Sept 27, 2021 13:05:12 GMT
I think you mentioned NATO green or a camo wrap? A small pattern camo might hide any cracks under the wrap?
Thinking modern "digital" patterns, or Vietnamese tiger stripes? Or flektarn?
Sept 27, 2021 13:09:03 GMT
See if there is something SANDF available?
Sept 27, 2021 16:29:43 GMT
What a pain for you Rian! I suppose at least you got them out beforehand. Still not ideal though. With regard to the fibreglass and repairs, I will just leave you a couple of pictures to advise that it's probably best left alone. This was midway through sorting the front end on the Midas. It very nearly broke me and took me months. Granted that this an extreme example but you do end up chasing crack after crack... Yes, certainly would be more hassle without the tool. There are a bunch more, but hopefully I can do them in the press. I have realised and decided to rather just leave well alone and possibly go the Prozac route. I think you mentioned NATO green or a camo wrap? A small pattern camo might hide any cracks under the wrap? Thinking modern "digital" patterns, or Vietnamese tiger stripes? Or flektarn? I will only go to the next level after it is insured and MOT’d Even then, it may be a bridge too far. See if there is something SANDF available? SANDF is Brown, very brown.
Sept 27, 2021 16:47:10 GMT
BEST LUBE FOR FITTING POLYBUSHES ??
Copper slip for bolts in sleeves yes.
But slipping the rubber in?
jamesd1972
Club RR Member Number: 40
Sept 27, 2021 17:28:45 GMT
Silicone usually - were there any packs with the bushes ? James
Sept 27, 2021 18:54:19 GMT
We sell those red polybushes for Merc G wagons. They come from poland - with vaseline included.
Sept 27, 2021 19:07:32 GMT
Silicone usually - were there any packs with the bushes ? James Thanks James, No lube included, used white grease spray. We sell those red polybushes for Merc G wagons. They come from poland - with vaseline included. I know some manufacturers include grease. Vaseline for the front end when I get to it.
Sept 27, 2021 19:18:06 GMT
Vaseline for the front end when I get to it. I'm told that Vaseline is also extensively used for the rear end.😅
Sept 27, 2021 20:25:33 GMT
Vaseline for the front end when I get to it. I'm told that Vaseline is also extensively used for the rear end.😅 I tried it before…….. Works.
Sept 27, 2021 20:41:18 GMT
So yesterday my one neighbour who restores pre-unit Triumphs popped around, “Hey mate, do you have a space heater?” My reply was “Ys, a a small gas powered unit, why? Do you need it?” “No was his reply, I have one, do you want it?” My reply was to ask what or how much he wanted for it, and just what model it was. The small one I have runs off Butane or LPG but I have never actually used it, so new in the box Seems Mike tried using his 55kw unit twice, running it on Diesel but did nt get on with it as it needs ventilation. I offered him my one in exchange, but he is going ceramic something or other. I will collect his one, when it gets colder. What it means, is that I will probably be able to work in the carport in winter if I do hang that large blue canvas in the front of the carport. I really want to complete this build as soon as possible. So last night I left the Rezin Rockit packed away as they weather forecast was for rain today. I forgot to show the inside of the one arm. And all packed away. Today, in a fruitless search for diesel for my car, I bought some nuts and bolts to replace some of the pieces removes when trying to get to the bushes. I also had some steel pipe cut and acquired, no charge. More later.
Last Edit: Sept 27, 2021 20:45:08 GMT by grizz
Sept 28, 2021 8:17:27 GMT
So after work I got some free time as Sally was too knackered to come here for a few hours and dinner. Perfect. So I started cautiously……. MAGIC !! Then the second one, needed the press to just seat is as deep as possible. Then onto the famous Void Bush Bit of white Lithium grease, and all the sleeves got traditional Copper Slip to help them resist rust for as long as possible. Once all the bushes were fitted, I removed the lower arms, one at a time, not knowing how the Anti Roll Bar would react once released, it was easier than I thought. Fitted the new to me lower arms and upper arms, Job done by 7.15 almost dark. Next job……. Front end.
Sept 28, 2021 17:49:10 GMT
Progress! Loving this
Sept 28, 2021 19:25:37 GMT
Small steps compared to what many on here get to do daily, but happy that it is in the right direction. And I guess I am just executing the communal energy here.
Sept 28, 2021 19:52:09 GMT
My day started with a crisis, so I requested a days leave from the boss, approved. By about 12.It was time to try focus on life. So I started with a job I was possibly not going to screw up. First coat on the roll-bar. I like that, contrast should be good. Also tidied up the rear end where I had burned the bush and hammered the living daylight deon the rear end. So I unpacked all the bushes where they were meant to go, just to get the idea. Started on what I thought would be the easiest point, the ARB. Hard to believe, but having it all disconnected and rolling round, this single nut took 30 minutes to remove, it was rusted and locked in, and the nylon of the nyloc was chewed up and pulled into the thread. Next job to figure out will be just how to remove these uprights, including the lower bushes from where they are stuck. And the next challenge after that one is these 27mm nuts……… their threaded shafts are long and make it impossible to use a regular socket or impact driver to unseat and unscrew them. Looks like I may have to head to Halfords or somewhere to buy a 27mm ring and open spanner. Little bit frustrating.
Sept 28, 2021 20:51:51 GMT
Give the exposed threads a good wire brushing and a squirt of lube. Would you get a deep 27 mm socket on there?
Sept 28, 2021 21:05:20 GMT
Give the exposed threads a good wire brushing and a squirt of lube. Would you get a deep 27 mm socket on there? Evening glen,anderson The other side has about an inch of thread sticking out, but I believe that would work. Just thinking right now, maybe I should go down-to the garage at the roundaboout and zoo to see if they have one I could use on the impact gun. Not being attached to the chassis means they are awkward to force.
Sept 28, 2021 21:06:01 GMT
Sept 28, 2021 21:14:40 GMT
Thanks. I would not try that on this job, it is a sparkplug spanner for easy jobs. I think this thing needs a load more oooomph.
mk2cossie
Club RR Member Number: 77
Sept 28, 2021 21:22:56 GMT
As glenanderson says, give the track control arm threads a thorough clean, and some kind of penetrant fluid. They should be fine to undo then They had been left unloved for many years on my Granada, and adjusted easily enough with some squirt and a spanner when adjusted many years ago now Good progress otherwise grizz
Last Edit: Sept 28, 2021 21:24:05 GMT by mk2cossie
Sept 28, 2021 21:28:38 GMT
27mm is often used for hub nuts, the six sided hub nut socket i have is very deep and designed to take torque.
