Jan 23, 2021 11:21:54 GMT
Good morning all, I've been tempted by one of these, advertised locally and wondered if any of you had any experience of them? It's an auto in Carat spec,with a recent clean MOT and looks quite straight. It'll be a replacement for my 18 year old Multipla, so I'm quite used to the odd foible! Have an inspirational pic ( not the one I'm looking at sadly).
Jan 23, 2021 11:31:10 GMT
No experience of them but I've had a Bora VR6 for a year now and the engine is faultless, the chains are banded about as being a problem but it's not.
Jan 23, 2021 18:49:14 GMT
I missed out on a V6
I was gutted, I think they are the one to have, bit of vrooom to your van.
I still have the Benz 17” wheels and tyres plus the lowering springs left from mine to sell.
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
2001 VW Sharan 2.8 V6fulvia1436
@fulvia1436
Club Retro Rides Member 63
Jan 24, 2021 10:26:11 GMT
I ran a 5spd VR6 Sharan for a couple years. Worked it very hard carting the band and gear around the Country. Fast, comfortable, reliable, juicy! TBH, the Multipla JTD 120 that followed it, is as good, as fast (slightly mod'd), as spacious, and much better on fuel
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
Jan 24, 2021 10:55:02 GMT
I ran a 5spd VR6 Sharan for a couple years. Worked it very hard carting the band and gear around the Country. Fast, comfortable, reliable, juicy! TBH, the Multipla JTD 120 that followed it, is as good, as fast (slightly mod'd), as spacious, and much better on fuel Funnily enough, I'm a drummer,hence the need for a vehicle such as these. What was the car like to service,as I'd imagine that lump is a tight squeeze in the front. Saying that,just changing the alternator on my Multipla involved the removal of quite a few things to get to it. Are there any unobtainium bits that anyone knows about?
fulvia1436
@fulvia1436
Jan 24, 2021 11:16:33 GMT
I ran a 5spd VR6 Sharan for a couple years. Worked it very hard carting the band and gear around the Country. Fast, comfortable, reliable, juicy! TBH, the Multipla JTD 120 that followed it, is as good, as fast (slightly mod'd), as spacious, and much better on fuel Funnily enough, I'm a drummer,hence the need for a vehicle such as these. What was the car like to service,as I'd imagine that lump is a tight squeeze in the front. Saying that,just changing the alternator on my Multipla involved the removal of quite a few things to get to it. Are there any unobtainium bits that anyone knows about? One drummer to another, I've found the Multipla is better for the job. Admittedly, I didn't get involved in much servicing of the VW, but I do know that the Fiat is easier and cheaper to do virtually anything under the bonnet. New alternator cost me about £300 fitted. Recon VW alternator cost about the same. Timing belt in the Fiat is much easier and cheaper than VW timing chain, but doesn't last as long, of course. Can't think of particular unobtainiums, except most garages are more afraid of the Fiat than the VW ~ for no good reason! Fiat parts are cheaper. Last thing, the Multipla drives much more like a car than the heavier Sharan :-)
Jan 24, 2021 11:36:00 GMT
Funnily enough, I'm a drummer,hence the need for a vehicle such as these. What was the car like to service,as I'd imagine that lump is a tight squeeze in the front. Saying that,just changing the alternator on my Multipla involved the removal of quite a few things to get to it. Are there any unobtainium bits that anyone knows about? One drummer to another, I've found the Multipla is better for the job. Admittedly, I didn't get involved in much servicing of the VW, but I do know that the Fiat is easier and cheaper to do virtually anything under the bonnet. New alternator cost me about £300 fitted. Recon VW alternator cost about the same. Timing belt in the Fiat is much easier and cheaper than VW timing chain, but doesn't last as long, of course. Can't think of particular unobtainiums, except most garages are more afraid of the Fiat than the VW ~ for no good reason! Fiat parts are cheaper. Last thing, the Multipla drives much more like a car than the heavier Sharan :-) I do like my Fiat but it's nearing the end of its life with me as it'll need a clutch/dmf/cambelt soon as well as the laquer is starting to fail on most panels. I'm also a fan of the so called really ugly ones (like mine) so may well hold out for one in better shape than mine.
Jan 24, 2021 11:40:21 GMT
Saying that, the paint looks ok when it's covered in snow like it is today!
Jan 24, 2021 12:28:50 GMT
Chains don't fail on the VR6 engine, it's the tensioners which are fairly simple to fit and real easy to check for issues (block 208 and 209 in vagcom), engine position sensors are expensive but other than that it's pretty bombproof - not many engines can take a turbo and double their bhp without and internal changes.
Jan 24, 2021 12:55:55 GMT
The one near me has done 85k and the owner tells me has a small amount of history,as well as only one key. The MOT history shows that maintenance appears to have been kept on top of,with some minor welding being required a few years ago. Being a Carat model it looks well spec'd with a good looking leather interior and the owner is confident everything works as it should. I'd need to fit a towbar and would look at changing the auto gearbox oil as part of a service. Grizz's wheels and springs are also a very tempting thought as well !
Last Edit: Jan 24, 2021 13:06:15 GMT by tubthumper
Jan 24, 2021 12:56:52 GMT
Still snowing here too.
Jan 24, 2021 17:41:48 GMT
Those auto boxes are JATCO so make sure its working ok. Of that vintage look for corrosion that may have got through an MOT but may become an issue. Front of sills and rear subframe mount area are usual suspects.
fulvia1436
@fulvia1436
Jan 24, 2021 17:52:03 GMT
Remember it's front wheel drive if you're planning to tow anything heavy
Jan 24, 2021 18:59:58 GMT
Remember it's front wheel drive if you're planning to tow anything heavy Cheers. I'd only be towing what my Multipla currently does,a small van trailer,for gigs that require all of my kit. There's 3 cased snares needing to find a space in there too!
Last Edit: Jan 24, 2021 19:01:08 GMT by tubthumper
fulvia1436
@fulvia1436
Jan 24, 2021 19:05:33 GMT
I always managed to get the whole 6 pce kit, all the bass gear, and a Fender Rhodes, into both the Sharan and the Multi, plus the 3 of us!
Jan 24, 2021 19:29:24 GMT
Those auto boxes are JATCO so make sure its working ok. I thought they were the STA/Renault ones in the earlier ones?
Jan 24, 2021 19:47:26 GMT
I always managed to get the whole 6 pce kit, all the bass gear, and a Fender Rhodes, into both the Sharan and the Multi, plus the 3 of us! A trailer takes away the need to empty the car after the gig🤘
fulvia1436
@fulvia1436
Jan 28, 2021 19:48:07 GMT
I always managed to get the whole 6 pce kit, all the bass gear, and a Fender Rhodes, into both the Sharan and the Multi, plus the 3 of us! A trailer takes away the need to empty the car after the gig🤘 just so easy to lose the whole lot in one go! I always unload the car when I get home. Know too many that didn't, then regretted it!
Jan 29, 2021 10:51:54 GMT
A trailer takes away the need to empty the car after the gig🤘 just so easy to lose the whole lot in one go! I always unload the car when I get home. Know too many that didn't, then regretted it! A very valid point and I do keep my snares and cymbals in the house,with the trailer living in the garage. After speaking to a few people about the Sharan I've been warned about the auto box and that they can be troublesome,to the point of rendering the car an uneconomical fix. Looks like I'll be keeping an eye out for another Multipla with better bodywork than mine.
Jan 29, 2021 10:53:20 GMT
