betenoir
Afraid of the Light
51rider Thanks for the tip. I have not previously heard of Seconds & Co but I will look them up if I decide to insulate the garage. This build thread is some way behind actual progress on the garage, however, and I have been working in there for a year now. Even during the winter I usually have the personal door open when I am working in there, so insulating it would make no sense, unless I start feeling the cold more.
bazzateer
Imping along sans Vogue
That looks like a great space to work in. Before you get too settled, do reconsider installing some insulation to make it more comfortable all year round as it also helps to keep it cooler in the summer. If you use seconds & co to source your sheets, it won’t cost a fortune either and you will be able to do the roof too. You can find them on the web and also by the same username on eBay too. I got all of my insulation for my timber frame garage from them and saved a bundle. I know bazzateer used them on his build following my suggestion and saved a bundle - speaking of which, he still owes me that pint for the recommendation! It's probably gone flat by now. 😉 Seconds and Co well worth it.
betenoir
Afraid of the Light
I fitted a pair of bulkhead lights on the front of the garage above the doors. I had added these to the original sketches I did for the planning submission, but I was surprised to see how closely the reality resembled what I had imagined many months earlier. The PIR sensor which switches these lights does so via one of a pair of double mains sockets located high up on the inside front wall. I have wired them like this because I also wanted the option to plug-in an illuminated SEAT sign I acquired from eBay. This sign is mounted on the inside of one of the front doors. There is no good reason to have it switched by the PIR, I just enjoy being able to see the sign illuminated when I look out of the kitchen window.  On the panel beneath these sockets, between the front doors, I put in a retractable socket which reaches down the middle of the garage, or over most of the driveway if I use it outside. Below that I have hooks for hanging the access ramps. I had not realised until I looked at this picture how colour-coordinated this looks alongside the fire extinguisher and brushes, mop etc.
betenoir
Afraid of the Light
The high level mains sockets at the front of the garage are mirrored by another pair on the rear wall, which are both wired more conventionally as part of the socket ring. One of these sockets is used to power a wall fan. I bought the fan specifically to go in the garage, but when it arrived the fan blades were cheap looking 'smoked' plastic. I had a rattle can of yellow paint in the other garage, so obviously I had to dismantle the fan and spray the blades yellow. Now it looks much more in keeping with its surroundings.
Project Garage Workshopglenanderson
@glenanderson
Club Retro Rides Member 64
Feb 15, 2021 14:17:43 GMT |
That bolt socket is genius. You owe me £20 you swine!
betenoir
Afraid of the Light
Feb 15, 2021 21:05:50 GMT |
glenanderson I take full responsibility for causing you to be envious of my posh bolt sockets. If you cannot cope with the envy, and feel the need to spend your money as a consequence, that is all on you!
@glenanderson
Feb 15, 2021 21:35:34 GMT |
I have a driveway finished in that massively annoying pea-beach stuff that gets stuck in your boot cleats and tyre treads. My father-in-law obsessively rakes it about and seems incapable of not sweeping it into the bolt holes for the garage door. This seems like an easier solution than beating him to death with the yard broom.
betenoir
Afraid of the Light
Feb 18, 2021 19:15:04 GMT |
The side walls of the garage will be mostly kept clear to maximise the space available for working, but above the workbench and tool cabinets I want to use the end wall for various shelves and other storage. The lining panels are 12mm thick and not intended to be structural, so I had to add some reinforcement behind. This is the southwest corner. The single horizontal reinforcement to the right of the corner was put in earlier, and supports a TV bracket. The four narrower bits to the left of the corner are for a pegboard. The black cable in this picture is the feed for the TV aerial. I intend to use the TV more as a PC display, but I have run a cable from the aerial distribution amplifier in the house so I can tune-in to Final Score on a Saturday afternoon in the workshop.  In the southeast corner the temporary electrical supply arrangement can be seen here, and to the right of the corner there will be shelves for power tools and suchlike.  In between the windows on the south wall I put in a couple of bits of 4x2. At this point I was not sure exactly what I needed these for, but I was pretty sure they would prove useful. The grey cables here connect the mains sockets, whilst the black one is for the DAB aerial socket.  Previously I always seemed to have tools charging all over the place, and still managed not to have the one I needed charged on a regular basis. In this workshop I was determined to be more organised, so I put in a unit where I can store and charge them all together.
betenoir
Afraid of the Light
Feb 18, 2021 19:18:02 GMT |
The structure of the roof supports readily lends itself to the addition of shelves for parts storage. I bought a load of timber slats, screwed them to the tops of the joists, and suddenly wasted space is wasted no more.
betenoir
Afraid of the Light
Feb 22, 2021 21:03:39 GMT |
I had not expected my shelf slats to engender so many (or indeed, any) likes!
betenoir
Afraid of the Light
Feb 22, 2021 21:07:09 GMT |
I deliberately did not bury an electrical supply cable into the slab, because I had the idea to run the cable via a bridge. The workshop is less than 2m from the house at its closest point, and we intend to put a gate or gates there, so it did not even need to be obvious that the cable bridge was anything more than a bar across above the gate(s). Fixing a gatepost to the corner of the garage was simple enough, and gave me a level at which to fit the other post to the corner of the house. The top bar is a sandwich, with 95mm wide boards top and bottom, and a pair of 32mm wide strips in between, fixed to align with the outside faces of the wider boards, so there is a 30mm gap down the middle. This gap houses the mains supply and aerial cables. The orange cable shown in this picture is the temporary mains supply.
betenoir
Afraid of the Light
Feb 22, 2021 21:10:12 GMT |
Finally it was time for the proper mains supply to go in. The electricity meter and consumer unit in the house were located in a passageway leading to the back door when the house was built, but since then it has been re-modelled including an extension on the back, so the electrical supply comes in more or less in the middle of the house, which is clearly not ideal when it comes to running a new chunky cable out to the workshop. The electrician earned his money getting the cable into a riser to floor level, under the floor to the front wall of the house, and around to the rear corner to go over the cable bridge. Inside the workshop there is a new consumer unit with separate circuit breakers for the lights and sockets. Getting this in place meant that the final wall lining panel could also go in.  The testing of my wiring did not show up any problems, in fact the electrician said he would be happy to give me a job!
betenoir
Afraid of the Light
Feb 26, 2021 23:43:52 GMT |
I mentioned earlier in the thread that I had plans to install pegboards, that was the reason for some of the reinforcement installed behind the wall panels. After getting my head around the various combinations of dimensions, material, hole pitch, and even colour available, I settled on Sealey pegboards. These are the perfect size to fit either side of one of the windows, are steel, and have standard 25mm between hole centres. The fact that they happen also to be grey makes them just perfect.  I bought a random selection of pegboard hooks from Amazon, and then started the fun of trying to decide which tools should go on the pegboard, and how they should be arranged. This photo was taken after one of my early attempts, and many other combinations have been tried since. A new workbench and heavy duty shelf unit also came from Sealey. The shelf unit is supposedly capable of supporting 1500kg, which means I could theoretically put an entire mk2 Ibiza in pieces on the shelves. That may yet prove to be useful.
betenoir
Afraid of the Light
Feb 26, 2021 23:46:47 GMT |
On either end of the roof, at the apex of the fascia boards, the garage had diamond shaped pieces of wood nailed in place. I assume these are a traditional thing, certainly they seem very common, but I wanted a more individual touch. I could have made something out of wood, but I had enough of woodwork inside, so I decided on something else, and that something else was perspex. I could not find anything around 10mm thick, which was what I wanted, so I bought some 5mm sheets and some strong glue, and the woodworking clamps got another outing.  Once the glue had set, I tidied and painted the edges of the shapes I had cut before gluing, cut some eyes from black vinyl, and screwed my new alien sentries to the fascias, using black screw covers sold for number plate fixings. These things serve no useful purpose whatsoever, but they make me smile.
@glenanderson
Feb 28, 2021 19:06:12 GMT |
They’re called finials; they protect the end grain of the barge boards, and they’re pointed at the top and bottom to encourage water to drip off them. They do a job as well as giving a decorative flourish. 👍👍
betenoir
Afraid of the Light
glenanderson Thanks for that. Hopefully my perspex aliens will do the job no less effectively.
betenoir
Afraid of the Light
Finialiens, perhaps?
Excellent job but I feel you need more hammers
It will come in handy even if you never use it
@glenanderson
A man can never have enough things for hitting other things with. It’s a rule. 😉
betenoir
Afraid of the Light
Throughout the build and fit-out I had been promising myself a new and bigger tool cabinet. I already had a couple of SGS Engineering cabinets, and although they are not as sturdy as 'professional' cabinets I have found them to be durable enough for a hobbyist such as myself.  I chose this particular cabinet partly because it can be 'extended' by bolting additional cabinets to the sides. Almost straight away I realised I needed to add one side cabinet to accommodate tools which would otherwise be homeless.  Right from the outset I knew I wanted to make use of the wall space above the windows, but it took me a while to settle on how I wanted to do that. What I ended-up with was helmet shelves one side  and tambour (roller shutter) cabinets the other side. On top of the cabinets is my Windows 7 PC running ElsaWin, which displays on either the small monitor above the workbench or the TV in the corner. I bought this PC specifically because I was fed-up with struggling to run ElsaWin in VirtualBox on my laptop. Somehow I managed to find myself with a version of ElsaWin which does not include the mk2 Ibiza, however, which is unfortunate!
