Hi all
I’ll be respraying some areas on my VW T4. The original paint (white) is clear over base, I was going to go for a solid gloss as it’s easier. There’s a couple of areas where I’ll need to blend the new paint into the old, along the roof rails, front edge of roof and sills - will this work ok with blending a solid gloss paint or will I need to use clear over base as per the original paint?
Was just planning to blend the solid gloss colour and use a bit of fade out thinner to avoid a paint edge.
