Aug 13, 2020 18:28:22 GMT
Well update on the 346 saga , tried taking the starter out , and levering the ring gear .not a chance of movement ....tried dragging the compressor up the garden , put some 30 wt oil in the cylinder with closed valves , and whopped 120 psi into it , no leakage ,but also no movement , tried the crank nut and the ring gear method with the pressure on the cylinder , no vestige of a tiny chance of any movement ...looks to me like it is head off time .pox .
Ironically , apparently the old chap that had the car bought a head set , so its probably sitting in his shed forgotten . any one know how much a head gasket costs for one of these .?
Oh , last little jem was , i was looking at the rocker box thinking " oh look someone has snapped off one of the studs that hold it down " ,then realised they had ,to fix this ,blobbed two drops of weld on the edge to weld the rocker box to the head ...nice .
oh , one last last thing , 6 cylinders ..... FOUR INLETS ! poxy designer decided to bring the distributor up high , so its inline with a port , so he made a cast in tube across the cylinders , then put a 4 branch inlet manifold bolted onto the tube ..oh you could not write this stuff.
Last Edit: Aug 13, 2020 18:41:25 GMT by ivanhoew
Aug 13, 2020 18:30:08 GMT
I can´t leave anything alone...
Aug 13, 2020 18:36:13 GMT
that looks lovely horrido .
Aug 13, 2020 19:17:19 GMT
gave me a cluster tingle...very nice!
Aug 13, 2020 19:39:07 GMT
I can´t leave anything alone... Best yet!
Aug 13, 2020 19:53:45 GMT
isn't that Cruella De-vil's car
Last Edit: Aug 13, 2020 19:54:13 GMT by duggers
Aug 13, 2020 20:39:42 GMT
more NASCAR silly ideas
Aug 13, 2020 21:08:27 GMT
Calming it down a lot, I've added a fastback behind the existing bodywork so there'd be minimal disruption to the door shuts etc. It's all gone a bit Renault 6 though.
Aug 13, 2020 21:14:21 GMT
Needed less boring wheels
moglite
Club RR Member Number: 144
The Temptressmoglite
@moglite
Club Retro Rides Member 144
Aug 13, 2020 21:47:33 GMT
Very brave and brilliant left field project - I doff my cap. Loving horrido 's photochops - they'd work well. But if modifying the roof line could be tricky - just alter the rest of the car to bring the roof into proportion. Four wheel steer from the League of Extraordinary Gentlemen should do it nicely. You might want to skip the detailing from the movie car though.
Aug 13, 2020 21:51:44 GMT
That could start a new genre-Nemo style, at least the captains hat would be appropriate
brc76
Aug 13, 2020 22:05:30 GMT
Calming it down a lot, I've added a fastback behind the existing bodywork so there'd be minimal disruption to the door shuts etc. It's all gone a bit Renault 6 though. That's a bit Daimler Majestic isn't it?
Aug 13, 2020 22:15:11 GMT
yeah it's not great, the back of those always looked too flat,
brc76
yeah it's not great, the back of those always looked too flat, Maybe it's me, I always think town mayor when I see one.
Right !
todays mission if i choose to accept it , is to get the 2 ton head off , and try to drag i out without killing myself .in the rain .maybe some head pics this evening .
That's starting to look like a factory concept for a Mk II Hurricane. I really like that, but much work!
I have no photoshop skills, but maybe some-one can take this into another rabbit hole by keeping the high roof line but adding a Landaulet rear?
Edit: I've just noticed the re-aligned rear lights as well! Most excellent touch!
Last Edit: Aug 14, 2020 12:05:47 GMT by theoldman
Aug 14, 2020 12:02:06 GMT
Coupe is just perfect...but i am suprised that someone more tech savvy than i (not diffucult) hasn't offered a chopped fastback photoshop , i think it could really work!
Aug 14, 2020 13:26:12 GMT
I love the idea of this build, whatever it ends up being it will be sure to stick out anywhere, and I love how its captured peoples imagination
Aug 14, 2020 14:52:42 GMT
I thought id have a go at keeping it 4dr, loosing the rear window, reprofiling the roof and rear pillar, doing the 2tone and slamming it. It hasn't come out as well as my idea thought it would, but you can have it anyway.
Aug 14, 2020 14:57:44 GMT
Complete roof transplant from a Bentley...as I'm sure you have one handy...
