sonus
Pick up convertible with hardtop?
Or how abouy an anglia rear screen graft so the rear screen angles back? Might make it look like its moving when standing still🤔
I like to Nomad solution too, but would shorten the rear overhang by removing som length, almost like a vertical chop.
Last Edit: Apr 4, 2021 11:07:22 GMT by sonus
Hmmm. I’m not sure that you’re going to be able to get the proportions right for a pickup regardless of how much you play with the original metal. The whole rear of the cab needs redesigning. At the very least, it wants a vertical rear window or, as others have said, raking the other way.
I’d be more inclined to hold out for an estate body, as I’ve always loved their proportions.
Whatever, I’m following your progress with interest, it’s a cool project. 😃👍
Something like this. You might need to push the rear window back a bit further for the headroom. Another thought would be to get hold of a Herald coupe hardtop and keep the sail planes, but make the rear window vertical.
Last Edit: Apr 4, 2021 15:29:30 GMT by horrido
logicaluk
Something like this. You might need to push the rear window back a bit further for the headroom. Another thought would be to get hold of a Herald coupe hardtop and keep the sail planes, but make the rear window vertical. That is where my basic thinking is at the moment but using the standard roof, put the bulkhead just inside the B post, as there is plenty of room forward from there in a herald, use a vertical screen and use the C pillars just for looks, heres a mock up A bit like an El Camino. I've had the possibility to make it removable in the back of my mind. I'm not convinced I could rework the glass in to a different shape like the nomad. Unfortunately estate bodies just don't come up in the price range I can afford. Dan
Last Edit: Apr 5, 2021 8:32:13 GMT by logicaluk
The side glass is only flat. You can get that cut easily and cheaply.
logicaluk
the bulkhead got dropped off for blasting this week, we shall see what state it comes back in.
logicaluk
Had a play with the roof again this weekend Its looking like this A balancing act between form and function. The roof pillars will need to be lengthened by a few inches, but 18 inches from the door apature seems to be the sweet spot. I also spent a lot of time trying to work out the best way to transition from original bodywork to inner pick up tub. Its tricky but i think i have a plan, some 30mmx 1mm box section coming off the peak of the fin, the tail gate is a whole can of worms and can't yet find a solution thats with in my capabilities that i actually like. Dan
logicaluk
Apr 14, 2021 16:49:31 GMT
Apr 15, 2021 12:28:49 GMT
I've just come across this, I like the idea and the rust isn't as bad as I would have expected.
Apr 15, 2021 13:24:20 GMT
That bulkhead doesn't look that bad at all. Pretty sure that I have taxed cars in worse condition! Keep on carrying on - I like this!
logicaluk
Apr 16, 2021 11:09:34 GMT
I'm off to pick up a bottle of argon/CO2 mix welding gas, £98 for a midi bottle full of gas. I ordered a mini spray gun which i had to collect from the post office yesterday, so i can spray the bulkhead with hydrate80 we shall see how it goes. Dan
Last Edit: Apr 16, 2021 11:10:04 GMT by logicaluk
Darkspeed
Club RR Member Number: 39
Apr 16, 2021 11:59:09 GMT
so i can spray the bulkhead with hydrate80 we shall see how it goes. Dan As the shell has had all of the rust blasted off of it I would consider spraying it with an epoxy primer rather than the Hydrate 80 - Having done a small test area on some rusty steel its pretty horrible if you need to remove it to do any welding as I found it just clogs and smears being a barrier coating. If treating rust in pits, sealing them up and coating over them it seems like decent enough stuff but I would not use it as a protective primer, others may have had different experience, but I would not spray a large clean panel in the stuff if I had a lot of work of to do on it.
logicaluk
Apr 16, 2021 17:35:55 GMT
Thanks DS that sounds sensible, in which case ill repair it first then spray it with hydrate80 as the blaster didn't get all the tar like seam sealer out of the darker recesses of the bulkhead. so i can spray the bulkhead with hydrate80 we shall see how it goes. Dan As the shell has had all of the rust blasted off of it I would consider spraying it with an epoxy primer rather than the Hydrate 80 - Having done a small test area on some rusty steel its pretty horrible if you need to remove it to do any welding as I found it just clogs and smears being a barrier coating. If treating rust in pits, sealing them up and coating over them it seems like decent enough stuff but I would not use it as a protective primer, others may have had different experience, but I would not spray a large clean panel in the stuff if I had a lot of work of to do on it.
Apr 16, 2021 19:25:24 GMT
Definitely don't use hydrate 80 now its been blasted. Ideally a phosphoric wash would be good (many blasters do this before returning shells) but just get epoxy primer on it as soon as possible.
As Darkspeed says, the hydrate 80 makes welding a real pig and is only really for treating rust - you now have no rust as its been blasted off so it's the wrong stuff to use. A sandblasted finish is perfect for paint as its got such a grained surface the paint bonds to it exceptionally well.
oilyt
Apr 16, 2021 20:08:34 GMT
Agree with the above, epoxy it now as you have the perfect key for it. but wear a mask when grinding back for welding repairs in as the dust can be nasty.speaking from experience here .
Last Edit: Apr 16, 2021 20:36:46 GMT by oilyt
ferny
Club RR Member Number: 13
I've used Hydrate80 loads of times as a primer. I've normally always regretted it. 😂
logicaluk
ok where do you all get your epoxy primer from? Is it a 2 pack? High zinc? ahhhhh I thought I had this figured out.
Darkspeed
Last Edit: Apr 17, 2021 7:29:05 GMT by Darkspeed
Express paints will ship epoxy primer to you, I'll post the links when I'm on my laptop.
Apr 17, 2021 13:09:25 GMT
