jgtr
Hi all, I’m refitting some rubber weather strips, I need to remove the foam double sided tape, any tips on the best way? The rubber is flexible which makes it awkward - caramel wheel maybe?
Any tips to remove foam tapefr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
I tend to use white spirits, a microfibre cloth I'm willing to throw away afterwards and my thumb.
Although it takes a few days for the blisters to go off my thumb!
Jan 29, 2021 11:14:24 GMT
In work I use Glue remover & then isopropranol to wipe the glue off.
jgtr
Jan 29, 2021 18:44:52 GMT
I tend to use white spirits, a microfibre cloth I'm willing to throw away afterwards and my thumb. Although it takes a few days for the blisters to go off my thumb! That was my plan, I was hoping someone would have an easier option😝 skin grows back eventually.
Last Edit: Jan 29, 2021 18:45:43 GMT by jgtr
Jan 29, 2021 20:35:17 GMT
Try acetone on it, you may be lucky and it starts to dissolve.
squonk
Jan 30, 2021 19:20:49 GMT
jgtr
Jan 30, 2021 21:58:33 GMT
Had a little go today, I think the issue is getting the foam off first which is a manual job using my thumbs to peel/roll it off😤 once the foam is off the glue comes off with a bit of standard thinners. Took me about 20 mins to do 15cm.....got a good 3m odd to do😫😫😫
I did Google new ones, over £100 each and I have 3🙄
Last Edit: Jan 30, 2021 21:59:52 GMT by jgtr
