Hi all,
Cosworth front TCA's Ford motor sport part no: 9095637 (gravel spec)
There is damage on them as can be seen in the pictures where the rubber boots fit
Comp struts were new items but for use with original TCA's I just cut the ends off and welded on my version to connect them to the TCA'a
Rod ends are all under a year old with no play in them
These are listed on Ebay as well as on here
£550.00 or best offer
Can collect from DN18 Barton upon Humber
If you want txt, call etc 07894315304
