Flynn
Club RR Member Number: 166
1983 Daimler Sovereign 4.2Flynn
@flynn
Club Retro Rides Member 166
Hello again. A few more weeks have passed, what great success have I achieved? Car wise - not a lot really. The XJR has seen around 500 miles now and I am really very fond of it already. Still got various little niggles to sort out but it has been my daily vehicle for the last few weeks and aside from a suicidal pheasant taking out a main beam head lamp unit (replaced for a whole £15 off eBay!) and a very slight 'clunk' from something driveline related when shifting down gears when coming to a halt, it has been perfect. I think once I get the central locking sorted and get to the bottom of the driveline 'clunk' I'll probably look at selling it on. Which doesn't really make sense but I've been doing this long enough to know how it goes and it generally goes something like this: - Buy a car that I consider really nice and in good condition (the newer XJ I had was the last one)
- Decide it is too nice, feel stressed when using it/don't bond with it and then sell it
- Buy something rubbish, fix it up a bit, basically fall in love with it, use it for a few months and then think "this is a bit rubbish, I should get something better".
- Repeat.
I will change my mind a few more times yet though.
Here is what an X308 XJR looks like missing a main beam head lamp:
Anyway. I digress.
The Daimler!
I have been slowly chipping away at various parts of the Daimler. The front subframe parts came back from the powder coaters and so, over a few nights last week, I got everything back together apart from the front brakes (they weigh so much I decided to reassemble when back on the car). My plan is to get the car rolling again before I put the engine back in - it will just make a few other little jobs I want to do a lot easier if I can move the car about and ultimately, the job of reinstalling the engine should be made easier if I can roll the car out of the garage and then not have to contend with a small step at the edge of my garage, which was fine when I was taking the engine out and rolling down the step, but will be more problematic when I have the 250Kg+ engine on the hoist, trying to push it up the same step.
Here is the subframe back from powder coating, you might not be able to make it out on the pictures but there was some pretty serious corrosion on this, the worst has been patched and the shiny black paint goes a long way to making it look nice but I think if this were a perfect world and a car with a limitless budget, I would have hunted down a more solid unit to start with. Yes, pictures:
One day I'll have that whole bench covered in EBC Brakes stickers. It took quite a bit of faffing around to get the subframe back together, it turns out the upper wishbone arms have specific locations, it is very subtle but there is a difference! I haven't made a note of it anywhere so here will do to remind me, I haven't actually torqued much of the bolts to spec, yet. New track rod ends will be going on and despite appearances, the steering rack has been apart and had some dodgy looking seals replaced so hopefully it won't leak. And there it is back in the car, I was wary about this step as if you recall from earlier, I had cut the front mounts off to repair some corrosion on the chassis rails. I was relieved when it bolted back in no hassle. I remembered I hadn't ordered any new nuts for the massive subframe bolts so they have been added to the list. I now have to get loads of engine bay jobs done before the engine can go back in. New battery cables and a general inspect and tidy up of the engine bay wiring is one of the bigger jobs but should be totally worth it when back together. Speaking of the engine, it is all ready to go apart from a few minor details: Series 3 XJ6's were fitted with an engine oil cooler - you can see it still attached to the engine in some earlier pictures. My cooler has had that horrible oil and water emulsion gunge go through it and so I wanted a new one, I didn't want to pay Jaguar prices (£200) so I bought a generic 19 row oil cooler with 3/4BSP connections (£47). Turns out Jaguar didn't fancy the well proven BSP standard connections and have gone for a stub pipe with O ring type affair, so my bargain oil cooler is no good without modifying the Jaguar pipe connections. The pipes are rusty and if nothing else, are approaching 40 years old and are partially made from rubber so I can't imagine have long left for this world anyway. I took a step back from the situation and then realised my series 2 XJ6 had an identical engine and no oil cooler, I ran that car in traffic on the hottest summer day we had in 2019 with no problems so have come to the conclusion that an engine oil cooler probably isn't necessary anyway, so I am going to do away with it. I've bought some compression fittings which should allow me to use what is left of the metal part of the standard Jaguar cooler pipes to just make a loop. Might be ugly but will work ok - not too unlike myself. I've not gone mad with painting it either, just given it a dusting to smarten things up, looks pretty good I think: That intake manifold and fuel injection set up was a project all on its own. I've replaced every single bit of rubber fuel hose for ethanol safe stuff now. If I keep working on it like I have been, an hour here or there, I should have the engine bay jobs done and the engine back in over the next month or 6 weeks I reckon. Hopefully I don't miss out on summer time! I hope you're all well. Good evening.
1971 MGB GT 1983 Daimler Sovereign 4.2 1999 Jaguar XJR
Flynn
@flynn
Jun 10, 2021 23:53:11 GMT
Apparently there was a partial solar eclipse today. I didn't notice it. More weeks have passed and generally, slow progress has been made, which I shall tell you about. XJR failed its MOT test, was expecting it and had planned to have it off the road for a bit whilst I tidy some bits up on it. Failed only on emissions, some way short of an emissions test pass too, it produces an absolute stink from the exhaust pipes when running but otherwise runs perfectly, it is on original cats so thinking it might just need a new set of cats, the low mileage over the last few years would probably mean a lot of driving cold, starting up and shuffling around a driveway etc, not good for cats. I'll do some proper investigation in a few weeks, I don't need the car at the moment and the air con doesn't work and I have no budget for fixing that right now so it can just sit in the garage and wait its turn. I strongly believe this is one of the best looking cars I have owned: DAIMLER The rebuilt engine is now back in and all of that went pretty well, nice warm day, pulled the car out of the garage which ended up being a mistake but it allowed me to flush out the heater matrix and it was nice to work outside, I picked a good day for it. First time this car has been outside since November last year. Turns out the handbrake caliper on the right hand side had almost totally seized on, only found this out when trying to push the car back in the garage. Ended up bathing the rear discs in WD40 and taking a run up and eventually got the car back in the garage - another problem for a another day. My goal at the end of the engine installation day was to crank the car over and make sure oil pressure looked ok before firing it up. Oil pressure cranking over was 80psi on the gauge so that is great and gave me the peace of mind to keep putting things back together. I hadn't paid any attention to the radiator the entire time I have owned the Daimler, I drained it and removed it and then tucked it out of the way and forgot all about it, when I came to refit it, it had clearly been leaking all over the place for some time and was in a pretty sorry state. After some research I discovered I had 3 real options, first was to buy a new standard rad from SCParts, I forget how much exactly but it was ridiculous, £700 something so that was immediately ruled out (none of the other suppliers seemed to stock a series 3 4.2 rad), option 2 was to get my knackered one re-cored - £300ish. Option 3 was to buy the cheapest alloy rad for a V12 series 3 and try to make it fit - £169. Obviously I went with option 3 and when it arrived I assumed I had been sent the rad from a lorry by mistake, it is huge. The old above and the new below. I had to a bit of creative codging about with hoses and unfortunately one of the hoses was only available in red it all works though, I've filled the cooling system and nothing came pouring back out. My latest issue is trying to get the old girl to fire up and idle, first off I had set the ignition timing wrong which was quickly resolved by swapping the leads over on the distributor, it coughed to life and idled great, it actually sounded really good... For 5 seconds and then died. I did some reading up on the fuel injection system and apparently, if the air flow meter doesn't move, the fuel pump stops running. I had been cranking the car with the air flow meter off so I put all of that back together and then tried again, a slight cough and then nothing. I tried once more but just had fuel pouring out of the intake manifold. I then just ran the fuel pump and could see fuel pouring out of the intake again, I took the injectors out of the manifold whilst still connected to the fuel rail and then ran the fuel pump and one of the injectors was stuck open. Annoying but surely not enough to stop the engine running? New injectors are silly money so I bought a cheap ultrasonic parts cleaner for half the price of one new injector and gave the stuck injector 15 minutes of vibro-death. The vibro-death actually worked to my surprise and the injector wasn't stuck open any more. I have put it all back together and now my latest issue appears to be the injectors and delivering so much fuel, the engine won't start. if I crank over with the fuel injection system all plugged in, no start. If I then disconnect the electrical connection to all injectors and crank it over, it runs sweet until it then runs out of fuel. Apart from the head gasket failure, the engine ran ok before I took it out of the car so I am hopeful it is something silly, I can't imagine that all injectors would just suddenly go bad and this problem does seem to affect all injectors so my next stop on the route to finding root cause is the only other thing I can think of that effects all injectors - fuel pressure, again a fuel pressure tester is significantly cheaper than a fuel injector or a pressure regulator so I've ordered one and that is my next stop. Hopefully next post from me will be a triumphant declaration of an MOT pass for the Daimler! Good evening.
Jun 11, 2021 19:57:28 GMT
If you need some injectors I have 8 which I bought for my range rover but turned out to be xj6 ones (apparently fitting them to a RV8 was a tuning trick) I've cleaned and flow checked them all at 10% and 100% flow and they seem OK, they cost me £30 you can have them for the same. PM me if you are interested.
It does sound like you have another problem though, I wonder if the regulator has failed or the return line is blocked/crushed somewhere.
Flynn
@flynn
Jun 11, 2021 21:02:21 GMT
If you need some injectors I have 8 which I bought for my range rover but turned out to be xj6 ones (apparently fitting them to a RV8 was a tuning trick) I've cleaned and flow checked them all at 10% and 100% flow and they seem OK, they cost me £30 you can have them for the same. PM me if you are interested. It does sound like you have another problem though, I wonder if the regulator has failed or the return line is blocked/crushed somewhere. Thank you kevins that is very kind and I may well take you up on that. The fuel pressure test kit I have ordered should arrive this week so I will hopefully have a better idea what my problem is then. I am conscious of not wanting to crank over my brand new engine too much, knowing its chucking fuel down my nice new cylinders so I started working through some of the known electrical issues this afternoon and had some excellent results. I now have a working stereo, with operational electric aerial! The stereo only seems to want to increase the volume no matter what button you press so probably only fit for the bin, but still marking it out as a victory. Central locking is working great on all but one door, electric mirrors work, electric windows are dreadfully slow but all work, all the exterior lights now work, incredible really! Anyway thanks again and I should be able to let you know over the next week or so if I need to tap you up for injectors.
Love an old Jag/ Daimler. BOOKMARKED
Just read the whole thread, not having spotted it previously.
Very informative and nicely written, please keep it coming!
Love the cars, particularly The XJR. I have a friend with a similar Jaguar addiction,usually X308s. He currently has a 2002 3.2 sport which is lovely. Needs a new headlining just like yours.
I'd like one myself but have a TVR money pit and no room for another car.
Cheers,
Andy
You have probably thought of this Flynn , but is the vacuum pipe on the fuel pressure regulator ?
regards robert
Jun 12, 2021 20:48:00 GMT
Option 3 was to buy the cheapest alloy rad for a V12 series 3 and try to make it fit - £169. Obviously I went with option 3 and when it arrived I assumed I had been sent the rad from a lorry by mistake, it is huge. The old above and the new below. Stupid question perhaps, but aren't the V12 radiators dual pass radiators (or is that just the XJS's)? Because if they are the way you've hooked yours up might not cool as well as it could.
Last Edit: Jun 12, 2021 20:49:30 GMT by mkickert
Flynn
@flynn
Jun 12, 2021 22:00:01 GMT
Good evening all, I've never worked out how to quote multiple people in one reply so will try the highlighting usernames thing instead, this may fail miserably... nickduncan - clearly a chap of good taste, glad to have you on board. cerbsp6 - Glad you've enjoyed reading so far, that XJR is my first x308 and I have to say they are very easy to live with, looks great and comes with all I expect of a modern car whilst still feeling like something from times past but also properly fast (as far as I am concerned anyway, you'd probably find it a bit sedate compared to your TVR!). Great value too. You can tell your friend that the replacement headliners from Myrtle Ltd are first class, that one I fitted went up in about an hour or so and it fits really well, very happy with it. ivanhoew - I have checked and double checked and can confirm vacuum pipe is present and correct, what you said though did spur me on to make sure all other vacuum take offs on the intake manifold were accounted for and doing a job which they are. I then went on to fuel return line and made sure it was free from obstructions, which it appears to be. mkickert - Not a stupid question at all! I don't know very much about cooling systems so if you can tell me more about this I'd be interested to hear it. The radiator I bought was listed as being suitable for both an XJ12 series 3 and XJS, does 'dual pass' refer to there being a coolant outlet from each head in to either side of the rad on V12 engined cars? As you can see I bodged one of those to be a degas line because I was trying best to mimic the standard radiator. Could I do something differently that would be better?
Last Edit: Jun 12, 2021 22:01:52 GMT by Flynn
and its definately a constant vacuum take off, not one near the blade of the throttle body that only gets vac when the throttles open ?
mkickert - Not a stupid question at all! I don't know very much about cooling systems so if you can tell me more about this I'd be interested to hear it. The radiator I bought was listed as being suitable for both an XJ12 series 3 and XJS, does 'dual pass' refer to there being a coolant outlet from each head in to either side of the rad on V12 engined cars? As you can see I bodged one of those to be a degas line because I was trying best to mimic the standard radiator. Could I do something differently that would be better? From what I understand this is how the V12 rads work: Coolant flows from the left top entry across the top third of the rad to the right, which then joins the right top entry to flow back across to the bottom left. This would mean that with the way your rad is currently set up there would be very little flow across the top third of your radiator (coolant enters from the top right and would flow across the lower 2/3rd of the rad to the bottom left), but switching the entry hose to the the left top entry would fix that. I have no idea if your aftermarket radiator works the same however, but it would seem worth checking, right? This site details the radiator situation well (plus it's where I stole the picture). bernardembden.com/xjs/radconvert/index.htm
Jun 13, 2021 10:50:26 GMT
Good evening all, I've never worked out how to quote multiple people in one reply so will try the highlighting usernames thing instead, this may fail miserably... Go to the bottom of each post you want to quote and click the gear wheel. Hit "select post". On the final post you wish to include, just hit the "quote" button and lo and behold, all the posts will be there, ready for your answers!
Flynn
@flynn
and its definately a constant vacuum take off, not one near the blade of the throttle body that only gets vac when the throttles open ? Yes, the vacuum take off is on the main body of the intake manifold, I was going to show a picture with an arrow pointing at it but the intake manifold is such a mess of pipes on a fully assembled engine its almost impossible to see, I found a picture online showing it nice and clearly though: mkickert - Not a stupid question at all! I don't know very much about cooling systems so if you can tell me more about this I'd be interested to hear it. The radiator I bought was listed as being suitable for both an XJ12 series 3 and XJS, does 'dual pass' refer to there being a coolant outlet from each head in to either side of the rad on V12 engined cars? As you can see I bodged one of those to be a degas line because I was trying best to mimic the standard radiator. Could I do something differently that would be better? From what I understand this is how the V12 rads work: Coolant flows from the left top entry across the top third of the rad to the right, which then joins the right top entry to flow back across to the bottom left. This would mean that with the way your rad is currently set up there would be very little flow across the top third of your radiator (coolant enters from the top right and would flow across the lower 2/3rd of the rad to the bottom left), but switching the entry hose to the the left top entry would fix that. I have no idea if your aftermarket radiator works the same however, but it would seem worth checking, right? This site details the radiator situation well (plus it's where I stole the picture). bernardembden.com/xjs/radconvert/index.htmThank you for the information and yes I think certainly worth checking, hopefully I'll get the engine running this week and then I'll take the car for a quick run out to get up to temperature and I'll see then if what I have done gives me any immediate issues, longer term though I think I'll do as you suggest, this would also give me the opportunity to use the threaded holes at the very top of the new rad as a take off for a degas line, which would work better as it would then be at the highest point on the rad. Thanks again. Good evening all, I've never worked out how to quote multiple people in one reply so will try the highlighting usernames thing instead, this may fail miserably... Go to the bottom of each post you want to quote and click the gear wheel. Hit "select post". On the final post you wish to include, just hit the "quote" button and lo and behold, all the posts will be there, ready for your answers! Thanks georgeb!
Flynn
@flynn
Jul 16, 2021 22:13:49 GMT
Good evening, Halfway through July already. Madness. So after several weeks of spending an hour or two here or there, I finally got to the bottom of the problem of why the new engine in the Daimler wouldn't run properly - one broken wire. I couldn't believe how I didn't spot this in my earlier investigations but there you go - it was the earth wire for the coolant temperature sensor and so with that sensor not able provide any information to the ECU, the fuelling is turned up to the point the engine doesn't run/runs so badly you may as well not bother. I had checked the coolant temperature sensor but obviously neglected to check the wiring from sensor to ECU, until yesterday evening! It runs really well now. I feel very relieved and happy I can move on to the rear brakes and then start thinking about getting it on the road. There is still plenty to do and the more look, the more I find but nice to finally put the engine running issues behind me. By this point I have now checked every fuel injection system component at least once so I am now actually pretty confident all of it is in good condition. I even went as far as sending the ECU and air flow meter for testing at ATC Drivetrain in Cannock (Steve was the chap I dealt with there and can recommend the service, very quick turnaround). The ECU was found to be fault free and the air flow meter had been tampered with and was way out of spec so I had that rebuilt for peace of mind. From this very forum Kevins sorted me out with a good set of injectors so thanks again for them. I started feeling sorry for how dusty and horrible the car had got being sat in the garage so I pushed it out and gave it the first wash it has seen in a very long time. That's better. The XJR is in for MOT attempt number 3 tomorrow morning, first attempt failed on emissions - this turned out to be a failed upper exhaust gas oxygen sensor which of course wasn't as straightforward as just swapping out the duff sensor for a new one and clearing the codes oh no, the old sensor wouldn't budge so I had to remove the cat, cut most of the old sensor off with an angle grinder, so I could get an impact socket on to it and then impact it out, it was well in there! This was annoying but gave me a chance to inspect the cat brick which looked fine. I put a new sensor in and checked how it was running and all was well so I booked another test. An hour before the test, I jump in the car to get some fuel and am met with an ABS fault message which won't clear, I phoned up the MOT place and cancelled my slot. Turns out a common X300/308 foible is the soldered main power connections on the board of the ABS module cracking and failing, mine decided to do this the morning of the MOT test, brilliant. I've fixed that so we'll see what tomorrow brings!
Flynn
@flynn
Sept 20, 2021 11:04:28 GMT
Well the good news is that the XJR passed the MOT test and I have been using it as my daily driver for quite a few weeks now. I had it up for sale for a while but really didn't make any effort in trying to move it along, there are only so many times you can politely reply to "HI MATE, STILL FOR SALE???" before you lose interest. I think subconsciously I just don't want to sell it. It does have a lot going for it and if I am honest with myself, I would only eventually replace it with another supercharged V8 Jaguar, so keeping hold of it for a while longer isn't going to be any hassle for me, I have decided to tuck it away over the winter months and see if I can finally resolve some silly little issues like the remote central locking not working. Oh and it leaks oil and that looks like rear main seal so, I might pop the gearbox off and see what's going on. Tax runs out at the end of the month so I think at that point I'll lay it up until next spring. So, if the XJR is going to be resting up over the winter time, what will I be driving instead? A car so terrible it has truly secured a place in my heart - my wife's first car that we still own, a 2004 Renault Modus. Running this car makes a lot of sense, it has almost new Michelin Cross Climate tyres and one of the last things I did with the car before we stopped using it when the plague set in last year, was a full service with a cam belt change shortly before that. It has basically been sat in the garden ever since, I kept the battery on trickle charge... Until I needed the trickle charger for something else, so the battery was flat but once I gave it a jump start it ran like a champ. One problem the Modus does have, is dreadful headlights and that can make for some tiring driving, especially when in just a few short weeks, I will be both driving to and from work, in the dark. To fix that I rediscovered some ridiculous 9" LED spotlights that I had bought for my old Citroen BX but never got round to fitting, and fitted them to this instead. I give you, my perfect winter hack: I've got that booked in for MOT this week so hopefully it will go through and then from October onwards, it is Modus time! Anyway, this thread was once all about the Daimler I bought in November last year and had intended to get on the road for this summer... Which is almost now at an end Daimler progress has been slow but steady. The list of things that needed resolving was very long but is now down to 2 items, indicators and both rear outer fulcrum bearings. Once I fix those things, I think it is MOT time. I have most recently had the rear subframe assembly off the car to make replacing the completely shot rear brake calipers possible. As you can see, it's all rather weathered looking under there and if I fall in love with this car, I'll do a strip down and powder coat job like I did on the front subframe but for now, it's refitted and is all perfectly serviceable, I also noticed that somebody before me, got in here and did 4 new shocks fairly recently which is nice to see. There is a special bolt for the rear radius arms and it made me smile, there is nothing wrong with this, it just made me wonder if you find any solutions like this on more modern cars. The bolt that secures the rear radius arm to the lower suspension arm is very close to the rear shock absorber studs and a normal sized hex head would clash when trying to withdraw or install the bolt and so to clear it, Jaguar came up with this: I have now ran the engine up to temperature a few times and driven the car a little bit and all seems well, if you cast mind back to the original problem with the engine it had a failed head gasket - well so far so good, no combustion gases in the coolant anymore! When the car arrived with me one of the first things I noticed was that the standard radiator cooling fan and viscous coupling had been removed. Replaced instead with a large electric fan that used a temperature probe rammed in to the top hose as a switch. The electric fan sounds very unwell when spun by hand and so I did have a look at reinstating the original viscous fan set up but just the fan, coupling and related bits and pieces were very expensive and the standard fan cowling wouldn't fit the new aftermarket radiator I have fitted without a bit of modification so I decided instead, to buy in 2 cheap 12" electric fans and mount them on the front of the radiator and then use a new coolant temperature switch in the top hose to control when the fan kicks in and out. I fitted the fans with the bonnet and everything else in place so it's not easy to see but here is a picture to give a rough idea what I have been up to:
They seem to work and the coolant temp seems to not get any higher than 90 which is about right, I haven't given it any sort of hard work yet though so I may still revisit the cooling system as per previous posts here. The Daimler is currently all back together and when time allows, I'll strip down the rear hubs and replace the failed outer fulcrum bearings. The dodgy indicators appear to be caused by a faulty hazard light switch and I have a new one in a box ready to go. Only trouble is now the car is trapped in the garage by a skip parked outside (I'm not referring to the Modus before any comedians chime in). So I am forced to wait before I can move it and do any more work to it. Just before some building work started here, I did get a nice picture of the Daimler and this is currently how it sits:
Flynn
@flynn
Good day and happy new year. Life has got in the way of any real progress on the Daimler recently but I am still plodding along with it. I think on my last update I finished up by saying it needed the fulcrum bearings in the rear hubs replacing, the indicators fixing and I may have mentioned the rear fog lights falling out of the bumper, I may have omitted that. So where are we now? Well I'll start with the rear hubs. I took the hub assemblies off the car to have a good look at their condition and all of the bearings were completely shot and everything was absolutely plastered in decades old grease, that had gone harder than Weetabix, when you leave the milky dregs in a bowl and don't get round to washing it for a few days. I chickened out of replacing the bearings in the hubs myself, and instead subbed the work out to Ward Engineering Ltd. I have used them before and they rebuild Jag rear axles for a living, so know exactly what they are doing. Took about 4 weeks from sending them off to getting them back again but they are basically like new and ready to just bolt on, much easier than me fannying around and getting the wheel bearing installation wrong numerous times. See these pictures of what I have been waffling on about: These are the hub assemblies as they were removed from the car, caked in old grease. I needed to clean this off, to get a good look and make sure the mess wasn't hiding cracks or other damage. This is after a quick scrub and they look a lot better for it, I couldn't see any cracks in the housings or any other damage so got them sent off and then waited patiently, some weeks later and these are delivered and are ready now to just bolt back on: In the mean time, with the rear wheels removed and the hubs out of the way, I had plenty of room to take a look at the various fuel lines that run from the fuel tanks, that are situated in the rear wings, in to the boot and then off and away to the engine bay. I found one hose had been replaced fairly recently but everything else appeared to be from '83. Some of it was still actually ok but I thought it best to order up some ethanol safe stuff and replace it all. Whilst having a poke about at the inner wheel arch, a big sheet of glass fibre filler fell off and revealed a big hole. Annoying but in probably the most user friendly place to need rust repair because it all gets covered up by a bolt in lower wing panel. Probably easier to show pictures than lecture: So we're looking towards the rear of the car with our head in the wheel well here and you can see where a patch of filler has fallen off and revealed a big hole in the inner wing panel (the big circular hole is there from the factory! I think earlier cars had a fuel sender unit accessed through there, the sender unit on the series 3 is got at through the rear light aperture). A lot of the common rust spots on this car have turned out to be like this, some of it has been repaired reasonably well (new outer sills, jacking points rebuilt, new rear lower valance panel all done OK) and some of it has either been completely ignored or worse, bodged. In that picture above you can also see a bit of fuel hose which shows the condition that most of it was in. The little round can with two wires coming out of it and fuel hoses attached to it is a solenoid that is there to stop return fuel coming back to the tank that isn't being used, so that you don't end up overfilling a fuel tank (you can select which tank you draw fuel from with a switch on the dashboard). The solenoid was of course broken and so I have a new one ready to go on, once this little rust repair is all finished. So now you can see that I have taken the LH fuel tank off the car so that I don't blow the garage up getting carried away with the grinder or the welder! Doing this also made access to the area much better, the LH side exhaust back box had to come off too. So by now I have made up a new panel using the rusty old bits and have stuck it back on the car, I checked the fit a few times with the bolt on lower wing panel and to my great surprise it all lined up and I was able to loosely bolt it all back together. As is often the way on jobs like this, I ended up with a calamity here and wound up with a gap between the old and new metal that I didn't notice until I had gone too far, I couldn't think of anything else to do with it, than just fill it up with the welder! As the Americans say, "a grinder and paint, make me the welder I ain't" and so that welding is getting the grindy painty treatment tomorrow! As with all of my 'fabrication', it isn't pretty but it certainly won't fall off and it saves £££ me doing it as opposed to paying someone else. This will all be getting slobbered with Dinitrol anyway, which is useful for hiding many sins! The only bits left to sort now are the rear foglights, which fell off the old rear bumper thanks to more rust. I have a new rear bumper bar now and even treated the old girl to a pair of new rear fog lights so once they are on, we should be looking smart and ready for the road! I probably have another few hours tidying up and reassembling everything on the Daimler and then I think I have run out of excuses to not put it in for an MOT test and hopefully start putting some miles on it in the spring. In other fleet updates, the XJR is still here. Tucked up in the garage on trickle charge and I have been sorting out a few more interior trim issues that it had, I have replaced the centre arm rest cubby box lid for one that doesn't have a cup holder. Backwards step you might think but the old cup holder lid was broken and just annoyingly flapped about when open and creaked when closed. Here is the XJR interior - a lovely place to be. That is about it for now. I have owned the Daimler for 13 months now and the furthest I have travelled in it is the end of my driveway haha. Hoping to improve on that this year! Hope all are safe and well.
Last Edit: Jan 5, 2022 23:44:08 GMT by Flynn
Flynn
@flynn
Apr 25, 2022 20:57:36 GMT
Good evening. The headline progress to report here is that the Daimler passed an MOT test on Saturday and is now running and back on the road! This is it mid test, it had just sailed through an emissions assessment and was on its way to an almost clean sheet pass but I had managed to slightly overfill the power steering fluid reservoir, which got hot after idling a bit and leaked a little - earning an advisory. It is a huge weight off my shoulders being able to actually use this car now, I had started to get a bit jaded with it but once I took it out for the first few engine break in runs, I was motivated again and am so glad to be able to get some miles on it now. Since my last post, there hasn't really been much happening with the Daimler, life has gotten in the way recently but last week I managed to tick off the last few little jobs and get it booked in. One of the jobs to do was source and fit a lower grille trim piece, the car arrived with this item missing, it is only a small piece of trim but it really finishes off the front end appearance of the car and it is a crucial bit of protection for the massive radiator that sits behind it. The tabs that should exist to bolt this trim piece to, have clearly rusted away long ago so I had to make and weld on some new ones and generally massage the whole thing to fit properly but it looks ok and should be fine. The car without the lower grille: The lower grille was a bargain off eBay, I think it was less than £40 delivered, for a genuine Jaguar item in good condition - seemed like a good price to me at least. With all of the really big jobs completed on this car, the list of outstanding work now contains items like 'stereo' and 'make windows roll up quicker', 'make central locking work on passenger door consistently'. Generally speaking everything left that I want to do with this car should be easy enough to chip away at when time allows, rather than needing weeks off the road with major subassemblies stripped down, which is what was required to get to this point. The plan now is to press it in to service as my dry weather daily driver, go to a few events with it over the spring and summer and continue to improve it and then sell it on and buy something else with a Jaguar or Daimler badge on it. Something a bit older wouldn't go a miss, a Daimler DE27 would be lovely but I don't think my budget is going to stretch that far. There is an old Rover P3 at the MOT garage that is in many pieces, that also could make a good project if I could negotiate a good price for it. In other car related happenings, the XJR is still going strong and I think I am going to invest in repairing the air conditioning. I currently don't have a car on the road with working air conditioning, which is soon going to make for uncomfortable motoring, especially now my usual commuting routes are back to pre-covid levels of traffic and queues! I will leave you with a picture of my latest wheeled acquisition, a Pashley Roadster Sovereign which was going for a good price on eBay locally. I bought it to try to make cycling more a part of my regular routine (my other push bikes are all a bit too flash to be left in town or in the bike sheds at work) so I have been cycling this thing to the shops and other local errands and have already managed to clock up something like 300 miles and it has been great fun, it has reinvigorated my love of cycling so hopefully I'll keep this up and won't be so chronically unfit after a few months! So there we are, next update will hopefully be a picture show of all the places that the Daimler has taken me to. Hope everyone is keeping well. Good bye.
Last Edit: Apr 25, 2022 21:01:43 GMT by Flynn
