Got a genuine holset hx50 turbo for sale. Removed as it was just too much for what I was trying to achieve. this is a 800bhp capable unit!!
Bought new from compressor racing this time last year, however has done less than 100 road miles as I've only just "finished" the car.. (check my build thread for confirmation)
In as new condition , has had the holes in the flange moved out to match a T4 flange rather than t4i and has had a 4 inch vband professionally welded to the exhaust housing to replace the impossible to source marmon flange they use from the factory...
It's water cooled which is rare on these, il grab some pics of the actual turbo later, this is the spec off compressor racings own add.. and a pic for scale.. this isn't the sort of thing a 1.3 a series will spool but if you've got enough engine this will supply you all the flow and all the boost!
Would like £300 ovno collected from Sheffield/rotherham.. I can post at a push but it won't be cheep.
Cheers
Cheers
