I hope it goes well, with not too much swearing
I'll check back later
Headed down to go start back on wrapping this build up.
Some swearing, blended with memory loss my ensue.
if it all goes well today will the next step be to book an MOT test ?
then clock up some well earned smiles
Some important items for your don't drive it until these are done list:
Bleed the brakes thoroughly and adjust them now the new parts have begun to bed in.
Fit a robust stop to the throttle pedal to prevent damage to the cable
One on the clutch pedal is probably a good idea for the master cylinder's life.
Fit a return spring to the throttle pedal - the one on the throttle body is NOT enough.
Source the necessary wheel bolts for the rear wheels, as what's on there are only good enough to move the car.
I know what the job thing is like, had to reapply for my own job a couple of times in my retail days.
Hope all goes well, trying times.
How long till you find out?
Being interviewed for your own job is harrowing, even more so at our age. I like yourself have been in this situation more times than I care to remember. All the best with your quest for continued employment.
What do these companies think?? Employees are clowns just to be harrassed to the max..
Even if you get your old job start looking for an other one in a company the at least respects its employees a bit.
So crazy world..
Thom
I hope everything goes well with the job stuff and you can get back to the more enjoyable things in life ASAP!
Thanks all.
I really appreciate the support and “man-love” on here.
Ended up doing nothing today. But bought some new walking shoes (trainers)
Except using a foot pump and pumping the rear wheels from 1 to 3 Bar.
However,
nickwheeler popped in and. Typically, we chatted, then started messing with the Scruffy Micra.
More to get done on a better day.
