logicaluk
Sept 3, 2020 19:46:32 GMT |
Mr Darkspeed I think that's for the ZF box, but its nicely oversized and could be turned down, as long as it won't matter that the holes are too big. Thank you. Ill PM you.
logicaluk
Sept 3, 2020 20:09:17 GMT |
Before Barry collected his cleaning tank, I managed to put the entire valve train from the left bank through just to get the worst off. Started off like this 20200903_183159 by logicaluk, on Flickr Ended up like this. 20200903_184209 by logicaluk, on Flickr I did find one hydraulic lifter was missing its clip, hopefully it's in the sump. Dan
Last Edit: Sept 3, 2020 20:11:36 GMT by logicaluk
logicaluk
Sept 5, 2020 10:28:26 GMT |
The third job for today is clean up the workshop, the First, make even more mess by completing the strip down of the V8, second make a bacon butty whilst posting this lot. The crank pulley thought it had the best of me but I bolted a bit of box section to the crank and attacked the other end with the big breaker and wound it out, the sump was much cleaner than I had expected. 20200905_103001 by logicaluk, on Flickr The front cover came off with a total of 2 sheared bolts one for the water pump with a nice bit to grab on to and one for the oil pump that broke off flush, curse word. I think at this point it realised there was no point in fighting me so it capitulated and came apart fairly easily. By the looks of it was taken out of use just before major damage occurred. 20200905_100020 by logicaluk, on Flickr 20200905_100214 by logicaluk, on Flickr 20200905_102754 by logicaluk, on Flickr 20200905_100338 by logicaluk, on Flickr 1 20200905_103511 by logicaluk, on Flickr 2 20200905_103520 by logicaluk, on Flickr 3 20200905_103526 by logicaluk, on Flickr 4 20200905_103551 by logicaluk, on Flickr 5 20200905_103602 by logicaluk, on Flickr 6 20200905_104812 by logicaluk, on Flickr 7 20200905_103632 by logicaluk, on Flickr 8 20200905_103611 by logicaluk, on Flickr
Last Edit: Sept 5, 2020 10:29:22 GMT by logicaluk
Sept 5, 2020 12:10:12 GMT |
Good progress, bottom end looks pretty normal, new bearings and rings are all they often need. What's the cam like, they are usually the first thing to go, standard cam kits are pretty cheap though. If you use a 3.9 cam make sure you get a 3.5 front cover gasket, there is one hole in a different place which means you won't get any oil pressure ,(I found out the hard way).
Are you keeping the injection, If not and it's a flapper I may be interested in some parts.
logicaluk
Sept 5, 2020 14:15:22 GMT |
cleaned up and did a bit more, both sheared bolts came out the front cover, one wound out with some heat, the other had to be drilled out and re-tapped. Upon close inspection I think the camshaft has had it. 20200905_125905 by logicaluk, on Flickr the cam follower that lost its clip, took out a push rod. 20200905_131753 by logicaluk, on Flickr Both of the rocker shafts are well worn, and ones bent.  biscuit. So the shopping list looked like this Full gasket setRocker shaft x2 Push rod x1 Piston rings Main bearings Big end bearings Timing chain Cam and followers Core plugs Any one have a Lucas hotwire ECU they would like to part with?
Last Edit: Sept 5, 2020 15:57:04 GMT by logicaluk
logicaluk
Sept 5, 2020 14:22:09 GMT |
Good progress, bottom end looks pretty normal, new bearings and rings are all they often need. What's the cam like, they are usually the first thing to go, standard cam kits are pretty cheap though. If you use a 3.9 cam make sure you get a 3.5 front cover gasket, there is one hole in a different place which means you won't get any oil pressure ,(I found out the hard way). Are you keeping the injection, If not and it's a flapper I may be interested in some parts. Yes cam looks shot. Yep (just checked) I did order the 3.5 gasket kit. I'm not using the injection as its missing its ecu and I have a pair of strombergs. But i think its a hot wire. Is the 3.9 cam good with carb? Thank Dan
Last Edit: Sept 5, 2020 15:15:16 GMT by logicaluk
Sept 5, 2020 16:35:47 GMT |
It's what I have in my tr7v8 on su's, which works fine.
logicaluk
Sept 5, 2020 19:30:01 GMT |
Thanks DS, a decent pair of rocker shafts would help greatly, could you ask if there is a push rod and a follower (or just the clip) in the cupboard too please. Thanks Dan
Sept 5, 2020 19:43:22 GMT |
If darkspeed doesen't have one I'm pretty sure there are 16 pusrods in my attic you are welcome to one, I'm not back for a week though.
logicaluk
Sept 5, 2020 20:15:41 GMT |
thanks Kevins
logicaluk
Sept 5, 2020 20:31:44 GMT |
I've been having a hunt on eBay;
£5 Proper valve stem oil seals as opposed to the flat washer type £14 Cam chain both sprockets look OK £60 Camshaft 3.9 £20 Core plugs £48 Piston rings OEM quality £50 Glyco std main and big end bearings
Plus the £37 I've already spent on gasket sets
£234 for a full rebuild kit. I had hoped it was just going to be a head set, lol.
But I can't grumble at that.
Last Edit: Sept 8, 2020 19:36:33 GMT by logicaluk
Sept 5, 2020 22:33:49 GMT |
Good call on second-hand rocker shafts. I've heard(?) that some new replacements aren't quite up to scratch.
Sept 8, 2020 11:40:01 GMT |
It may be wise to add a shim kit for setting the lifter preload, especially if you are mixing parts from several engines and these shim kits are not expensive
I used these on the RV8 i rebuild and also renewed the camshaft bearings and asked a friend with a lath to make some pullers for fitting those
Peter
Last Edit: Sept 8, 2020 11:40:45 GMT by petervdv
logicaluk
Sept 8, 2020 11:53:50 GMT |
Thanks peter, I will check them when it gets built up.
Darkspeed, would the injection work with the 3.9 cam?
Ill get some pics of the lifters tonight, having read up some on this engine, it looks like it would be sensible to change them out.
What are the opinions on crank bolts, looking at the wear on the bearings, have the bolts stretched, should they be replaced? Dan
logicaluk
Sept 8, 2020 20:32:12 GMT |
I built a Microsquirt EFI system for the acclaim from scratch and the pair of Strombergs I've got sat in a draw for this need rebuilding so there's probably not a lot in it, I'm not looking for power but reliability and having it injected would be right up my street. When I took the lifters out they didn't look to bad, and I was hoping to get away with a just a head gasket, now I'm in deep enough and it's not worth it, new lifters and timing gears ordered. No point in spoiling the ship for a hapth of tar as my Granddad would have said. Yesterday my ultrasonic cleaner turned up, what a treat that was, opening the box to find not only a proper deathdaptor but a power lead that when plugged into it couldn't make earth contact, despite 3 warnings on the tank and another in the booklet all saying this appliance must be grounded.... 20200907_154325 by logicaluk, on Flickr The euro plug can't connect to earth but if you look closely at the earth pin on the deathdaptor you can see the earth pin is sleeved, so only connects when you First start to plug it in, when the live and neutral pins connect the earth pin get disconnected leaving the appliance unearthed. What fun! I messaged the company, and they have offered to pay for a new lead. I also checked the earth continuity on the tank before plugging a spare lead in to it. It's a good size, 10l but this also has a drawback, the 250w heater isn't man enough to bring 10l of cold water up 1℃ in 5 mins, so I also had to purchase a workshop kettle, now when filled with boiling water the heater will quite happily keep the water up around 75-80℃ even when changing parts, I've made it an insulated hat to go on top of the lid to help keep the heat in. It's big enough to get 2 pistons and con rods in along with a main bearing cap. 20200907_162406 by logicaluk, on Flickr This evening I ran it for about 3 hours, cleaned 8 pistons all the main bearing caps and bolts and the other bank of valve springs. Whilst that was cooking, I took the planet gears out of the spares' gearbox, I say spares but it looks as if it was rebuilt shortly before being taken off the road, the internals of the box were spotlessly clean the ATF was bright red and there was some old greasy looking stuff which I assume is Vaseline in places, and one of the break bands still has writing on. 20200908_172937 by logicaluk, on Flickr I've also pulled out the core plus from the sides of the block, I will remove the 2 outer ones on the back and leave the cam one in but how am I supposed to remove the 2 hex plugs, or should I leave it to the machine shop when I sent the head and block in to be cleaned? Thanks, Dan
Last Edit: Sept 8, 2020 20:37:59 GMT by logicaluk
logicaluk
Darkspeed I will try to get some pics of the injection kit to check it see if its complete, when i get home later. I was told its a hot wire and the ecu plug was empty then the whole lot went in a bag. Dan
Last Edit: Sept 9, 2020 8:49:15 GMT by logicaluk
Sept 9, 2020 10:13:57 GMT |
I don't know how you're building this engine up, but I have a 3.9 cross bolted engine (complete minus the crank and pistons) that I want rid of, and some brand new bigger inlet and exhaust valves, shortened and bulleted valve guides, new stem seals, new rocker shafts and a timing cover too. Also a full set of heavy duty adjustable push rods. All bought for a project I'm not doing anymore.
Last Edit: Sept 9, 2020 10:15:40 GMT by Phil2600s
logicaluk
Sept 9, 2020 11:50:54 GMT |
Thanks phil, but a std 3.5 will be adequate for this build.
Just poped our on my lunch brake to pick up a missed delivery and I now have a cam shaft. Dan
Sept 16, 2020 10:05:26 GMT |
Do you still need a pushrod?
I found them yesterday, if so PM me your address and I will pop one in the post.
Kevin
logicaluk
Sept 16, 2020 15:27:18 GMT |
Do you still need a pushrod? I found them yesterday, if so PM me your address and I will pop one in the post. Kevin Pmed
