Jan 28, 2021 16:43:51 GMT
So......
Tried these today, after refitting the side repeater as it was out in anticipation of the new fittings getting delivered.
HOWEVER.......
THIS:
Advice, tips, laughter, mocking, all welcome.
But tell me how to slow them down.
Thanks.
logicaluk
Jan 28, 2021 17:21:30 GMT
It needs either an led indicator resistor in line or an led flasher module grizz Dan
Jan 28, 2021 17:56:35 GMT
It needs either an led indicator resistor in line or an led flasher module grizz Dan So for a guy who concentrates when he changes the torch batteries..... Which is the easier Dan?
Last Edit: Jan 28, 2021 17:56:50 GMT by grizz
Jan 28, 2021 18:23:07 GMT
Flasher module is easier if Cf13 or Cf14 should be plug and play. resistors will need some cutting of wires and soldering.
Jan 28, 2021 18:59:49 GMT
Flasher module is easier if Cf13 or Cf14 should be plug and play. resistors will need some cutting of wires and soldering. Just need to find the thing
logicaluk
Jan 28, 2021 22:03:48 GMT
If you can find the flasher relay pull it out take a pic of the pins, then have a look on eBay for an led flesher relay with pins that look the same as yours grizz, sorry forgot you had to use your tongue to concentrate whilst changing torch batteries. The flasher module is behind the glove box, it's held in place by a plastic strap. Dan
Last Edit: Jan 28, 2021 22:12:11 GMT by logicaluk
sonus
Jan 28, 2021 22:11:55 GMT
