Sept 24, 2020 18:45:37 GMT |
Britool 3/4 drive AF and Whitworth socket set. In good used condition. Includes two ratchets, extensions two breaker bars Its all Original Britool apart from the Extra ratchet which is Tipco It goes up to 1 1/2" Whitworth ( About 60odd mm) and 2" AF about 50mm Its a two man lift £125 collected Just off junction 7 of the M62
It will come in handy even if you never use it
Sept 25, 2020 4:39:35 GMT |
What's a 'proper man'? Someone fragile enough to be defined by their tool?
shampooefficient
@shampooefficient
Sept 25, 2020 11:03:13 GMT |
I want that just for the sheer overkill of using it to undo a cam cover or windscreen wiper... But I can't justify the spend.
Ignore the millennial nonsense, keep marketing it as you have. Maybe throw in a couple of Yorkie multipacks... GLWS!
Sept 25, 2020 16:42:45 GMT |
I want that just for the sheer overkill of using it to undo a cam cover or windscreen wiper... But I can't justify the spend. Ignore the millennial nonsense, keep marketing it as you have. Maybe throw in a couple of Yorkie multipacks... GLWS! Thanks I slipped up should have photographed it next to a mug the sockets are massive, only selling as we have two, the others even bigger as its also metric
Oct 20, 2020 17:31:36 GMT |
Now sold
