Cheap and cheerful Fiesta 1.25 Zetec from 1999 with 125k miles.
Came to me with a high idle and a leaking rear wheel cylinder, Diagnosed and fixed the high idle in 5 minutes It was a split vac pipe under the manifold... now it runs like a top.
I will change the leaking rear wheel cylinder this weekend so it’s mechanically up together.
3 of the tyres are on/over the limit so I’ll keep an eye out and fit good tyres or another set of ford rims and tyres and sell it for the £200... unless someone’s got a set ford rims and tyres lying around and wants the car in which case they can come and fit and take the car away for £150.
Only other thing wrong with it is a big crack in the windscreen, my insurance won’t cover me to replace this, but most do for about an £80 excess... so a job for the new owner.
The government are giving everything a 6 month MOT extension... so this little gem now has MOT until 27/01/2021, so if someone wants a cheap reliable runabout then this could be the one for you.
Car is located at my workshop just off Junction 21 of the M5, south of Bristol.
Please see the pics below... call on text me on 07915643495.
