Possibly the most pointless recon ever but it was a case of "I can so I will". TBF they do get a bit lazy starting at higher mileages as the valves and seats get a hammering and it closes the clearances up. Anyway:-
Reconditioned head with 8x new valves, seats cut, cleaned, skimmed and reshimmed.
Bores honed
Block Decked
Pistons cleaned & new rings fitted
Crank polished
New Main Bearings
New Big End Bearings
New OE Oil Pump
Bosch Fuel Pump
Injectors Tested & Cleaned
New Gates Waterpump & Cambelt Kit
Larger alternator fitted
New Aux belt
New filters (oil fitted, comes with air and fuel also)
New Glowplugs
Complete ready to bolt in with inlet/exhaust manifold + flywheel.
Collection from Leeds or I can deliver for a agreed price. Price is ONO.
Bores honed
Block Decked
Crank polished
New Main Bearings
New OE Oil Pump
Bosch Fuel Pump
New Aux belt
New Glowplugs
