Oct 28, 2007 19:07:34 GMT
Was on my way to the NSRA swapmeet this morning doing about 85mph down the M1. Just before the Meadowhall junction there was a large bang, the car dropped and I skidded across 3 lanes luckily missing everything and pulled in the hard shoulder. The O/S rear tyre was flat. I wasn't risking getting mown down by a passing car so I drove off the motorway to change the tyre. This is the one that came off. Its a tubeless tyre with an inner tube in. The tube has gone and took most of the sidewall with it. Few pics from earlier when I took it out of the car. Check the size of the split in the tube!!!!!!!!! That wasn't the end of it as the spare went flat too after about 5 minutes. I stopped at a garage and its currently got about 45psi in and its not gone down lol. Matt
Oct 28, 2007 19:12:31 GMT
Check the date code I bet that tyre is at least 15 years old!!!
Lucky lucky man
Resident Toyota Geek Current Fleet: HDJ81 Landcruiser, GZ20 Soarer, JZX81 Cresta
mowzer
Oct 28, 2007 19:14:42 GMT
I have heard of tyres with tubes doing that before at speed Its something to do with heat build up of I was told Glad all was ok tough mate
Last Edit: Oct 28, 2007 19:15:15 GMT by mowzer
Oct 28, 2007 19:15:46 GMT
Yep I checked them all they're all fairly old but they're not cracked and still fairly supple. Good enough reason to put the alloys on though.
Matt
Oct 28, 2007 19:19:41 GMT
Yikes Definatly using mine at crusing speed then Why were you running tubes? They don't look particularly stretched?
Last Edit: Oct 28, 2007 19:26:57 GMT by HoTWire
Mr S
10-4 Good buddy.
Oct 28, 2007 19:20:41 GMT
Yikes! Glad you made it out the other side ok!!
Oct 28, 2007 19:27:20 GMT
I didn't realise I was lol no way to check without taking the tyres off lol.
Matt
Oct 28, 2007 19:30:49 GMT
Good to hear you're ok! cptsideways - where do you look for the date code on a tyre, I think this could be some valuable info for everybody! I was under the impression that anything over 5 years old and your pushing your luck.
berendd
Oct 28, 2007 20:48:44 GMT
en.wikipedia.org/wiki/Tire_codehere it is.. the Dot code (department of transportation) is written in 4 numbers of which the first 2 are the wheek and the last 2 stand for the year. you got away there, those tires were years old.
Carter
Oct 28, 2007 21:02:52 GMT
Hells.. glad your okay, and the car aint trashed
'77 Chevy G20
Oct 28, 2007 22:03:54 GMT
Phew, that was a close one! Glad you and the car survived! en.wikipedia.org/wiki/Tire_codehere it is.. the Dot code (department of transportation) is written in 4 numbers of which the first 2 are the wheek and the last 2 stand for the year. you got away there, those tires were years old. Well worth remembering, when we had a wheel nicked off Mrs JS's Vectra the Police used the code to prove a wheel recovered from the local thief was ours!
My fleet: Suzuki GSX-R600Y SRAD with bald, melted tyres A borrowed Mondeo
sav
Oct 28, 2007 22:40:34 GMT
Nasty one that, glad it tuned out ok for you.
Would having a look at the valves be sufficient enough to tell if it's been tubed or not?
Duno whats the difference?
Matt
Sh!te dude, glad your alright!
It made a right mess of the tyre, scary stuff.
The valve on a tube is the same thickness all the way down the part that you can see and simply sticks through the hole in the rim. A tubless valve "mushrooms" out as it meets the hole in the rim to create a seal.
Ah right didnt know that will check all the tyres.
Matt
Oct 29, 2007 11:17:53 GMT
F*ck me I didnt know people still put tubes in tubeless tyres, I did know one tyre fitter who did that but now he`s thankfully a florist or something. If the tyre is old maybe this is some of his handywork.
Makes me feel funny to be honest, I`m assuming it`s the Uno, you could have been killed, and I`d previously had the opportunity to weigh the car in, therefore preventing you from having the blow-out. Strange feeling.
Oct 29, 2007 11:32:12 GMT
Tubes go like that even if they are in a tyre designed for them, its one of the reasons high speed blowouts are less common these days, tubless tyres usually go down quite slowly.
Oct 29, 2007 11:39:18 GMT
Yep was in the uno. Rob its not a problem mate you didn't know its not something I usually check for either but will be doing in future.
This was fully inflated 1 second and complete flat the next gonna stick with tubeless tyres from now on i've had one of those go flat on the motorway and it was much safer.
Matt
Oct 29, 2007 11:58:54 GMT
F*ck me I didnt know people still put tubes in tubeless tyres, I did know one tyre fitter who did that but now he`s thankfully a florist or something. If the tyre is old maybe this is some of his handywork. Makes me feel funny to be honest, I`m assuming it`s the Uno, you could have been killed, and I`d previously had the opportunity to weigh the car in, therefore preventing you from having the blow-out. Strange feeling. you virtually sold its as spares repairs... Twist of fate indeed, the biggest twist being that noone or anything was harmed Amazing isn't it, there seems to be a reason for everything... ...Might be different is some slow reaction joe public bought it of the lot... Wierd The van was a time bomb with bumpy tyres, no brake pads and wobbly suspension, both me and 'her dad' are lucky to have gotten away with that!
