Jul 26, 2020 17:25:59 GMT
anyone know where to get extended wheel studs from? i need m12 x 1.25 with a 12.4(ish)mm spline for my hillman avenger.
as a couple of alternatives i've come up with,
drill hubs for 14mm spline stud (no way of re-splining the hubs though)
use m12 cap head bolts bonded in (a good fit without touching the splines already there)
use wheel adapter/spacers (would need to make a spigot ring for the rears as there isnt one at the moment)
any thoughts on the above?
thanks
Jul 26, 2020 17:42:27 GMT
anyone know where to get extended wheel studs from? i need m12 x 1.25 with a 12.4(ish)mm spline for my hillman avenger. as a couple of alternatives i've come up with, drill hubs for 14mm spline stud (no way of re-splining the hubs though) use m12 cap head bolts bonded in (a good fit without touching the splines already there) use wheel adapter/spacers (would need to make a spigot ring for the rears as there isnt one at the moment) any thoughts on the above? thanks I bought mine from Rally Design
Jul 26, 2020 19:37:29 GMT
ferny
Club RR Member Number: 13
wheel studsferny
@ferny
Club Retro Rides Member 13
anyone know where to get extended wheel studs from? i need m12 x 1.25 with a 12.4(ish)mm spline for my hillman avenger. as a couple of alternatives i've come up with, drill hubs for 14mm spline stud (no way of re-splining the hubs though) use m12 cap head bolts bonded in (a good fit without touching the splines already there) use wheel adapter/spacers (would need to make a spigot ring for the rears as there isnt one at the moment) any thoughts on the above? thanks I'm pretty sure the hub holes aren't splined when drilled, just plain holes. The studs force the spline into the hubs. Some balljoints fit like that too.
