I see one for sale here in Ireland. Comes with loom, alt, starter, gearbox, manifold, inlet and carb. From a (usa) granada. I assume it's the 302. Might be a 350? Questions are. Is it a decent engine? Suitable for a small, light, car? Decent spares availability? Any help would be appreciated, thanks.
It'll be about the worst version of that engine you can get, probably 130hp or so. If it's cheap enough it's worth having as one to build though, they're great with a few mods and pretty small
Just had a quick Google, they also did the 351 Windsor in the Granada. If it's one of those it's definitely worth having.
Dec 21, 2020 10:23:47 GMT
Looks like a 302, the 351 intake is about 2" wider than the 302. They are good engines but as Matt said it may well be a lo-po motor. Easy to wake up but it will cost, just depends how far you want to go. Looks like a C4 trans. This may need attention as well so budget for this. Easy to do yourself though. Unless you know for sure it runs it's a rebuild and the price should reflect that although they still fetch good money.
Dec 21, 2020 10:40:21 GMT
£ per hp has definitely gone a bit ridiculous on Yank engines.
Dec 21, 2020 11:38:44 GMT
They are good engines.
I've owned the 260, 289, 302, and 351 versions of it.
The 302 is probably the most common, and that one is quite a bit lighter than the 283/327/350 Chevy ( but I still prefer the Chevy )
Unless you have a HiPo 289 ( which that one isnt) the heads will be really restrictive.
The later 5.0's are better, but not by that much.
Some later Explorer heads are big step in the right direction, but a better bet are some aftermarket heads.
( don't get the super cheap Ebay ones, I've heard stories of them lasting one single 1/4 pass )
Lots of aftermarket stuff available for them to make them go faster.
Even if you'd run the asthmatic stock heads, a mild cam ( like a 268H Comp Cam ) and a 600 Vac Sec Holley with a 4BBL dual plane intake will make a big difference.
The C4 is a good transmission, and you can get stall converters, manual valve bodies, etc for them too.
Great engine for a light car.
Although if you live in the UK, a Rover V8 could be more practical...
A word of warning about US Ford stuff, they like to make things almost fit between the different ages.
So things like pulley offsets, etc , can vary by a lot.
So make sure you know the exact year it was made ( you can tell by the casting # near the starter), and ask questions before you order anything.
Dec 21, 2020 11:55:44 GMT
P.S.
Stay away from the 255 version ( had one of those too ) from the '80s
Its the worst one of them all, with a smaller bore that matches nothing else and heads that wouldnt breathe enough for a 1300cc Kent.
And also a weird external balance on the flex plate , if I remember correctly.
That one is pure garbage and not worth having.
Dec 21, 2020 13:29:28 GMT
Re Rover's, they're bigger than the 302, expensive to rebuild/tune and are not that powerful in stock condition. Mine p*sses oil out as well, a common issue. I'd take a 302 and C4 ( as said a good trans) any day.
Dec 21, 2020 15:42:08 GMT
Re Rover's, they're bigger than the 302, expensive to rebuild/tune and are not that powerful in stock condition. Mine p*sses oil out as well, a common issue. I'd take a 302 and C4 ( as said a good trans) any day. [ Yeah theres a reason the rover was called a nailhead engine when it was a buick! Also if it bothers you, a rover will use more fuel than an American v8 (usually!) particularly if its in a Range Rover 🙄
Paul Y
Dec 21, 2020 15:51:06 GMT
302 is good to go with a few mods - Explorer heads/Gt40 heads - avoid the ones with 4 cast in lines on the front of the head as they need a very specific header - Cam and a performer inlet and a brawler carb and you are going to be good for 300ish crank. Matching converter and shift kit in the C4 and you are going to enjoy that in a light car - match it up with a T5 and it will be even better! P.
Dec 21, 2020 17:51:10 GMT
Thank you all for the advise and comments. He has a video of it running which he is to send to me tonight. I'll upload it here. He is asking £650 for everything?
Dec 21, 2020 17:54:59 GMT
Re Rover's, they're bigger than the 302, expensive to rebuild/tune and are not that powerful in stock condition. Mine p*sses oil out as well, a common issue. I'd take a 302 and C4 ( as said a good trans) any day. [ Yeah theres a reason the rover was called a nailhead engine when it was a buick! Also if it bothers you, a rover will use more fuel than an American v8 (usually!) particularly if its in a Range Rover 🙄 It will be going in a Ford Hotrod. I'd prefer a ford engine.
Dec 21, 2020 18:25:05 GMT
Re Rover's, they're bigger than the 302, expensive to rebuild/tune and are not that powerful in stock condition. Mine p*sses oil out as well, a common issue. I'd take a 302 and C4 ( as said a good trans) any day. [ Yeah theres a reason the rover was called a nailhead engine when it was a buick! Also if it bothers you, a rover will use more fuel than an American v8 (usually!) particularly if its in a Range Rover 🙄 Anorak alert... The Nailhead is the cast iron 264 to 425 cubic inch Buick. The smaller 215 is sometimes called the pinhead to differentiate it from the bigger version ( like with the rat and mouse Chevy big & small blocks )
Dec 21, 2020 18:32:41 GMT
Thank you all for the advise and comments. He has a video of it running which he is to send to me tonight. I'll upload it here. He is asking £650 for everything? Bargain!
Dez
Club RR Member Number: 34
Dec 21, 2020 19:31:23 GMT
Looks like everything has been covered, but even with the sh1te 2 barrel setup 650 for a running setup is a bargain.
Dec 21, 2020 21:05:53 GMT
£650 is good for a runner. It's pot luck whether it'll be worn out internally (most are) and TBF it doesn't really make much difference to how they run.
A colleague runs a 302 with 289 heads in his Falcon. Reckons it goes considerably harder than standard.
Paul Y
Dec 22, 2020 12:16:53 GMT
For £650 I would say that is a bargain. And ( to paraphrase Brian in Hot Rod) If you are going to rebuild it might as well go fast.... Let me have a look in the Shed of Tat (tm) - I might have a shift kit for the C4. P.
Dec 23, 2020 10:23:36 GMT
He sold it!! I was trying to meet him sun, mon, tue. Yesterday he messaged me that it was sold...
Dec 23, 2020 11:13:18 GMT
Dutch auction??☹️
