Hi all,
Can you help with this fabrication;
I want to copy a headlight (simple shape of the light with glass cover on) from a 1969 Merc in 3d then make some minor changes to cut a hole to accept a 7" light bolt and one for an indicator.
Then I want these cut/milled out of a corrosion resistant aluminium alloy.
Any idea what the process of scanning, digitising and the milling out is called, so I can find the people who do this kind of wizardry? The latter part will be CNC I guess. But the scanning and modifying??!
Thank you
U
Thank you
U
