Aug 12, 2021 15:50:35 GMT
I feel your pain Rian, having gone down the same route - what is it about white 80s fibreglass kit cars that makes everything a pain in the flange to remove? A tip I learned very quickly with dome-headed self tappers is to grind a slot in them using a thin grinding wheel on a Dremel. This should then generate enough heat to enable you to loosen it. I quickly found that with a previously-neglected kit, a Dremel was an absolute Godsend. Dremel EZ Speed-Clic cutting discs are the ones you need (you need the EZ Clic mandrel too). I also would recommend not trying too hard to undo bolts that don't want to play. Just cut them off. You'll thank me later! Same goes for the braking system. If there's any doubt, there is no doubt: Bin and do it properly. If I wasn't tied up in doing stuff here I'd be down there but have too much on at the moment.
Aug 12, 2021 21:47:18 GMT
My life changed the day i bought those ez discs for my dremel.
Zero garage time. Insomnia sucks big time. Been awake since 03.00 chatting with Dennis in St Louis who had a power cut, sitting in his truck charging his phone. I have a generic Dremmel type tool. Would that work? I find it to be very fragile. Only good for plastics etc. No Super Duper ability. And the EZ discs?? Tell me more.
Last Edit: Aug 13, 2021 3:21:57 GMT by grizz
So yesterday was planned for nuts, bolts, rusty stuff, side cutters and a grinder Lazy slow start, then chatted with Paul Y about the roll cage or hoop options for the build. I want something chunky looking, and different is a great option. He sent me a pic of the half cage from one of the phases of his 56 Chevy. I think it may work. With a bit or lot of work. Then Sally called, and all hell broke loose. I got to cut the grass, weed and clean a bit of stuff around the yard. She asked me if I could help her to help Uncle Bob with some trees that had grown too tall, and were interfering with overhead power lines. Of course I had to say yes, no problem. So while she washed her car, I gathered all my bits, went to buy 5 liters of fuel to mix up for the chainsaw, filled the chain oil and fuel reserves, and tried to start it, third pull it took, this after more than 2 years since the last time I used it when building the garden wall, After washing her car, I had to buff back the one fender and bonnet that must have had a paint repair at some point in the past as they always fade away, and if she is selling the Corsa, it needs to be presentable Then off to Uncle Bobs. Unpack, find a double length ladder and get started. Fortunately Uncle Bob was away at his yard, spraying brambles and weeds, so we could get on and just do the job without him supervising. He had shown us on an earlier recce in the morning which trees needed to come down. 9 of them in total, though a lot of other plants needed some serious pruning and cutting back (he stopped looking after the large garden 14 years ago when Sally’s mum died as she used to love the garden and manage it) , certainly more than one days worth of work, having to plan and operate between various structures and abandoned treasure cars etc. Despite a used, somewhat blunted chain, I managed to proceed. Sally drew the cuttings away for me and built a huge pile. I had to cut quite a few branches into smaller manageable sizes too. Two tanks of petrol, and one refill on the chain oil is how long it took me to get the first two trees done. 7 trees to go, a job for another day. Perfectly timed, for us, Uncle Bob for home just when we had finished cutting the lot down and piled up. He seemed happy, almost 75 now, I guess jobs that were a breeze when he farmed, now are both tiring and dangerous. . Now I need to find a petrol chipper locally to use, or one to buy as there is a load of work left and the other 7 trees to cut down. Having all the cut branches and stumps removed will cost more than the price of a used petrol chipper I suspect. After we finished at Uncle Bobs we went to Sally’s place for her to try out the mower I had got her for her birthday, seems she likes it. Even got a pic this morning from her to say she was happy with the finish, which made me smile. She loves her garden. Maybe today I will get an hour or two on the Rezin Rockit. After going out with Sally.
Last Edit: Aug 13, 2021 9:30:04 GMT by grizz
Paul Y
Rian, A bit easy after the event but the electricity company will come and cut the trees for you FOC if they are interfering with power lines. They come and trim my Poplars every two years - not the neatest job - but it is a lot less risky than being fried.... If only I had a pick up truck I would come and help you move some of the wood! P.
Rian, A bit easy after the event but the electricity company will come and cut the trees for you FOC if they are interfering with power lines. They come and trim my Poplars every two years - not the neatest job - but it is a lot less risky than being fried.... If only I had a pick up truck I would come and help you move some of the wood! P. Yup…… We know they will come cut trees etc. But, remember Bob is a serious HOARDER and has some very interesting stuff hidden in various sheds etc on site, so he does not want anyone coming and seeing what he has. We both know this, but he would not budge, so sometimes it is easier to flow with the tide. Yes, and my truck is a softie. There is enough in the pile now already to fill two high side Transit pickups like the garden guys use.
jamesd1972
Club RR Member Number: 40
Aug 13, 2021 11:06:01 GMT
Plant hire people often have the chunky diesel tow-along chippers but if you can find a more agri based place they might be better looked after. Last time I hired one it was £90 for the day but cheap for the work a big machine can do. Weekend rates etc. can often be had as companies don't want them at weekends. Used oregon chains with good results - two for £20ish last time so well worth having a couple of spares when it increases the work rates so much. Oh and watch your back I find chainsaw work hard on it ! James
Aug 13, 2021 13:57:18 GMT
I have a generic Dremmel type tool. Would that work? I find it to be very fragile. Only good for plastics etc. No Super Duper ability. And the EZ discs?? Tell me more. The Speedclic Mandrel is a brilliant and simple idea. Just pull the collar down, fit the disc over the top, twist 90 degrees and you're done. The discs are far more hardy than the ones that are held in with a screw, as those ones tend to explode into shrapnel on a regular basis. Granted that the EZ-clic mandrel is only made by Dremel, as are the discs, but they are far superior to anything generic. All available from B&Q or most online shopping sites. Pics below: There's no reason why your generic version won't work - it's a simple drill after all! A variable speed one is better
l33dwc
Aug 13, 2021 20:09:12 GMT
Yep. They are good enough to cut through a Corsa D front coil spring, when you can’t find your angle grinder disc removal tool! I have a generic Dremmel type tool. Would that work? I find it to be very fragile. Only good for plastics etc. No Super Duper ability. And the EZ discs?? Tell me more. The Speedclic Mandrel is a brilliant and simple idea. Just pull the collar down, fit the disc over the top, twist 90 degrees and you're done. The discs are far more hardy than the ones that are held in with a screw, as those ones tend to explode into shrapnel on a regular basis. Granted that the EZ-clic mandrel is only made by Dremel, as are the discs, but they are far superior to anything generic. All available from B&Q or most online shopping sites. Pics below: There's no reason why your generic version won't work - it's a simple drill after all! A variable speed one is better
Current fleet 1991 Fiesta 1.1 Popular Plus - The garaged queen 2003 Shogun 3.3 DiD - The family truck and general dogsbody 2004 Audi A4 1.8t.- Project that needs Mot 2007 Nissan Note 1.4 - Business car 1 2008 Vauxhall Corsa 1.4 Auto - Business car 2 2014 Toyota Yaris 1.4 - Business cars 3
Aug 13, 2021 20:50:32 GMT
Yep. They are good enough to cut through a Corsa D front coil spring, when you can’t find your angle grinder disc removal tool! The Speedclic Mandrel is a brilliant and simple idea. Just pull the collar down, fit the disc over the top, twist 90 degrees and you're done. The discs are far more hardy than the ones that are held in with a screw, as those ones tend to explode into shrapnel on a regular basis. Granted that the EZ-clic mandrel is only made by Dremel, as are the discs, but they are far superior to anything generic. All available from B&Q or most online shopping sites. Pics below: There's no reason why your generic version won't work - it's a simple drill after all! A variable speed one is better Sounds like a good option guys, thanks.
Aug 13, 2021 21:00:28 GMT
On a slightly different tack, I had a big grin and chuckle today. Reading this written by a reader on another forum. Seems I am influencing scavenger culture. Free money is great. Howdy. Catching up here a little bit. I learned something about hanging the flag vertically. Makes sense that the blue stays in the upper left hand corner but I had always thought of that as sort of the back side of the flag since it's opposite side from what usually shows when the flag is oriented horizontally. And I learned it from a South African who lives in England, haha. That little barbecue you made out of the keg was fantastic. What a great idea to utilize the legs from those stools. I don't think it would have occurred to me to upside-down one of them like you did. Came out really nice. Had to chuckle when you talked about picking up stuff out on your walks. In the last week I've come home with a set of driving lights, one with a cracked lens which is replaceable. A hose reel on wheels that I think will store a couple of 50 footers. And a computer desk that's in perfect condition. I could carry the driving lights pretty easily. I had to go back after my walk to get the hose reel and put it in the trunk of my car. But I decided to see if I could carry the computer desk the five blocks home. Had to set it down a couple of times but made it, haha. Added a bit to my workout. I like it when my walks become part exercise / part treasure hunt.So most of today ended up being spent on more domestic chores, house cleaning, garden work, and cleaning up and out the BBQ in preparation for the weekend. So when headed to town to get a few things, Sally clocked this car, she had seen it before, thinking it was another fiber glass replica Turns out it is metal bodied, looks like it has high and low range options. No creature comforts. Could it be a Mahindra, from India? I really liked the zip up padding on the cage, makes it look chunky, a look I am going for. Fold down screen. Eventually home by 4.30 Coffee, then shop time from 5.00pm .
Aug 13, 2021 21:35:37 GMT
So after a coffee, my team leader headed down to the garage. This pic is real, she was getting at one of the bolts holding the grille and fender together. I crept in under it to get going on undoing the nuts covered in Duck Oil yesterday. One chassis bolt undone. One attacked with the spark maker. Another job to do was steering to be disconnected. QUESTION TIME: Looking at this joint, it does not seem to be removable, or splitable…… How do I replace the rubber joint with fresh rubber? Is it called a rag joint? Also cut all the brake lines while in there as they are fed through the body, some are already broken and cut, so remake will be the the way to go. There was a load of thick scabbed rust here too. Mr Hammer made it go away on the vertical plane. Next job, remove the self tapping screws holding the grille to the front bumper. Following this, I decided to undo the next set of chassis bolts. Much hammering with the BFH saw the passenger side unscrewing with a visegrip attached. Drivers side looked like this……. So Sally held the small LED spotlight torch so I could see what I was doing, getting the cutting disc going on the right spot of what was left of a 11mm bolt and washer. After that, I closed shop by 7.30 and came inside. Cooked some bacon, and made bacon and pork sausage paninis, along with a tall,Rum and Pepsi Max Sally poured for me. Tomorrow it is the turn of the handbrake assemble to be disconnected Feeling good so far. Weekend too.
Last Edit: Aug 14, 2021 5:04:35 GMT by grizz
Aug 13, 2021 21:37:04 GMT
Listed on DVLA as a Mahindra Marksman.
Aug 13, 2021 21:39:04 GMT
Nice one that your free money/recycling ethos is gaining traction. And Mot check says that it is a Mahindra Ah, Mr Bounce has faster fingers
Last Edit: Aug 13, 2021 21:41:54 GMT by Morris63
jimi
So Sally held the small LED spotlight torch so I could see what I was doing, getting the cutting disc going on the right spot of what was left of a 11mm bolt and washer I'd be extremely surprised if it was 11mm, it would be a very unusual non standard size. I've never seen an 11mm bolt in all the time (a very long time) I've worked in engineering. I'd guess it was either 12mm or 7/16"
Last Edit: Aug 14, 2021 1:08:07 GMT by jimi
joeytalent
ITB Everything.
I have a generic Dremmel type tool. Would that work? I find it to be very fragile. Only good for plastics etc. No Super Duper ability. And the EZ discs?? Tell me more. The Speedclic Mandrel is a brilliant and simple idea. Just pull the collar down, fit the disc over the top, twist 90 degrees and you're done. The discs are far more hardy than the ones that are held in with a screw, as those ones tend to explode into shrapnel on a regular basis. Granted that the EZ-clic mandrel is only made by Dremel, as are the discs, but they are far superior to anything generic. All available from B&Q or most online shopping sites. Pics below: There's no reason why your generic version won't work - it's a simple drill after all! A variable speed one is better This might change my life.
Listed on DVLA as a Mahindra Marksman. Nice one that your free money/recycling ethos is gaining traction. And Mot check says that it is a Mahindra Ah, Mr Bounce has faster fingers I knew it had to be a Mahindra. Model name is interesting, as they often are.
So Sally held the small LED spotlight torch so I could see what I was doing, getting the cutting disc going on the right spot of what was left of a 11mm bolt and washer I'd be extremely surprised if it was 11mm, it would be a very unusual non standard size. I've never seen an 11mm bolt in all the time (a very long time) I've worked in engineering. I'd guess it was either 12mm or 7/16" Good spot jimi That was 99% a trick posting. As the 12mm just managed to fit on what was left of the passenger side bolt, but could not unseat it, despite the BFH Visegrips, or is that Vicegrips (Singular or Plural?) managed to get it undone with gentle forward, rearward motion. My vote goes for 12mm as a few other bits are sort of standardised, by this is by no means an OCD built kit car, but rather built under a canvas on the drive,,assembled with whatever the contents of a load of small jam jars on the workbench were.
Last Edit: Aug 14, 2021 4:57:09 GMT by grizz
The Speedclic Mandrel is a brilliant and simple idea. Just pull the collar down, fit the disc over the top, twist 90 degrees and you're done. The discs are far more hardy than the ones that are held in with a screw, as those ones tend to explode into shrapnel on a regular basis. Granted that the EZ-clic mandrel is only made by Dremel, as are the discs, but they are far superior to anything generic. All available from B&Q or most online shopping sites. Pics below: There's no reason why your generic version won't work - it's a simple drill after all! A variable speed one is better This might change my life. Agreed, this could make a difference. Also the comment on the durability of the discs. I find them mostly being like confetti at a wedding…… flying all over the place. Next question would be whether the mandrel is universal. Then I could buy one, and some Dremmel brand discs and fit them to my free tip find generic machine.
