ratty
Sept 27, 2020 15:47:31 GMT
Once upon a time an idiot (that would be me) dragged an old Mini out of a Welsh field, it didn't look too bad Mmm, maybe just a little crusty You get the picture and a freaking very long time later (12.5yrs in fact) An almost finished car, I was going to wait until it was done but I thought I'd share now before another decade goes by. We have all mod cons, 4 pot disc brakes, a heated rear window, electric windscreen washers, an alternator, illuminated rear storage bins
Last Edit: Sept 27, 2020 16:26:49 GMT by ratty
Sept 27, 2020 16:57:29 GMT
that is class
elfman
Sept 27, 2020 21:43:27 GMT
Very nice, looked a lot of work but well worth it. Well done.
Lovely! And a great image of a stretch limo reflection in the front wing! 🤣
That is a cracker!
And those wheels - from Image??
ratty
Mrbounce, they are from Force Racing, a 4.5x10 split rim Mamba with a +28mm offset. Normally they are a deeper dish 5 or 6 inch rim. After speaking with Carl he was sure he could do them so that I wouldn't need arches and still run Minifin spaced drums on the rear and Minisport 4Pot alloy calipers upfront I needed to fit 50mm wheel studs to the front and 60mm to the rear but that was an easy job to do www.force-racing.co.uk/wheels/force-racing-10-wheels/product/mamba/
elfman
They look perfect... very classy
Oct 12, 2020 16:18:51 GMT
Stunning. Rotten in the usual places at least! Force do a lovely split rim wheel based on 1100 Special / Sprite exactons.
Last Edit: Oct 12, 2020 16:20:18 GMT by exuptoy
Oct 12, 2020 20:54:16 GMT
Yeah thats lovely and the best colour for a mini too!
alecf
Oct 23, 2020 13:35:29 GMT
that is lovely, worth the 12 and a half year wait
Nov 19, 2020 21:46:45 GMT
What...12.5 years? Not that long then. My Mini is still not finished after 19 years! I was on Mini Mag and said in 2 years and my better half said 9 years. This year was that 9th year. It is road legal, taxed and drivable. I'm ironing out teething problems, then get it painted. So you done very well.
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
Nov 20, 2020 14:36:08 GMT
That has turned out really nice
ratty
Nov 23, 2020 18:46:38 GMT
I appreciate the kind words, makes it worth the effort Under bonnet specs 1046cc 10.5:1 comp ratio MD266 cam Balanced bottom end Lightened flywheel Ported 12G295 with large valves 1.3:1 rockers Offset keys for timing HIF38 Carb with AAU needle CSI 23/25D Electronic distributor RC40 Exhaust Remote gearbox casing with A+ gear set Gratuitous port shot
Nov 23, 2020 22:14:23 GMT
Nice looking resto, though I must admit, I quite like the look of the original wheels & trims.
What engine did you start off with, 850/998/1098cc?
ratty
The original engine was 3/4 of a 850 as piston 3 had made a bid for freedom, I sourced a pre A+ 998 block to build the 1046 so it was in keeping with the period
Duggy
Nov 25, 2020 11:45:52 GMT
Very nice.
That is gorgeous...I'm jealous !!
Norman
Beautiful restoration, you must be proud. It’s easy to lose the time scale when tackling these type of restorations. My current car i have had for seven years but a lot of that time I didn’t do anything. The one i had before that a 1600E i had for ten years, i got so sick of it after doing a LOT of welding that one weekend in a moment of madness i took the grinder to it and cut it up!!! Back to your car, it’s very nearly finished, or are they ever finished? I am very envious, i had a number of minis when i was in my teens and twenties. I wish i had one now. All the best, Norman
That looks lovely. My Mini came off the road in about 2005 for a slipping clutch. After the verto flywheel refused to budge I ended up ripping the whole drive train out and fitting a Vauxhall C16XE. Probably only done a couple of hundred miles since I ‘finished’ it. Couple of persistent wiring issues spoiled my enjoyment of it but think I got to the bottom of it just before I flew to Australia so it’s just been sat for 2 years now. I’ve been drawing up a list of other things I want to do to it when I get back so who knows how much longer it’ll be before it’s on the road again?
