Dez
Club RR Member Number: 34
Jan 26, 2022 20:17:38 GMT
Sealer and paint- ![](https://uploads.tapatalk-cdn.com/20220126/cf412ad97da59193ba8be84f7f746265.jpg) You’ll see I also refitted the crash bar at the front to check allignment. All good. ![](https://uploads.tapatalk-cdn.com/20220126/a196e1aa8634a37cf49c5b5d55d0ce4c.jpg) The next step was another deep breath and lay into the sill and step. This was standard transit fayre. ![](https://uploads.tapatalk-cdn.com/20220126/6ec118a98c9bd982614588bd804be00e.jpg) ![](https://uploads.tapatalk-cdn.com/20220126/b207f611067e04c8792d0ef54ffd4885.jpg) ![](https://uploads.tapatalk-cdn.com/20220126/545446d9c19f11ed264d0f9f0604ddcb.jpg) ![](https://uploads.tapatalk-cdn.com/20220126/4208455ded3f59e3bb8132b9da3ad106.jpg) Another massive hole. I’ve cut the floor edge back similar to the other side, then taken the whole step out. I’ve also unbolted the seat box to get it out the way. ![](https://uploads.tapatalk-cdn.com/20220126/ef5b6a7b8b4727c6c3e313b5bbafa8a3.jpg) After a lot of hacking away I got back to the crossmembers. The rear one needed just a flat patch the same as the other side. ![](https://uploads.tapatalk-cdn.com/20220126/1c5ea0160428eef686aeb82284ce25e0.jpg) The front one I remade entirely, also like the other side. The template had to be tweaked as it’s a bit different because of the cubby hole for the Jack. The back upright had to be shortened. Oddly the angle where it meets the chassis is different but I didn’t find out til after and it was offered up, so I had to cut and weld that bit. ![](https://uploads.tapatalk-cdn.com/20220126/b45e749e95bfbc4f6748e3b76b3f317c.jpg) ![](https://uploads.tapatalk-cdn.com/20220126/8eec0baafd26f09c169979e6cad892cb.jpg) The step had that overlap panel on the back the same, so that was removed. ![](https://uploads.tapatalk-cdn.com/20220126/b9f42bb9cda88c7202beba5345171e7e.jpg) I cant weld all this lot in just yet, it needs aligning to other things, but it’s all made and ready to go.
Jan 27, 2022 11:22:36 GMT
Lol, was that sill just squirted full of expanding foam and Chemical Metal?
Dez
Jan 27, 2022 11:39:13 GMT
Lol, was that sill just squirted full of expanding foam and Chemical Metal? It was squirted full of expanding foam (as was the arch) to give the filler and underseal something to sit on to bridge the massive hole 😬 I knew about that bit when I bought it, hence me already buying the panels for that area. Tbh Ford themselves like to use expanding form to bridge big gaps to then put seam sealer over though!
Jan 27, 2022 13:40:16 GMT
Wow….. epic structural repairs. Not quite sure why the front end hadn’t just folded up….
The old truck certainly got lucky finding you! Wasn’t long for this world otherwise…..
Nick
Dez
Jan 27, 2022 19:33:55 GMT
Wow….. epic structural repairs. Not quite sure why the front end hadn’t just folded up…. The old truck certainly got lucky finding you! Wasn’t long for this world otherwise….. Nick Well, nothing in front of the engine crossmember really does anything. The front 18” of chassis rail holds up nothing other than the bumper crash bar and the rad, and I’ve seen them with the crash bar missing altogether behind the bumper skin! The inner wing sections and lower splash panels do pretty much nothing either, apart from hold up the airbox on the drivers side. It’s easy to ‘keep them going’ year on year with blastover patches and rudimentary bits of tin in place of the original stuff. You’d be surprised how many transits out there are actually like this, what is MOT passable can be pretty shoddy tbh, and as long as you replace the front wings when they go they still look presentable from the outside.
Jan 27, 2022 19:55:05 GMT
Hmm, surprising! Looks pretty scary to me! I’m looking at a 2002 transit camper van (conversion) shortly with a view to buying ….. so I’ll bear this in mind!
Any tips for getting them going when they’ve been run out of fuel? Apparently it’s being very stubborn and the internet says it’s a thing with them….
Nick
Dez
Jan 27, 2022 19:58:03 GMT
Hmm, surprising! Looks pretty scary to me! I’m looking at a 2002 transit camper van (conversion) shortly with a view to buying ….. so I’ll bear this in mind! Any tips for getting them going when they’ve been run out of fuel? Apparently it’s being very stubborn and the internet says it’s a thing with them…. Nick It’ll be rusty somewhere. They all are. To get it going again pressurise the tank with an air line and a rag. Cap off, rag wrapped around airline and stuffed in the neck to get it to seal. Then crack the injectors as someone else is pulling the airline trigger. Tbh, if it’s been run dry don’t expect the pump to last, it knackers them.
Jan 27, 2022 20:09:59 GMT
Thanks. That last bit is a worry….. Pretty sure he said it had been running since he ran it dry but it “lost its prime” again after a few weeks standing. That might just be because someone didn’t do something up after bleeding last time or because the pump is hurt…. Bargaining point anyhow.
Nick
Davey
Resident Tyre Nerd.
Jan 28, 2022 16:43:31 GMT
Thanks. That last bit is a worry….. Pretty sure he said it had been running since he ran it dry but it “lost its prime” again after a few weeks standing. That might just be because someone didn’t do something up after bleeding last time or because the pump is hurt…. Bargaining point anyhow. Nick Screams hurt pump with one of these unfortunately...
Dez
Jan 28, 2022 17:34:16 GMT
Thanks. That last bit is a worry….. Pretty sure he said it had been running since he ran it dry but it “lost its prime” again after a few weeks standing. That might just be because someone didn’t do something up after bleeding last time or because the pump is hurt…. Bargaining point anyhow. Nick Screams hurt pump with one of these unfortunately... Yep. £800 for a pump last time I checked. That was pre-covid when such a cost would write the van off, not sure if they’ve gone up but I expect they will have with the cost of vans going nuts.
Dez
Jan 28, 2022 21:39:11 GMT
It was obvious the inner A-pillar/spring pocket area needed the same attention as the other side, so I cut that off high up above the lower hinge as I did before. This side all went a lot quicker as I was familiar with the construction, what it should look like, and how I made the other panels. ![](https://uploads.tapatalk-cdn.com/20220128/3d911260727a90c591079aef2f4d1dab.jpg) ![](https://uploads.tapatalk-cdn.com/20220128/abe07e8ecab662af94e5b72852760327.jpg) There was actually a little more left to template from on this side, but it was still a mess. I’ve had questions fielded elsewhere about how I go about picking stuff like this apart. Decent spotweld drills and a good thin bolster chisel are essential. The cut lines are marked and cut through just the one skin I’m working on, the spotwelds marked and drilled, then it should only take a light tap if anything to pop them. Time consuming but the only way to do it when you need the original piece as a template. ![](https://uploads.tapatalk-cdn.com/20220128/70903cbb58702ded21296365d7d4771b.jpg) A while later and the replacement is made. It’s not a massively complicated panel, as long as you cheat. ![](https://uploads.tapatalk-cdn.com/20220128/0bf9275faa89c03c522af1c5a46f75cc.jpg) ![](https://uploads.tapatalk-cdn.com/20220128/f5dad67ec4adb4ef480ce27845c4eb18.jpg) There’s no point trying to be all clever and make it in one and bring that edge over and then shrink it down. Just make it straight, cut it, shrink the flange on the shrinker/stretcher til it’s the right shape then drop in a filler piece. By the time it’s dressed back no one would ever know. ![](https://uploads.tapatalk-cdn.com/20220128/ddd241076ff2f38b1b0f27d634809004.jpg) It was then offered up and trimmed, and the location of the mating faces drawn on from the back so I can mark out and drill for replacement spotwelds. ![](https://uploads.tapatalk-cdn.com/20220128/e9a8164bf4af0e30bdb921b1119eafed.jpg) ![](https://uploads.tapatalk-cdn.com/20220128/2ff5659bc6d0b6dd1c06a307b88a757d.jpg) ![](https://uploads.tapatalk-cdn.com/20220128/be9384e71e7e3bac9e3355b8b7c01c64.jpg) Then the outer. I had to replace a lot do this as it was quite pitted between the two skins. ![](https://uploads.tapatalk-cdn.com/20220128/669c31515e3d2da2cb9d1d3bf384dce6.jpg) All this was cut out- ![](https://uploads.tapatalk-cdn.com/20220128/6a5957ac0b235515d454b0e9be3fc563.jpg) Outer skin was a similar story. ![](https://uploads.tapatalk-cdn.com/20220128/27d9eb748b1779c25648faae9c77a588.jpg) Reassembled and smoothed out- ![](https://uploads.tapatalk-cdn.com/20220128/850e025f794ad1519082985fc4dc3e45.jpg) Then the inside of both were painted before they got stuck back together. ![](https://uploads.tapatalk-cdn.com/20220128/54b7d3217be7c89ea28f99beeeb69247.jpg) ![](https://uploads.tapatalk-cdn.com/20220128/c895b8205e53cff719d39da50c211611.jpg) After a grind up, that was another section completed.
Last Edit: Jan 28, 2022 21:41:42 GMT by Dez
Jan 28, 2022 21:52:18 GMT
Classy work as usual 🙂
Nick
jimi
Good to see you use quality protection ear defenders ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) Too many people use nothing or poor quality defenders / ear plugs, which they will regret later in life I used those Peltor Optime's for many years offshore. Working in engine rooms next to V16 Detroit's and supercharged EMD's you quickly get to know which defenders are good ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Black is not a colour ! .... Its the absence of colour![](https://jlawson.co.uk/images/Jimisig04.jpg)
I'm deeply impressed, Sir!
I would have worried a lot to remove the door fitting holes.
Did You somehow test that without having to re-fit the heavy door?
Impressive work Dez. Never thought I would be interested in a Transit!
Jan 29, 2022 10:19:42 GMT
I can only repeat what others have said....fantastic work 👍.
Its also great to see someone other than myself putting so much time and effort into an old commercial....it makes me feel sane 😁. I would image you're thinking along the same lines as me, in terms of knowing that you're going to keep the vehicle long term and having peace of mind that everything has been done properly and is going to last!
Opel Commodore A Coupe Opel Rekord C Coupe Opel Rekord C Saloon Vauxhall Magnum Coupe V8 (Magnumania) Mk1 Scirocco GLS Mk1 Scirocco GLS (early chrome bumper) Corrado G60 Mk1 Cortina 2 door Pre Airflow Mk2 Escort 1300 2 Door VW LT35 Tipper Truck BMW 320D E91 Tourer
Dez
Jan 29, 2022 17:59:58 GMT
Good to see you use quality protection ear defenders ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) Too many people use nothing or poor quality defenders / ear plugs, which they will regret later in life I used those Peltor Optime's for many years offshore. Working in engine rooms next to V16 Detroit's and supercharged EMD's you quickly get to know which defenders are good ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Yeah good ear defenders are something I’ve always had ever since I was given my first pair of peltors at 12, the first time I went shooting. I don’t like using power tools without them on really. Well maybe a drill bit certainly not a grinder.
Dez
Jan 29, 2022 18:02:10 GMT
I'm deeply impressed, Sir! I would have worried a lot to remove the door fitting holes. Did You somehow test that without having to re-fit the heavy door? With how and where I cut it I had strong references so it couldn’t move in any direction. A nice neat cut and you can just gap the cut and weld it up again after. With a little thinking you don’t have to worry about taking measurements on a lot of stuff.
Dez
Jan 29, 2022 18:03:08 GMT
Impressive work Dez. Never thought I would be interested in a Transit! Tbh I’m rapidly losing interest in doing it as this side is very much rinse and repeat, the only thing keeping me pushing on is my need to use it!
Dez
Jan 29, 2022 18:04:40 GMT
I can only repeat what others have said....fantastic work 👍. Its also great to see someone other than myself putting so much time and effort into an old commercial....it makes me feel sane 😁. I would image you're thinking along the same lines as me, in terms of knowing that you're going to keep the vehicle long term and having peace of mind that everything has been done properly and is going to last! Yeah that’s it really. I need it to do some specific things in the short term which is why I have it, but knowing it’s good and solid means I’ll probably hang onto it long term unless someone waves daft money at me or it’s getting in the way too much.
