Jan 13, 2022 12:45:47 GMT
modelled up a quick bracket lunch time to hold the bearing for the steering, will bolt up to the back of the front suspension as I handily put some 12mm holes in it, just need to screw cut some bar to screw in the back and a nut to lock it all in place and this can give it some adjustment
Last Edit: Jan 13, 2022 12:46:53 GMT by atomman
Play'in round with an old Datsun & a Ford COE
Jan 13, 2022 13:44:56 GMT
A water jet comes in so handy ! can take this back and try it later and get the right measurement for the shaft now
Jan 13, 2022 18:01:56 GMT
Bit of TiG and screw cutting tomorrow and should be sorted
Last Edit: Jan 13, 2022 18:04:43 GMT by atomman
Jan 14, 2022 12:25:01 GMT
Great read. You have some great skills and access to some great kit too. Like the way this build is going and it's given me some inspiration to crack on with my long overdue project
Jan 14, 2022 20:03:51 GMT
Great read. You have some great skills and access to some great kit too. Like the way this build is going and it's given me some inspiration to crack on with my long overdue project I'm so happy you can take some inspiration from my build , I find it's a lot of up a down with big projects, sometimes you just need something to push you or maybe just do something else on the project for a change, like wiring with me instead of welding, I used to watch a Petrolicious video of a Datsun 240z every time I got fed up with my 240z project , must of watched it a hundred times, Managed to get the screw cutting done today will tack it together tomorrow and see if it's all smooth
Jan 15, 2022 17:43:03 GMT
started making up the loom for the headlights today , I'm gonna use the marker lights on top of the wings as the front indicators I reckon and change out the orange bulbs for some white ones, from what i remember you cant use orange on the front facing lights ? but the roof lights are orange anyways, So maybe I just imagined it?
Last Edit: Jan 15, 2022 17:47:38 GMT by atomman
jamesd1972
Club RR Member Number: 40
1954 Ford C-600 COE truckjamesd1972
@jamesd1972
Club Retro Rides Member 40
I think you have to have white side (think marker might be the correct term) lights to pass MOT but additional lights in orange are ok. Could use the original side lights under the headlights for this or even as a DLR with a suitable 21w equivalent LED white bulb ? Have the headlights got indicator sides etc all built in ? Coming on really well, pro level build from where I’m sitting for sure. Enjoying just watching the journey. James
Jan 17, 2022 10:47:17 GMT
thanks James, I don't know about Pro but I'm trying .
The head lights have a halo side light, but no indicator. so I'm gonna use them and the original ones underneath, I have ordered some white LED bulbs for them , see how it looks.
Jan 17, 2022 11:25:39 GMT
Marker lights became mandatory after sometime in the 80's I got caught out on this when fitting older second hand wings without the to my 87 range rover.
Jan 17, 2022 15:17:42 GMT
Marker lights became mandatory after sometime in the 80's I got caught out on this when fitting older second hand wings without the to my 87 range rover. No, that's turn signal repeaters. White side lights, orange indicators to the front, post 1965. Slightly gray in the term, but a vehicle "first used in the road" pre- September 1st 1965 can dispense with the orange altogether and just run white side with white indicator in the same lamp housing. Ditto red/red to the rear. If it's issued an age-related plate for '54 then you can pass with the American light fixtures. You are allowed orange lights all the way down the side of the vehicle. You have the option for them to flash when the indicators are switched on that side, but they must be in phase with the indicators (ie not wired from indicator+ to side+ so when the indicator is on the side markers are off). You may have red to the side behind the rearmost wheel as the last lamp but orange is recommended to the side.
Last Edit: Jan 17, 2022 15:33:07 GMT by PhilA
Jan 17, 2022 15:49:34 GMT
Cheers PhilA
I was gonna use the red rears as indicators but thought against it, I'm going to use Orange in the bed ends as most people these days wouldn't think I was indicating if they were red ,
Jan 17, 2022 16:17:11 GMT
Cheers PhilA I was gonna use the red rears as indicators but thought against it, I'm going to use Orange in the bed ends as most people these days wouldn't think I was indicating if they were red , Sensible, know your audience. Phil
Jan 17, 2022 17:24:30 GMT
I seem to remember there was somewhere doing Green LED bulbs that flashed orange when fitted inside a red lens.
Jan 17, 2022 20:34:57 GMT
I seem to remember there was somewhere doing Green LED bulbs that flashed orange when fitted inside a red lens. Tried it, just looks dim and dirty red-ish with fully dye mixed red PMMA lenses. It all depends upon the thickness of the red- if the lens itself is all orange with a red lacquer it kinda works. But, overall, no. Phil
mk2cossie
Club RR Member Number: 77
1954 Ford C-600 COE truckmk2cossie
@mk2cossie
Club Retro Rides Member 77
Jan 17, 2022 20:42:00 GMT
I have Amber LED bulb replacements in my rear light clusters. But the difference there may be that mine are amber lenses, sprayed with red lens tint spray Also, isnt there some silliness about having either all amber indicators, or white front with red rear? (And yes, I know the cut off year is 1965 for MOT purposes, but I've no idea what category or fun and games this CoE build is aiming for)
Jan 18, 2022 11:36:13 GMT
I have Amber LED bulb replacements in my rear light clusters. But the difference there may be that mine are amber lenses, sprayed with red lens tint spray Also, isnt there some silliness about having either all amber indicators, or white front with red rear? (And yes, I know the cut off year is 1965 for MOT purposes, but I've no idea what category or fun and games this CoE build is aiming for) No, you can have amber to the rear and white to the front before 1965. Before then the front and rear lighting regs weren't unified so you can technically mix and match so long as the individual requirements are met.
Jan 19, 2022 10:07:23 GMT
Made another dash panel this morning with the gauge holes moved to a better location, thought I'd have a go at a turned finish, like you had back in the day, So I turned a bit of ally down and cut up a scotch pad I had lying round, a bit of super duper glue and some WD-40 on the plate, a pillar drill and it looks ok,
Last Edit: Jan 19, 2022 10:08:08 GMT by atomman
Jan 22, 2022 16:13:42 GMT
Still working out loom lengths today but did put the gauges in the dash panel I made, I need a heater down the workshop in this cold weather , its alight when I'm welding and grinding stuff but this wiring stuff sitting down makes me cold ,
Jan 23, 2022 18:23:02 GMT
forgot i took this to work last week and TiG'd it all up , looks like it does the trick , need to beef up the rack mounts next as i made them thin to bend them into the right shape , and stick some gussets on there , my mate next door pulled this out of his unit , to be honest i forgot he had it as he's only used it once or twice , pretty RaD though took it up and down the road , doesn't drive that low though unfortunately also thought about getting a Flying B for the bonnet as its already got a hole in there , or maybe one of those 50's fly deflector kool things , the flying b's don't come cheap so thought I could make one instead , went though the scrap bin and found some 3mm 304 offcuts cut out 2 and then bumped them on the folder , TiG'd them together bit of filling and polishing and came out like this , Not a B but looks like the PLayer's logo , which would be pretty kool for the show I reckon I have also ordered some more bits from the states today an interior light, starter button and some little clips etc just to finish things off in the cab properly
Jan 23, 2022 22:27:08 GMT
Loving that hood ornament
