betenoir
Afraid of the Light
Aug 24, 2021 22:00:18 GMT
Before fitting the front brakes, I wanted to get the Ibiza up on the scissor lift. As the lift operates on the sills, this meant that the side skirts had to come off. In all honesty, I am not sure why the side skirts had remained on all of this time, as I had always thought the car would end up without them. Once I had decided they had to go, and despite not managing to get a single one of the fixing screws undone, they both came off pretty easily. With the side skirts out of the way, and 23 years worth of dirt cleaned off the freshly exposed sills, I slid the lift under the car and started lifting it up in the air. The lift is designed to be used to lift two wheels while the others remain on the ground. With my Caddy, I positioned the lift so it was touching the front tyres, but even so when I raised the lift it was the rear wheels which came off the ground, due to their being no weight at the back. To get the front to lift first I had to put quite a bit of ballast in the pick-up bed. The Ibiza lifted in just the same fashion, but finding space for sufficient ballast in the back was more of a challenge. Once I had got the front to the desired height, I lifted the rear on a trolley jack and put some stands under the back of the sills. The front brake discs are mk4 Ibiza parts which I had drilled to 4x100 PCD from 5x100. This means that the holes for the disc retaining screws no longer align with the threaded hole in the hub, but the new bolt holes are tighter than the standard holes to keep the discs centralised. The mounting holes for the brake callipers in the hub carriers were in a bit of a state, to the extent that initially I thought I had the wrong bolts. I did not have a tap of the right size, but I managed to clean the threads using some spare bolts which I greased then wound in a half turn and back a quarter turn until they were through. It seemed to take ages but the actual calliper bolts went in a treat afterwards. Brake hoses provided the next challenge. As I mentioned previously, I had ordered a 'complete' kit of braided hoses for the mk2 Ibiza from Goodridge, although a quick look at the unions on the mk4 callipers would have told me they were never going to work. I then ordered some mk4 Ibiza hoses, from HEL this time, on the basis that if they did not fit my Ibiza they could always go on my son's mk4 Ibiza Cupra. Obviously the calliper end fitting was fine, and the length was good too, but the fitting at the inner wing end was wrong. Now I knew the length required I ordered bespoke hoses, from HEL again, which are essentially mk4 Ibiza Cupra hoses but with a mk2 ibiza spec fitting on the inner wing end. I also got them to fit a single bolt mounting rather than the standard grommet style mounting. In the photo, all three hoses have the calliper end at the bottom, and they are L-R mk2 Ibiza, mk4 Ibiza, and custom. It was only once I put the brake pads in that I realised I was short of 'fitting kits' for the front callipers. I had pad retaining pins, and some anti-rattle springs which proved to be too wide, as apparently the AP CP-6600 callipers are available for different disc thicknesses, and as well as the smaller anti-rattle springs I also needed pad retaining bolts and 'retainer pads'. Fortunately, as AP Racing callipers are widely used in motorsport the spares are readily available, but the downside is that they are not cheap. The contents of the bag in the photo cost me £80! The cost was soon forgotten once I put it all together. The callipers are pretty hefty, so that I have to fit 17" wheels, and even those only clear with 20mm spacers fitted. I could not resist a trial fit just to have a look.
betenoir
Afraid of the Light
Sept 14, 2021 21:40:12 GMT
Warning! This post is all about wheels, and lots of them :-) When I had my previous mk2 Ibiza 1.8T running, I had a set of 17" Oz F-1 wheels refurbed for track use. They looked the business with Oz Racing and SEAT Sport decals in yellow and with carbon centre caps. Since I took that Ibiza off the road, these wheels had been stored in my rented lock-up. When I went to collect them to go on this Ibiza, I was horrified to find that something had leaked onto them and damaged the paint. The wheels had been stacked on top of each other, so the one at the top was the worst, but none had survived unscathed. I was able to effect a repair on three of the wheels with some wire wool then brush painting of primer and colour coat. Replacement decals were applied after this picture was taken. They are by no means perfect, but plenty good enough for track wheels. The worst one of the damaged wheels had to be professionally refurbished, so as I was going to Wheel Works I thought I may as well make it worthwhile, so I took in four other 17" Oz F-1s which I had acquired in various states to be done at the same time. The AP brakes I now have on the front of the Ibiza mean that I can no longer fit the 16" wheels that I used to fit on my previous track Ibiza. I did consider running 16"s on the back and 17"s on the front, but I then found a few more 17" wheels so that is no longer necessary. Consequently I had some 16" wheels which I no longer have a use for. Nine Oz wheels (in two batches) plus two 13" Scirocco wheels I listed at the same time fetched just £5 short of what the refurbishment cost, which made it feel like it had been done for nothing. Hopefully I can sell the remaining four 16"s to help pay for tyres! My love of Oz F-1s started with some offered as an option on SEAT mk1 Leons. Several years back I asked Wheel Works to match the gunmetal colour of these SEAT Sport wheels, and they (not unreasonably) sent me away with hundreds of colour swatches and instructed me to find a match for myself. The shade I settled on was VW LA7Y, and I have lost count of how many wheels I have had painted in that colour since Freshly refurbished wheels are things of beauty, in my opinion at least, and Wheel Works did their usual high quality work. The blue around the rims without tyres is just tape used to protect them for transit. The decals for the refurbished 'track' wheel (on the right) are not an exact match for those on the other three wheels in that 'set', but they are close enough that I will probably be the only one who ever notices. On the 'other' wheels I have just put Oz Racing decals but not SEAT Sport, at least for now.
Last Edit: Jun 5, 2022 15:40:35 GMT by betenoir
betenoir
Afraid of the Light
Sept 30, 2021 21:28:47 GMT
Much earlier in this thread I mentioned my DTM style door mirrors. A few months back I had a clumsy moment in the workshop, which resulted in the nearside mirror being knocked-off the door, and hitting the floor. The impact with my shoulder broke-off the mounting lugs from the base-plate, and then hitting the floor broke the corner off the base-plate itself. The sorry remains went in a box while I searched in vain for a replacement. Eventually I had to admit defeat, and get the araldite out. My first attempt at gluing two of the mounting lugs was a dismal failure, resulting in my having to snap the lugs off again and attack the glue residue with the Dremel. Thankfully the second attempt was more successful. The third mounting lug must have been missing when the mirror was fitted, but I was able to replace that with an M6 threaded coupler bolted through from the mirror mounting face. To make some clearance for the head of the bolt holding the coupler in place, I had to drill a hole in the mounting face of the mirror, but as they are manual mirrors which mostly contain fresh air this was not an issue. Once reassembled and back on the car, the repairs are barely visible.
Last Edit: Oct 16, 2021 21:14:13 GMT by betenoir
betenoir
Afraid of the Light
Oct 16, 2021 21:20:15 GMT
The OMP steering wheel I had fitted to this Ibiza had been in my previous Ibiza track car. The wheel is dished by around 65mm, and in combination with a steering boss that is about 100mm long the driving position was not ideal. In the other Ibiza I modified the seat sub-frame so I could get the seat lower and further back, and that worked OK, although it was a fairly drastic solution, and it still left the control stalks an uncomfortable reach from the steering wheel. For some time I had been looking for a similar wheel but with a lesser dish. I wanted a decent quality one, but I was not keen to pay ~£170 for a new wheel. Eventually I found another OMP wheel which appeared to fit the bill. This one has just a 25mm dish, and along with a shorter boss I succeeded in getting the wheel rim significantly closer to the indicator and wiper stalks. When I subsequently tried-out the driving position, expecting to be basking in my success, I quickly realised I had been too successful, and had created a new problem. The wheel was now too close to the stalks, so that I would probably be forever inadvertently operating the indicators and wipers. This was easily resolved with a 20mm spacer. The replacement steering wheel boss has another advantage over the old one, in that its slip-ring engages with the contact for the horn push, so that is now working too. The diameter of the new wheel is 300mm, rather than the 350mm of the one it has replaced. This may yet prove to be too small, but that will be an issue for another day.
betenoir
Afraid of the Light
Apr 15, 2022 23:23:29 GMT
Fitting the handbrake cables should have been a straightforward job. I had bought new genuine cables, and as the brake callipers are standard Ibiza 6K (albeit possibly mk3 Cupra) I was confident I had been supplied the correct parts. Although the Ibiza had been in pieces for many years, and its component parts had been scattered all over the place, I had been pretty good at organising and labelling them, and nothing had irretrievably gone missing, until I came to need the handbrake cable guide tubes. There is no way I would have thrown them out, but I have failed to locate them despite searching extensively. As I have two other mk2 Ibizas I did not think this was a major problem. My Super 6 ex rally car has no handbrake cables fitted, so the guide tubes were easy to remove, and it was almost as easy to fit them to this Ibiza with it being up on the lift. Once the cables were fed through the guide tubes and connected to the handbrake lever, I was very surprised and disappointed to find that there was insufficient adjustment on the cables to operate the handbrake. I struggled for days to figure out why. My first theory was that the rear brake callipers had been reassembled incorrectly, such that the handbrake operating levers were not aligned as they should be. This seemed unlikely as they were professionally refurbished by a reputable specialist, and on closer inspection I could not see how this could be possible. I needed another theory, but none was immediately forthcoming. Finally it came to me. If the Handbrake cables are right, the brake callipers are right, the handbrake lever is standard, then the only other component that can alter the operating length of the cables is the guide tubes. With my Super 6 being an ex rally car, what is the likelihood that the handbrake was completely standard? I found an eBay seller somewhere in Eastern Europe who had both right and left guide tubes new, so I ordered some. When they arrived, a quick comparison readily confirmed my theory: the guide tubes in the Super 6 had been cut-down. The new parts were swiftly fitted, and proper handbrake function was restored.
Last Edit: Apr 16, 2022 9:22:02 GMT by betenoir
betenoir
Afraid of the Light
Apr 23, 2022 20:27:27 GMT
The front mount intercooler makes it impossible to fit a standard front bumper. On my other 1.8T mk2 Ibiza I had solved this problem by getting rid of virtually everything behind the outer skin of the bumper, and by replacing the grille slats with aluminium mesh. I liked the look of it, but the bumper became very flimsy and was not attached particularly securely. Starting with the green Ibiza's standard bumper, and with the previously modified bumper as a pattern, I set to work with the Dremel. I did much Dremeling, followed by trial fittings, followed by yet more Dremeling. By the time I had finished it looked like this: In the photo above, the aluminium mesh to cover the enlarged apertures has been cut to size but is held in place with a couple of cable ties. This was then permanently fixed with screws which will be concealed when the bumper is fitted, and with rivets which will be visible. As can be seen in the next photo, I have ended-up with only the skin of the bumper again, no more rigid than what I had on the black Ibiza. I did however have an idea how to make it more secure on the car. Fitted on the car, I am really chuffed with how it looks. On the black Ibiza, the bumper was held in place just by two screws at the top, and by a couple of cable ties at the inner wing edge. Then as now the mountings for the bottom two mounting screws had been removed. On this Ibiza, I have re-fitted the wheel arch liners and undertrays, and replaced the multiple screws which attach the bumper to them. It feels much more solid, without having to resort to cable ties this time.
betenoir
Afraid of the Light
Apr 28, 2022 21:18:17 GMT
With the front bumper modified and on the car, it struck me straightaway that I ought to modify the top grille to match. This was an annoying revelation, as it was not a job that was strictly necessary to get this Ibiza back together and on the road, but once I had seen the need, I could not unsee it. Resigned to the extra effort, I fetched my extensive selection of mk2 Ibiza radiator grilles from my lock-up to identify a suitable candidate to be modified. I have no idea how or why I have four kiwi grille surrounds. On checking each of them, I found that all but one was damaged. The ends of this panel are held in place by 'captive' square-headed bolts which push into clips in the panel ends. The plastic becomes brittle with time, the clips break, and the square-headed bolts are captive no more. As luck would have it, the only one of these grille surrounds which had these clips intact was the one from which the slatted original grille was already separated. That at least saved me some time and effort. The aluminium mesh I used on the bumper came from Halfords many years ago, and the bumper had used the last of it. I managed to source some similar but not identical mesh, but hopefully I will be the only one who notices the difference. My first thought was that I would just ditch the black plastic slatted grille completely, and cover the whole aperture in the grille surround with aluminium mesh. The would have been OK, but I could not work out how to fit the SEAT 'S' badge into the middle to my satisfaction. Instead I decided to get rid of the slats from the grille but keep the 'frame' and the badge, and to sandwich a piece of mesh between this and the grille surround either side of the badge. Hopefully the photos will provide a better explanation. The standard 'naked' grille looked like this. After I had attacked the slats one side with the Dremel it was in this state. Then I (obviously) did the other side to match. I drilled-out the grille mounting lugs on the grille surround so I could use self-tapping screws through the mesh to secure it in place. The plastic chrome SEAT 'S' badge just pushed back into place, and the new grille & surround were ready to go on the car. At this point I discovered I needed to cut a little off the badge surround at the back, because the mesh pushed it closer to the front panel around the bonnet catch, but this was easily resolved. Throughout this lengthy build, I have been contemplating what badges to put on the Ibiza. This was originally a GTi 16v and would have been badged accordingly. This car did not have a grille badge when I bought it, although it does (currently) have the original badge on the tailgate. I considered getting some GTi 1.8T or GTi 20VT badges made, and I might yet do that. For the time being, at least, I have fitted a simple GTi badge which would have been standard on an 8v GTi Ibiza. I was able to trim the clips which hold this badge to the slatted grille so that they will hold it in place in the new mesh grille. After looking at this picture I realised that the badge is actually in the wrong place. The next evening I went back out to the workshop and spent 20 minutes repeatedly removing, re-locating, and re-fitting the badge until I had convinced myself that it was as close as it could be to the original position. There that is miles better!
Last Edit: Jun 5, 2022 15:56:21 GMT by betenoir
betenoir
Afraid of the Light
May 10, 2022 20:51:08 GMT
Sorting the fuel pump has been somewhat of a saga. Even in the context of the rebuild of this Ibiza stretching over more than ten years, the fuel pump still qualifies for that description. Over the early years of my ownership of this car, I acquired loads of tuning parts, taking advantage of the fact that I was years off trend and was only starting to build my 1.8T mk2 Ibiza when everyone else was breaking theirs. One of the parts I bought was a mk2 Ibiza fuel pump and fuel tank sender assembly, with the pump itself replaced with a mk1 Leon Cupra R unit. This had been patiently waiting for its turn to be fitted, until I got a phone call from an old friend. His VW Lupo GTi had broken down as a result of its fuel pump failing. Knowing I had a stash of VAG parts, he asked if I had a pump to get him going again. We looked through the four or five pumps I had, but the only one which visually resembled the Lupo part was the one earmarked for my Ibiza project. I did not yet need it myself, so I let him borrow it. I assumed it was only needed to get him home and he would replace it with a new one as soon as he could, but that was not how it turned-out. It was a couple of years before I was ready to pay any attention to the Ibiza's fuel pump, and in the meantime it behaved faultlessly in the Lupo. When I asked him for it back, it did not even inconvenience my mate particularly as his Lupo was off the road due to engine issues. He posted it back to me, and I fitted it where it was always supposed to go. Sadly, within a very short time, it was clear that all was not well with the pump. With the ECU and engine loom having been made by myself, I have not yet come to accept that I may have done a decent job of it, so I always look to discount a problem with the wiring before I assume any fault with a component. In this case, I wanted to check that the fuel pump control may have gone awry. I decided to investigate this by making a test lead to go between the fuel pump and its electrical connector on the loom, and including an LED to indicate when there is power to the pump. The test lead quickly confirmed that there was power to the pump, but it was clearly not running. Time for a new fuel pump. A few years back I had a Mitsubishi Evo VIII. It was mapped to 350bhp, and the fuel pump was uprated to a Walbro unit to support that. Having had that good experience previously, I decided that a Walbro was the right way to go for this Ibiza. I found and ordered a Walbro kit specific for a VAG 1.8T, which arrived within a couple of days. When I unpacked it I was surprised to see that the new pump was significantly smaller than the original, but the kit included a rubber sleeve and spacer to enable the smaller pump to fit correctly into the Ibiza cassette. At this point I did not fully understand the full function of the pump cassette, and I found details online of builds using the Walbro in the same way as I was, so although it did not look quite right I was reassured it was OK. With the new pump installed, the problem that had caused it to be bought was resolved. Despite the engine running fine, I could not set my concerns about what had to be done to make the Walbro fit aside. A bit more online digging uncovered other folk with similar concerns, and explained that the standard VAG fuel pump cassette provides swirl tank functionality, but that this is lost when the Walbro is used. As my Ibiza is intended for track use, having the fuel pump taking big gulps of air in corners is a very bad idea. The Walbro was going to have to go :-( I recently had problems with the fuel pump in my 1.8T Caddy, and JKM recommended a Deatschwerks DW65v. I had not previously heard of Deatschwerks, but I trust Jim at JKM, so I ordered another DW65v for the Ibiza. Before it arrived, I dismantled a couple of pump assemblies to select the best parts for the new pump. Both of the fuel senders looked the same, but I used my instrument panel test rig to check that they were compatible with the Ibiza's fuel gauge. It was a good job that I did, because one of them had the opposite polarity to what I need. I would have been so annoyed if I had only found that out after I had assembled the pump and fitted it into the car. Having selected all the components I intended to use, I gave them a good clean, and arranged them all neatly to await the new pump. The pump in this picture is the original, with O-rings left in-situ so I can see how they need to be located for reassembly. When the new pump arrived, it was physically a good match for the original. It came complete with a convoluted fuel hose, hose clips, and new O-rings. Being of the same dimensions as the original, the Deatschwerks pump was a doddle to fit inside the swirl tank. Convoluted hose and fuel level sender in place. Top cover fitted, and hose connected to it. I disconnected and rearranged the wiring a few times after this photo, for no good reason apart from the fact that I cannot help myself with wiring. Return hose in place. The returned fuel goes back into the swirl pot, and the pump is able to scavenge fuel from there through a hole in the side, as well as drawing 'fresh' fuel in through the strainer at the base. The return hose is specified to be good for in-tank applications, but I have now also found a decent source for convoluted hose so I will check on the pump in a few months and if I do not like the look of this hose I will replace it. One (the only?) advantage of my fuel pump woes having become a saga is that I am now quite well practised at removing and fitting the assembly from and to the fuel tank. It was a task I used to dread, and which would sometimes take a while. Now it is a five minute job. Once completed, the engine came to life as it should.
Last Edit: Jun 5, 2022 15:53:59 GMT by betenoir
