hopeso
Oct 16, 2020 11:19:07 GMT |
Hi, A question for those who know about these things.
I have a new battery for a grass trimmer that won't take a charge. It is new so should work.
Can these be successfully dismantled and fixed?
hopeso
Oct 16, 2020 11:20:03 GMT |
Oct 16, 2020 12:48:09 GMT |
If you know your charger is good...... then this suggests the battery is either defective or too flat for the charger to recognise. Neither is great for a new battery so claiming warranty is probably the correct path.
However, if it’s “only” flat (and you should be able to establish this with a simple multimeter) you may be able to wake it up enough to get the charger to see it by applying something close to its rated voltage too it for a short while.
Nick
1967 Triumph Vitesse convertible (long term pet) 1999 Audi A8 2.8 2WD FL Winter banger 1996 Audi A6 2.5 TDI Avant (still durability testing) 1972 GT6 Mk3 (Restored & learning to be a car again reluctantly!)
Oct 16, 2020 17:35:14 GMT |
Hi, Be aware they do need a carefully controlled charge voltage otherwise they can burst into flames. Remember the hoverboards? That was down to charging problems.
Colin
