As per title stripping my spare vvti that's spat a rod. Thought it had been run out of oil but the more I've taken off the more I think it's ingested water (and then been parked in it) 😂😂 no idea on prices if I'm too dear just say (if I'm too cheap grab a bargain or tell me if your really nice) haha. Will do deals on multiple bits to get them out my way
All prices plus postage, cash on collection from Sheffield/Rotherham is welcomed. If it's not listed I may have it just ask.
Pair of cam covers £40
Complete front and rear water bridges with thermostat housing £50
Complete inlet manifold with both rails and injectors. There was water sat inside it when I pulled it off but should clean up ok when split/blasted/dipped.. will throw throttle body in, may be scrap may have salvageable bits on £50
Full set of 8 denso Toyota coilpacks. Untested but obviously were working when it spat a rod 😂. Assume you may have a duff one in the 8 SOLD
Aircon pump, it turns and what's pictured is there.. untested. £30
Power steering pump/pulley/resevoir.. spins and isn't lathered in oil so may be good may want seals and a bearing in it, £30
Aux belt Idler pulley and housing. Bearing is rough but I believe they can be swapped £20
Pair of upper cambelt covers. £30
Complete oil filter housing (not pictured but didn't want oil all over) £30
Pair of vvti heads with cam pulleys and everything still on. May be some use. May be scrap metal. Won't know til I've taken them off. Offers.
Also have he loom ECU and maf. But I've given someone first refusal on that.
If I'm miles off on prices let me know. Will stick stuff on eBay if it doesn't go
Cheers
Cheers
