Bit of an embarrassing question. There was someone with a Ford Capri on RetroRides who has/had Citroen’s wheels fitted. I cannot for the life of me remember if they were banded, regardless, I do believe they were 4x108 and could be for sale. Anyone know what I am talking about I mentioned them: Stock 6.5 x 16" spares from a C4 Picasso, with Capri LS centre caps. I'm seeing the owner tonight, I'll check if he's still got them.
I’d want deeper dished wheels personally
I have some banded 4x108 wheels (wide) but they are in the netherlands
34 B Ford V8 Flathead Hotrod 55 International L170 (Cummins 6BT) 65 Mustang V8 supercharged Coupe 58 Plymouth Belvedere (Christine) 05 Dodge Ram 1500 HEMI
I’d want deeper dished wheels personally Of course, so would I. So banding them to get to ET - 0 would be the plan. I have some banded 4x108 wheels (wide) but they are in the netherlands Tell me more......?
Last Edit: Oct 6, 2020 16:43:03 GMT by joem83
Could always see if you could re-drill the drums & change front hubs
Beautiful but £130.00 each is a touch rich for my blood
Bikini roof was in my head from the start, despite not wanting a roof or much weather protection. After cutting the grass, I was weeding the paving in front of the garage, and found this under the storage caravan. Also found that the welding caravans one wheel that I pumped p on Monday, had blown out, so need to go get a new tyre fitted. Bikini time again: Attaching it to the front screen in a way that prevents water ingress would be a challenge, but this old trick should work. I need a longer one by 150mm or so, but this can work too. Caravan window hinge. Simple C shaped design, sew some rope onto the roof canvas/vinyl and slide it into the groove. Secure up front, attach rear tails along roll bar. Job done. Happy days. Easy.
Last Edit: Oct 6, 2020 20:14:34 GMT by grizz
Or there's a rail that attaches directly to the top of the screen frame to take the Land Rover soft top...
I was going to say what George just has. The screen I have for you is already drilled for a Land-Rover rail.
And you can get bikini tops off the shelf to suit, although they do need a basic frame...
I've just had to edit my post - I'd put some 15" slotmags up but have just deleted the link as I'd not counted the lug holes (there are 5 not 4!) so haven't bothered to post the link up.....
I've seen alot of 13" wellers - but nothing larger - if I do I'll post them here.
I've also seen a rickman ranger being broken too - I only mention it because it's got cortina underpinnings (and a 1.6 pinto, which probably isn't of interest).
I’d want deeper dished wheels personally Of course, so would I. So banding them to get to ET - 0 would be the plan. I have some banded 4x108 wheels (wide) but they are in the netherlands Tell me more......? Cant upload pictures, but they are 16 inch widened peugeot wheels 4x108 we had them on a Audi 80. With new tires newly powdercoated gloss black. 250 euro's and they are your's
Or there's a rail that attaches directly to the top of the screen frame to take the Land Rover soft top... Thanks George. I was going to say what George just has. The screen I have for you is already drilled for a Land-Rover rail. And you can get bikini tops off the shelf to suit, although they do need a basic frame... That is good to know. Not sure if those are common, and to be honest, a full LR item may be overkill. I will look and investigate as I do not want too much structure out back, and the cover needs to live under the bonnet, or in a steel box behind the seat, with incredibly simple attachments.
I think 15 or 16 or even 17 inch wheels, with 8” front and 10” rear would fill everything that needs filling, and creat a great look.
This thing is finding the right steels, with the right look, ie holes and centre, or Alloys that appeal to me.
You never know, weird stuff pops up at times.
The closer to et - 0 the better too.
Of course, so would I. So banding them to get to ET - 0 would be the plan. Tell me more......? Cant upload pictures, but they are 16 inch widened peugeot wheels 4x108 with et 31 and we had them on a Audi 80. With new tires newly powdercoated gloss black. 250 euro's and they are your's Thanks @68mustang So one needs to get them from Werkendam in the Netherlands to Rochester 🚀. Maybe there is a 🐎 express opportunity Looks like 205 R45 16’s and 215 R45 16’s if I read correctly.
93fxdl
Enter your message here...
There's a bit of theme developing here .. this one's in Helensburgh ... or do they all go to the same place to die... bit like elephants
Last Edit: Oct 7, 2020 11:48:24 GMT by westbay
I much prefer the look of the Jag to the Eagle, but we will make the eagle work. There's a bit of theme developing here .. this one's in Helensburgh ... or do they all go to the same place to die... bit like elephants Yup....... Seems that is the case.
