i wouldn't know where to start with something like this, I've spoken to a few local gearbox/axle companies but no one is interested in anything other standard rebuilds, can anyone recommend a company in central Scotland who could help with this, failing that specialist down south who could supply or modify an axle with this spec?
Going to sell the other axle on, by the time i get it narrowed, half shafts, then fit an LSD and setup id be better off starting with another casing.
