A set of four Weller Racing 13 inch steel wheels originally used on a Formula Ford track car.
Rare wider rim widths of 6 inches and 8 inches. Two of each width included.
Wheel dimensions:
6 x 13 inches
PCD 95.25mm (3.75 inches)
ET 15mm (offset)
Backspace 123mm
Centre bore 63mm approx.
8 x 13 inches
ET 3mm (offset)
Backspace 84mm
The 3.75 inch PCD was used by Triumph for the TR7 and other smaller Triumph cars as well as Lotus and early Caterham.
Wheels are in good condition but please check the photos.
Collect from West Lancashire, 10 minutes from J27 of the M6.
dapser.
Wheel dimensions:
6 x 13 inches
ET 15mm (offset)
Backspace 123mm
8 x 13 inches
ET 3mm (offset)
Backspace 84mm
dapser.
