Nov 20, 2020 20:50:31 GMT
Just refresh my memory ... what is the orientation of the pinto sump in the Rockit ? i.e is it in front of the crossmember or behind it ? what is the orientation of the mx5 engine i.e in front of crossmember or behind ? If the same then check position of gear stick is the mx5 same, longer or shorter in cab area? this will impact engine mounts size / position etc. If all that is somewhere near 'just' make some mounts and whack it in ! Main thing is don't over think the task , tackle it in managable chunks ... I have no idea regarding the Ford bits. It seems to be a long motor and trans, I wonder if the gearstick wont be further back. Use a transit pinto gearbox, the stuck is mounted on the bell housing rather than the tail of the box.
These but I just thought. They're 5-lug. Phil True. I really should look at Poundland and the rest of there are any stainless bowls of the right size to adapt.
I have no idea regarding the Ford bits. It seems to be a long motor and trans, I wonder if the gearstick wont be further back. Use a transit pinto gearbox, the stuck is mounted on the bell housing rather than the tail of the box. Simple, needs to stay simple, trying to keep stuff together that is together. But who knows, maybe we do end up with a Frankenstein
Last Edit: Nov 26, 2020 10:58:42 GMT by grizz
Nov 26, 2020 10:58:06 GMT
Having a chat with Flingstam abouthis Toyota Deliboy and rev counters, he refered me to his newest favourite website for buying “stuff” His thread: forum.retro-rides.org/thread/215030/1991-toyota-deliboyI was always thinking of a silly, large Rev Counter and had one stashed bit it seems I stashed it too well of someone else now has it. Anyway, looking around I saw this.......... I do like the look of it, but no real idea of how well they work or not.
Nov 26, 2020 12:31:15 GMT
The 'scope of application' part looks interesting.
1991 Toyota Deliboy (RWD JDM LCV) - Now SOLD 1998 Lexus LS400 (RWD EUR VIP) - Also GONE 1989 Volvo 740 GLE (RWD EUR GLE)
Nov 26, 2020 15:21:23 GMT
I think that's more used for industrial machinery. Our machines are measured by engine run hours using an hour meter such as that one. They don't have odometers so this is how we tell how much use they've had.
Nov 26, 2020 22:31:42 GMT
I think that's more used for industrial machinery. Our machines are measured by engine run hours using an hour meter such as that one. They don't have odometers so this is how we tell how much use they've had. I've always said that vehicles here should be so equipped, given how long they sit in traffic jams then idling outside shops to keep the air-con running. Low mileage is meaningless in Manila and unless you keep the vehicle for 40 years, high mileage is impossible!
Last Edit: Nov 26, 2020 22:33:00 GMT by georgeb
The 'scope of application' part looks interesting. Made me chuckle. It could be that I need to look for other options. Including something with a built in Satnav, I do not know what is out there, but it has to exist somewhere, so that rather than stick in an iPhone, one goes straight in with the right device. I think that's more used for industrial machinery. Our machines are measured by engine run hours using an hour meter such as that one. They don't have odometers so this is how we tell how much use they've had. I,suspect that’s where it’s best applied. I liked the style and size of display, did not go through all they have in stock, other suppliers may have better options too. I think that's more used for industrial machinery. Our machines are measured by engine run hours using an hour meter such as that one. They don't have odometers so this is how we tell how much use they've had. I've always said that vehicles here should be so equipped, given how long they sit in traffic jams then idling outside shops to keep the air-con running. Low mileage is meaningless in Manila and unless you keep the vehicle for 40 years, high mileage is impossible! So true. I still love the old analogies of one elderly driver, and you hear them drive off with clutch dragging, or find not a panel straight on the whole car. Likewise, engine hours may be more indicative, but we have options at least.
Having a day job, rubbish weather and life in general can all get in the way of a good story. Another small job done today on the Rezin Rockit build process during my “lunch hour” break . We had a load of rain and some snow early in the morning. Driveway temperature was 4’C when I was getting this done, chilly. As much as I dislike this whole Corona virus and how it has turned our worlds upside down, I am massively thankful for still having a job that I can do successfully from home, despite it not being very rewarding as the old way was. BUT...... my daily commute of a minimum of 60 miles or 100km taking me a minimum of two hours, means that one can add a bit of travel time to your own agendas. So today I needed to move a 3/4 ton bag of sharp sand from under the carport to behind the garage. Also some 25kg bags of building gravel and more bags of kiln dried sand. Opening up some space. For the Rezin Rockit as originally planned. So getting it through here between the caravans. Managed that, with a 3 ton jack under the rear differential and some careful force. Resulting in it getting reversed into position so that I can get to it for some of the preparation work. So in a way I have made it to one of the goals set originally A dry workspace for the future. Still needs more work to be done and some weatherproofing. Oh, and it is the weekend.
Last Edit: Dec 4, 2020 20:30:51 GMT by grizz
bricol
Well...... Did you, did you buy it?
Did a load of odd jobs around the garage, but it was unpleasant and by 3.00pm it was down to below 5’C and I gave up and shut shop. Managed to do a tiny job on the Rezin Rockit as well. Drilled a 10mm drain hole in each footwell to release all the captive water that collected recently. Will clean and dry it all out so I can work in there. Screen still needs to be removed carefully.
Last Edit: Dec 6, 2020 8:10:20 GMT by grizz
Your thermometer indicates exact the same temperature as here in Australia. Yours on the left ours on the right hand side.
Dec 12, 2020 15:57:41 GMT
Your thermometer indicates exact the same temperature as here in Australia. Yours on the left ours on the right hand side. Do you guys read it in “F rather than ‘C ?
Dec 12, 2020 22:02:03 GMT
Not much done with the Rezin Rockit recent;y, day job, weather and other jobs getting in the way. In fact hit a bit of angle iron which slowed me down for the time being till I figure out or get advised on how to deal with it. Started off by getting up inside the passenger A-pillar and removing the rear view mirror. Then over to the drivers side. My back has been fighting me really badly for some time now and I have been referred for spinal surgery, but I am stalling. Slithered in there, upside down Looking up the A-pillar and toward the window frame, you can see there is a length of angle iron incorporated in the frame. This needs to be dealt with, in order to figure out how to remove the frame. Managed to get out of that upside down position, had gotten the one rear view mirror bolt unscrewed, then used a long screwdriver to lock the 10mm bolt in place and rotated the mirror around it, as there was no way to get spanner’s in there. Done If you look carefully at the bonnet of the car you will see that it had started to rain, made me chuckle as the carport roof was always planned this way. Finally, managed to get one of the gutter bolts unscrewed from the frame. The second one on the other side ended up just spinning, so will get done when I can rope Sally or Mickey in, to be my extra hands. I actually gave up with trying to get it undone. However, there will be more challenges, as I see as you can, there is angle iron running down from inside the A Pillar. If anyone has previously removed one of these screens, please let me know how the easiest way would be. Thanks.
Last Edit: Dec 12, 2020 22:10:02 GMT by grizz
Dec 12, 2020 22:30:55 GMT
You take care of that back Rian, you only get one and it's the only thing that keeps your butt from your head. I didn't look after mine which is probably why to most people I appear to talk out of my butt!
Dec 12, 2020 23:00:33 GMT
If you’re definitely not going to be using the original screen, don’t waste loads of time and effort trying to get it off undamaged, only to throw it in the skip; just cut it off.
Your thermometer indicates exact the same temperature as here in Australia. Yours on the left ours on the right hand side. Do you guys read it in “F rather than ‘C ? No, all in C.
You take care of that back Rian, you only get one and it's the only thing that keeps your butt from your head. I didn't look after mine which is probably why to most people I appear to talk out of my butt! It has gotten worse over time, to the extent that my motorbike has been SORN for 3 years, I am too scared of dropping it, or not being able to handle it in tricky situations. Not much fun as so much stuff just has to be by[assed, even going to sleep is actually a problem now, as I get spasms some nights as I nod off, that make me squeal like a girl and then leave me awake, too bloody nervous to try go off again in case it recurs, which is what happens often. Growing old is not for sissies If you’re definitely not going to be using the original screen, don’t waste loads of time and effort trying to get it off undamaged, only to throw it in the skip; just cut it off. I had hoped to be able to rescue it so that someone else could use it if needed elsewhere. I had the front bull bar that I removed at the beginning, go off to Wales yesterday, along with the 65 C10 roof that I gave to a buddies son who is restoring a 63 panel van. But, you are right, and maybe getting some new blades for Mickeys reciprocating saw today ( I have the day off work) and just cutting it off, is the right idea, then I can start to design and make up the plates and tabs plus mounting brackets for the Land Rover screen you donated to the project (Did I really just say PROJECT ? ) Do you guys read it in “F rather than ‘C ? No, all in C. Ahh, right. And do you get rainfall this time of year?
Dec 14, 2020 14:57:13 GMT
Nice sunrise. Dennis updated his NASCAR race truck build, it is now on its wheels, all wiring, gauges etc done. Back to the Rezin Rockit saga. Mickey popped around early morning to drop off this puppy. I just got back from the shops, armed with a pack of 5 14 TPI blades for the reciprocating saw . Next up a coffee, then hit the garage for a bit before it gets cold and dark again. Never planned on using one of these on the Rockit. Kinda excited. Thanks glenanderson
