mk2cossie
Club RR Member Number: 77
Dec 30, 2020 12:36:24 GMT
Ignoring the fact that I accidentally tossed a V8 in it, under the "points" system that seems to apply to rebuilds, would this not just be a MX5 with a body kit? Over here in Britain, nope. A rebody is a separate chassis frame with a non original bodyshell on top. Your MX-5 skate board would be classed as an altered/radically modified monocoque and then the P1800 shell would be subject to the ball on a stick test and all the radius nonsense for interior trim
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
More updates on the 7. It feels like a never ending weldathon, so we are trying to hit landmarks in each episode. So here we get the cockpit framed and start on the very back of the car. Should only be 1 more on chassis fab and we can move onto some different parts of the build
ToolsnTrack
Homebrew Raconteur
ToolsnTrack
Homebrew Raconteur
Episode a week going ok so far!
ToolsnTrack
Homebrew Raconteur
Feb 14, 2021 14:07:00 GMT
bricol
Feb 14, 2021 18:14:14 GMT
Just a slight addition to the forces on the track rod end used in the top arm - when you apply the brakes, there's quite a sizeable reaction moment gets placed on it - and in a different direction to what you might at first think.
An undersized joint in the outer end of the upper wishbone will bend FORWARD - as that is the direction the brake disc is trying to turn the caliper and hence the upright, pivoting it around the lower wishbone joint. Some less than well engineering conversions to rose joints on Caterhams from the Fiat track rod end they use have found this out!
ToolsnTrack
Homebrew Raconteur
Feb 15, 2021 18:13:07 GMT
ToolsnTrack
Homebrew Raconteur
Feb 21, 2021 20:34:59 GMT
Feb 22, 2021 12:37:08 GMT
Really enjoying this, great way to start a Sunday, mug of tea, toast & Youtube.
1993 Rover 220 Coupe 1972 MG Midget
jimi
Feb 22, 2021 22:33:50 GMT
deliberate blooper at 1.23 ? or just brain in advance of tongue ? good episode Tommy
Last Edit: Feb 22, 2021 22:34:55 GMT by jimi
ToolsnTrack
Homebrew Raconteur
deliberate blooper at 1.23 ? or just brain in advance of tongue ? good episode Tommy Its usually pretty simple to spot my mistakes Jimi, they occur from 0.00 to whenever the episode ends!
ToolsnTrack
Homebrew Raconteur
OK, this is maybe the last episode we drop on a weekly basis. I need to drop the pace a bit and focus on doing them like this more. We really paced ourselves and added the quality in this but it's simply unmanageable to do this editing, building a car, air an episode every week AND work 40h a week in a separate job. But it is absolutely worth doing them to this level, so that's the plan...
mk2cossie
I thought the Kirkey seats were adjustable for grip via tweaking the sides in or out with brute force?
ToolsnTrack
Homebrew Raconteur
Apologies for the delay...
ToolsnTrack
Homebrew Raconteur
Apr 11, 2021 16:39:26 GMT
ToolsnTrack
Homebrew Raconteur
ToolsnTrack
Homebrew Raconteur
May 10, 2021 10:01:34 GMT
Long overdue update, hope you enjoy!
ToolsnTrack
Homebrew Raconteur
Hiatus over, we are back on it in a big way!
ToolsnTrack
Homebrew Raconteur
ToolsnTrack
Homebrew Raconteur
Happy Monday guys, we have been busy too:
Still to come, we are going to get the rear suspension arms put together and push for a rolling chassis ASAP. Also, between us I may or may not have yet another project to add to the stable.
It's retro and relevant. Promise.
