Hello,
Up for Sale is my Mercedes-Benz CLK 320 V6.
The car comes with FSH and a fresh 12 Month MOT. There have been just two previous owners: the first having owned the car from new until 2017. The second owner had the car for a bit over a year, until I bought it in August 2019.
I’ve owned this car for just over a year and it has been very reliable during this time. (Selling because I have bought a new car)
Car specification:
2001 face-lift model (underwent revised manufacturing process, less prone to corrosion)
M112 3.2 V6 Engine (Classic and Reliable engine producing 220PS and 320NM)
ULEZ Compliant
Black Leather Interior
Electric Front Seats
Dark Wood Pack
Air Conditioning (Ice-Cold)
Central-Locking
Pneumatic Boot Release
Electric Windows
Traction Control
Collapsible Rear Head Rests
The previous owner of this car was an enthusiast, and performed an extensive maintenance overhaul. There is a huge Folder of receipts, filed in chronological order.
A summary of the work undertaken is below:
FSH with regular Servicing from main dealer and specialists
Blueprint ADL Fuel Filter Kit
Bosch Spark Plugs x12
Bosch Cabin and Air Filters
MBZ Breather System Rebuild - including all pipework and connectors
Cam-cover breather box re-seal (common M112 issue)
Mannol AG13+ premium long life Coolant change
Borg and Beck Coated Front and Rear Brake Discs
Mintex Rear Brake Pads
Full Brake Fluid Change
Fuchs Sintopoid 75W85 DIff Oil
Mann Transmission Oil FIlter Kit
Fuchs 4134 MBZ approved transmission fluid (236.14 spec)
MBZ transmission loom plug / seal kit
Genuine AMG 17” staggered wheels (could do with a refurb)
225/45/17 Kumho UHP PS71 front tyres
245/40/17 Kumho UHP PS71 rear tyres
Sparco hub centric 16mm rear wheel spacer kit with extended wheel bolts
Mtec hub-centric 10mm front wheel spacer kit with extended wheel bolts
Delphi front upper wishbones
Front lower ball joints
MBZ front anti-roll bar bush kit
Febi-Bilstein steering damper
Mapco centre steering drag link
Mapco track rod ends
Sachs / Boge Sport specification shock absorbers with new mounts / securing bolts
Supersport uprated and progressively wound lowering springs
4 wheel laser wheel alignment
As is evident from this list, the car has been well maintained, and drives well.
However, there are a couple of minor issues the new owner would probably want to remedy at some point:
- Slight Oil Leak
- Exhaust blows a little (due to corroded exhaust clamp)
- ABS Sensor may need replaced (ABS light sometimes flicks on at high speeds when going over a bump in road etc.)
Cosmetically the car is generally clean, although as shown in the pictures, a few of the arches are beginning to bubble with rust as is typical on cars of this age.
However, this CLK is solid underneath, and does not seem to have suffered from corrosion issues at all (Jacking points, sills, Floor Pan are all rust free)
The front bumper has a small crack on the lower diffuser section (as shown in picture) - could replace the front bumper or respray the existing bumper.
The car is located in Alnwick, Northumberland. (NE66)
£1500 ONO
Car specification:
ULEZ Compliant
Dark Wood Pack
Central-Locking
Electric Windows
Traction Control
- Slight Oil Leak
£1500 ONO
