bstardchild
Club RR Member Number: 71
Well, if it ever stops pi$$ing it down, I might get back on with this now I’m back at work. In a brief break in the deluge, I did mock up for how 10ft ramps will fit and work. Here it is sat on the back of the bed. The angle doesn’t currently match, but it’s not meant to. The idea is as you pull a car on and the weight sits on the ramps it all levels (or unlevels I guess) out and you get a straight run. Of course I won’t be able to fully test that til it’s all done, but by eye it looks about right. I'd trust your eyes for that sort of thing every day of the week and twice on Sunday over a full set of engineering calculations
LowStandards
When we build beds, we like to use C-section steel along the outer edges, makes for a nice strong edge and is also a place to hide your side markers from damage. I also detest ally beds, this one was specced by the traveller, but was soon replaced with steel due to damage. But then, these are trucks used daily dragging all manor of broken and overweight wibblepoo on.
Dez
Club RR Member Number: 34
Jan 21, 2021 20:15:23 GMT
That's the kind of corner I'd keep walking into and bashing my hip - well worth the effort That’s a consideration actually. It’s about hoody pocket height and I rip them out on stuff all the time.
Dez
Jan 21, 2021 20:16:15 GMT
Well, if it ever stops pi$$ing it down, I might get back on with this now I’m back at work. In a brief break in the deluge, I did mock up for how 10ft ramps will fit and work. Here it is sat on the back of the bed. The angle doesn’t currently match, but it’s not meant to. The idea is as you pull a car on and the weight sits on the ramps it all levels (or unlevels I guess) out and you get a straight run. Of course I won’t be able to fully test that til it’s all done, but by eye it looks about right. I'd trust your eyes for that sort of thing every day of the week and twice on Sunday over a full set of engineering calculations It’s slowly working it way down as I add weight to it. I reckon it’ll be Bob on by the time I’m done 😆
Dez
Jan 21, 2021 20:17:30 GMT
When we build beds, we like to use C-section steel along the outer edges, makes for a nice strong edge and is also a place to hide your side markers from damage. I also detest ally beds, this one was specced by the traveller, but was soon replaced with steel due to damage. But then, these are trucks used daily dragging all manor of broken and overweight wibblepoo on. That is quite a good idea actually. Fairly weighty though I guess. I don’t plan to give mine that sort of abuse so hopefully I won’t go bashing it up.
Dez
Jan 21, 2021 20:57:03 GMT
Today was an odd day. After a daily major storm last night that rattled the windows (and everything else) all night, and covered all the roads in detritus on my trip in, I was driving along and I actually needed shades it was so sunny. I got to the workshop and not only was it sunny, it was fairly warm. To top it all off my steel turned up Shortly after I did, so today was pickup bed day. First I lobbed up the 2x1 into bits before it even made it through the door- In some ‘looking at things and thinking’ time i’d come up with these out of some 2x2 for the rear drops for the light bar area. They’re a bit complicated but you’ll see how they work as we go on. They stick out to sort of act as little bumpers. They also consolidate the slope of the end into an upright surface for the lights, hence the funny angles. They go here. You can see they also cap the ends of the main rails, and should be suitably floor proof in case I bash em. I was going to use a standard transit light bar and end caps, but it didn’t really work in either width or depth, and then I decided the ramps would need to be stored behind it, so I opted to make something up instead. The bottom rail is just 2x1. It’s put on so it’s flush with the end bed rail, so I can mount a flat upright panel behind to mount the lights to. That’s something for later though. Next I arsed around removing the bit of bow out of the main rails, and straightening a bent outrigger. The bed is now flat and level though, so I can move on with the rest of it. The next major task is some strengthening to the cantilevered rear section of the bed. This is 5 foot long so needs some additional support to tie it into the end of the chassis. First I cut these. 6mm plate, the first proper weight stuff I’ve used. The were marked up for the bolt holes on the end of the chassis rails. The bottom one had to be tapped as it’ll end up being blind. They fit here. Top edge welds to the bottom of the rails to add support. Bolts are only 8mm but they’re in compression in use so actually do more or less nothing. Square is actually being used as a measuring device for the next bit. I rounded the corners before welding them on. Then I marked up and cut these. They have a ridiculously long taper, but they’re going to as they’re level to the rails, so it’s going to be 7 degrees again. The cut is nearly 3 foot long. They go here. They’re dropped as low as they can go and still effectively bear on the chassis ends. Any lower and they won’t actually improve the situation any, only crate a weird cantilever the other way. Lots of welds. I only got one in before I had to do other stuff, but even one makes a HUGE difference to The bed stiffness, and Is one of the last big bits of ‘figuring out’ done. There’s a fair bit do donkey work still to do before it goes for blasting, but it can be done in spare moments here and there rather than in big chunks.
Last Edit: Jan 31, 2021 10:48:58 GMT by Dez
Jan 21, 2021 22:09:11 GMT
Could you bring that axle back a bit if you need to? Looks like another set of spring hanger mounting holes.
Jan 31, 2021 10:44:59 GMT
Today was an odd day. After a daily major storm last night that rattled the windows (and everything else) all night, and covered all the roads in detritus on my trip in, I was driving along and I actually needed shades it was so sunny. I got to the workshop and not only was it sunny, it was fairly warm. Are you not concerned about the chassis? thats a whole lot of weight hanging off the back of something so rotten! lol
Last Edit: Feb 1, 2021 12:58:31 GMT by HARDCORE: Remove a zillion photos from the quote
Thanks for quoting 16 photos for no benefit..
Are you not concerned about the chassis? thats a whole lot of weight hanging off the back of something so rotten! lol[/quote][/quote] That's only on the surface when they go they bulge in all the double skinned areas (much like the rails on commycoupers LT). It's amazing what these will take, those holes at the end of the chassis just behind the spring hanger are where the factory bolt about a metre of chassis extension on, then customers hang tail lifts etc off the end of that and these seem to survive daily use, Dez's bed may look a bit tail heavy but most of the payload weight will be at the front and when loaded the rear wheels of the car will also be a long way forward of the rear of the bed.
melle
South West
It'll come out in the wash.
quoting 16 photos for no benefit.. A nasty habit many on here are guilty of... Perhaps some don't know quotes can be trimmed? Or are they just lazy?
Thanks for quoting 16 photos for no benefit.. quoting 16 photos for no benefit.. A nasty habit many on here are guilty of... Perhaps some don't know quotes can be trimmed? Or are they just lazy? Thought it was getting better for this, then along comes annoyedtaxi!
Last Edit: Feb 1, 2021 11:47:32 GMT by georgeb
I think people just don’t realise that a) it’s easy enough to edit a quoted post down to just the phrase you want to reply to; b) if you want to refer to an entire post then simply responding without quoting is ok; and c) that those of us that view on mobile platforms get massively irked when a huge chunk of slow to load and data hungry pictures get quoted for no reason.
Every now and then something like this pops up and people get told/reminded, but I don’t think that there’s ever any malice in it, just that people don’t know.
Fixed. Deffo no malice, it is what it is.
GUILTY AS CHARGED!!
I consider myself suitably admonished!
For the Dez fanboys, He works out of our yard and will just say "If ya know, ya know"
bstardchild
GUILTY AS CHARGED!! I consider myself suitably admonished! You only learn from your mistakes in life For the Dez fanboys, He works out of our yard and will just say "If ya know, ya know" If I read this right - plot twist incoming
Dez
Been waiting a while to post this one, but today this happened- Selling a car like this is hard work. It mostly attracts dreamers who think they’re gangstas, but have no money. Only some clapped out 5 series or similar for swaps. The swaps and P/X list I was offered for this thing is basically a lesson in cars no one wants to buy. Eventually It went on a P/X to a local guy who knows his yanks and was super pleased with how Straight it was. So in a step that partially sideways a well as forwards, as well as some cash I now have this- It’s a 1979 1/2 ton shortbed fleetside Chevy C10. 292ci straight six, th350, 10 bolt axle. All the front end sheetmetal is brand new but for a 80-up model. It came with a full set of correct year front end panels, only needing minor work. The cab is super solid, the bed less so. Floor and one bedside are rough. The chassis and running gear is mint. Sandblasted, powder coated, poly bush everything, stainless everything. It has some parts missing, most notable of which is the windscreen. Nothing for these is that expensive though so if it doesn’t sell quickly I’ll buy up all the bits and put it together. Biggest factor for taking it as a p/x is trucks are usually a much easier sell than cars, and it’s price is lower in actual monetary terms, so theoretically a wider market. But tbh if I put it together and end up using it, I won’t be disappointed.
Rich
Club RR Member Number: 160
Square styling.. rotten bed.. needs paint.. It’s my ideal wrecker project. That I won’t ever be able to afford or build. 😂
Dez
Square styling.. rotten bed.. needs paint.. It’s my ideal wrecker project. That I won’t ever be able to afford or build. 😂 It’s ex-mil as well, to tick another ‘Rich’ box 😂
