2000 V6 Ford Cougar comebackChasR
@chasr
Club Retro Rides Member 170
Feb 14, 2021 15:14:22 GMT
A great project this! I'm hoping my ST220 won't be quite as involved as this, but we will wait and see! Good to see another car being rescued .
Feb 27, 2021 19:36:25 GMT
General sill (right side) restructuring is well advanced, but it always helps to mix it up with some cosmetic browsing, yes? With luck I found a bargain set of 18" in 4x108 on FB Marketplace which ought to suit the car. Not much wrong with these. They should come up well with a home refurb. ETA, when I arrived the seller was sitting at a table in his shed, lightly hammering something. Watching him were 2 young lads, I assume grandsons, the eldest about 12 years old, both wearing overalls. In the shed was an A40, and old XJ, an Astra convertible, a Mini shell on a spit, a couple of other random old school motors. School is out, but old school was in. How awesome is it those 2 lads are getting a schooling experience like no other?
Mar 18, 2021 17:20:17 GMT
Time for an update on progress... I finished repairs to the right sill a couple of weeks ago. The front of the sill was as bad as the left side. Ignore the rusty wing which will be dealt with later. The rear of the sill looked easy with just a small hole. It turned into a larger repair thanks to a big bit of foam inside the sill to retain the moisture. Cosmetics and paint will come later for these repairs. The rear suspension is all in with brakes complete on the left side. Brakes on the right are still in progress. There are new splash guards as the old ones were rotten. Also new ABS sensors as the old ones wouldn't come out intact. The flying leads off the sensors disappear into the car which meant removing the rear seats to connect them. Making a start to the front, bushes and joints all look sound and it doesn't look like anyone has been in here since the car left the factory. It's good news as the lower wishbones are unique to the Cougar, different from the Mk2 Mondeo the rest of the car is based on. i.e. hard to find and expensive. Dust covers and CV boots are in good shape, but the ABS ring on the outer CV joint is broken. I've had to take the suspension apart to gain access for a replacement. Luckily it's come apart without damaging anything. I've descaled all as best I can without complete disassembly and the Kurust is doing its thing this evening.
Mar 28, 2021 18:10:09 GMT
The front suspension got built today following the fitting of a new ABS reluctor ring. That's looking a lot tidier. The front is proving simpler than the rear. The wishbone bushes are a bit untidy, but I don't detect enough movement to justify changing them unless the MoT man tells me otherwise in a few months. The struts still carry the Ford part number labels. It all seems original. For an idea of the starting point, this is the right side. I've stripped it to the same level as the other side, again to replace the bloated ABS reluctor ring. A word on cleaning and paint. On recent projects I've usually sent parts for shot-blasting then primed and painted with some decent quality oil-based enamel paint. As this is a cheap project (and the shot-blaster is probably out of bounds), I've descaled with cup-brushes on angle-grinder, profiler belt and grinding stones on a dremel. Obviously this doesn't clean up as well as shot-blasting. A friend uses Kurust to treat the rust so I've been trying that for the first time on this car. Hopefully it holds back the rust for longer. For paint, I like POR-15 but it's a bit excessive for this car. I gave up on Hammerite/Smoothrite a long time ago. I've gone with No Nonsense Trade Smooth Metal Paint from Screwfix as I get discount It goes on OK, but doesn't feel like it offers much protection other than colouring parts black. Oddly, when I check the parts the day after, they have pin-pricks of orange! Rust spots from the curing of water-based paint perhaps? I've never seen this before. I've ended up painting Waxoyl onto the parts after assembly. That should keep things fresh.
Apr 16, 2021 16:14:22 GMT
The front brake calipers have been cleaned, painted and refitted, so that seems to be the dirty work and the suspension/brakes done. The discs and pads don't look like they were on the car long before it was laid up. Reminding myself this is a cheap car challenge, I'm running with them until the MOT man tells me otherwise. Bleeding of brakes is still to be done, plus engine service and change of belts while access is good. However, a damn good wash is in order which means getting the car out of the garage, which means buying tyres, which means refurbishing wheels. I've spent a couple of days rubbing down and filling imperfections, then knocked up a stand for access to all of the wheel while painting. The base is off a shop display stand from sister-in-law's old wool shop Well the wheels are all straight but this repair to one wheel is visible now the old tyres have been removed. I don't know much about repairs to alloys, but this looks a sound enough repair?? Any advice??? It's a heavy big alloy so I don't understand how it got damaged in this area. With a trip to Halfords this morning for aerosols, all 4 wheels are primered this afternoon and set aside for a couple of days. There are a couple of small imperfections to sort out before the silver paint.
Apr 19, 2021 18:37:23 GMT
I made some small filler repairs, then on with the Halfords own-brand wheel and wheel trim paint, then Simoniz acrylic lacquer. The preparation is a pain but I enjoy the process of aerosol spraying wheels.
Apr 19, 2021 19:10:48 GMT
Any advice??? It's a heavy big alloy so I don't understand how it got damaged in this area. With a trip to Halfords this morning for aerosols, all 4 wheels are primered this afternoon and set aside for a couple of days. There are a couple of small imperfections to sort out before the silver paint. I think that might well be a casting flaw or crack that was allowing air to leak out & has been welded up.
Todos con Lorca
Apr 20, 2021 13:59:31 GMT
Thanks. That idea did occur to me, but wasn't sure about it. Sounds like it should be fine.
Apr 26, 2021 16:40:08 GMT
I got a set of fresh 225/35R18 tyres fitted by my favourite tyre place today. Obviously these cost more than the purchase price of the car! The wheels are on and I got the Cougar out to clean off all that dust and grinding grit. That's better. Enthused, I tackled a couple of square feet of the rear arch with Autoglym Paint Renovator to remove a load of dark grey overspray specks. A previous owner seems to have been careless with a painting job near the car. It's come up nicely just rubbing by hand. I think a few sessions of the same will be a good first pass at the paintwork before deciding on more paint correction. There are still some mechanical jobs to do (dealing with a sticky caliper for one), but the project has switched to paintwork and cosmetics.
bstardchild
Club RR Member Number: 71
2000 V6 Ford Cougar comebackbstardchild
@bstardchild
Club Retro Rides Member 71
Apr 26, 2021 17:45:19 GMT
Rear panel in and some coats of zinc primer to keep it clean until cosmetics time. Enjoyed this havent seen it before - thanks for sharing but one bit of advice as I understand it You'll need a sympathetic MOT tester or some better weld clean up to make that repair invisible For MOT repairs need to be continuously welded on all edges - that includes the bottom edge where it's easy to see you have puddle welded it on - you can only replicate factory welding when you replace complete pannels I ran a slitting disc along mine just cutting thro the top skin and then ran a line of weld along it - that seemed to satisfy the "requirements" of being a continuous weld
Apr 26, 2021 18:44:59 GMT
Interesting. Thanks.
I understood it to require puddle welding where original spot welding had been in place. Point taken though and for belt and braces it wouldn't take much to make that continuous. In fact much of it has been made continuous as the edges weren't tidy enough for my liking, so I might zip up the remaining repairs anyway.
I've been rubbing down paintwork and fillering the sill repairs. A nice car is starting to appear. More and more I find the shape looks ahead of its time but that Ford were fitting tiny wheels 20 years ago.
Working cutting compound by hand was going to be hard work on the left side of the car where more attention was needed. I thought about buying a polishing buff, but this is a cheap project. For the price of a compound head, fitted on a suitable bolt found in the shed, I went the bodger's route. Pro detailers look away now. It works for me. The sill corners have been shaped and have a coat of stone-chip to match the rest of the sill texture. Continuing with body repairs, this week's lesson learned is that dolly and hammer aren't ideal for amateur PDR. Rather than spend hours and hours on repairing dings I've decided to live with what can't be fixed with rubbing compound. I'll deal with those later if I want but I'd rather push on with getting the car finished. I fitted the rear bumper and buffed it. There are scuffs on one side but it's better than the full repaint I had planned.
Thanks. I've not looked into it much but do they charge per dent? I have a few fairly light dings.
May 11, 2021 17:33:31 GMT
Thanks. It sounds like it's worth getting a quote at least. I masked and sprayed the sill repairs yesterday, but need to get the car out into daylight to check the colour-match of my Ebay-bought aerosol can. Fitting the front wings....I wasn't looking forward to this task, but it's worked out well. The bottom edges of the wings, the bit just ahead of the doors, were rusty. One of them is solid enough and only needed removal of a perforated corner. Well, nobody will see it. Trying to patch the other wing ended up with me chasing a hole with the welder. There was nothing else for it but to remake the last 3 inches of the wing. I clamped up a load of bits of wood to jig the bottom flange to the correct position, so this is my satisfying end to the day. It's not earth shattering but it's a nice step forward. I'll prep the bare metal but ultimately I'll schutz up to the paint-line on this wing and follow that line along the underside of the sills. When I get the front wings on, the next step will be sorting out the front bumper. It looks scruffy enough for a full respray. I'm back to checking the result on the sills to decide how to deal with that.
Rich
Club RR Member Number: 160
2000 V6 Ford Cougar comebackRich
@foxmcintyre
Club Retro Rides Member 160
May 11, 2021 17:52:52 GMT
In regards to the MOT test comment, that’s incorrect information, the test rules have changed allowing spot welded seams to be replicated if the original seam was spot welded and the replacement panel work isn’t a patch over the top. Patch repairs still have to be a continual weld but the repairs that have been carried out are perfectly acceptable under the MOT guidelines.
Last Edit: May 11, 2021 20:04:35 GMT by Rich
bstardchild
@bstardchild
May 11, 2021 19:59:18 GMT
In regards to the MOT test comment, that’s incorrect information, the test rules have changed allowing spot welded seams to be replicated if the original seam was spot welded and the replacement panel work isn’t a patch over the top. Patch repairs still have to be a continual weld but the repairs that have been carried out are perfectly acceptable under the MOT guidelines. Ahh that's good to hear - I'll have to download a newer copy of the MOT rules - thanks for pointing that out Rich
Last Edit: May 11, 2021 20:04:49 GMT by Rich
Rich
@foxmcintyre
May 11, 2021 20:03:39 GMT
In regards to the MOT test comment, that’s incorrect information, the test rules have changed allowing spot welded seams to be replicated if the original seam was spot welded and the replacement panel work isn’t a patch over the top. Patch repairs still have to be a continual weld but the repairs that have been carried out are perfectly acceptable under the MOT guidelines. Ahh that's good to hear - I'll have to download a newer copy of the MOT rules - thanks for pointing that out RichNo trouble, wasn't trying to be that guy, just want the OP to know that his repairs are up to standard and what not. Not to derail too much, but the up-to-date regs can always be found here
Last Edit: May 11, 2021 20:05:05 GMT by Rich
