thomfr
Head gasket or a cracked head? Exchange it for a 1.8 or 2.0tr Ford Focus (built till 2012or so). Very dull but no flimsy stuff to go wrong.
Great work on that LT! Deep bow and respect!
Thom
73' Alfa Giulia Super 64' Volvo Duett 65' Volvo Duett 67' Volvo Amazon 123GT 09' Ford Focus 1.8 06' Citroen C4 Exclusive
My experience is that as a general rule most petrol, non turbo, non direct injection cars are pretty reliable. (But often somewhat dull to!)
My experience is that as a general rule most petrol, non turbo, non direct injection cars are pretty reliable. (But often somewhat dull to!) Trying to find something that meets that criteria is blooming hard! Even if you go direct injection. We are trying to find a modern (2015 or newer) 5dr hatchback for my Mrs and just about the only thing we can find (that she doesnt hate) is the Suzuki swift.
thomfr
Mazda?
75swb
Beta Tester
Club RR Member Number: 181
If you do then expect the mirror motors to break, and their paint is apallingly soft also. Drive ok though
Jun 11, 2023 17:49:09 GMT
Hi Dan, Great work as always and ingenuity with the hacksaw. I seem to struggle these days thinking outside the box. You often have to step back and look for solutions instead of problems. All the best, Norman Nice work as always, hopefully it’s just something simple that’s gone wrong with the Vauxhall. If not I can always do you a good deal on a Jaguar. Love how you come up with left field solutions like that hacksaw trick. Great to see an update; good luck with the Vauxhall. Dan, maybe a simple test for combustion gasses in the coolant would rule out a head gasket? I’m think of the test strips you dip in the coolant. Knowing sweet-nothing about this particular engine, I’d nonetheless be suspicious of the oil-to-coolant oil cooler, or maybe just it’s seals. A left field analogy, but Porsche 944 engines suffer from that. Best of luck, John Sounds like headgasket to me, if it was the oil to water cooler you would get oil in the water when it's running and water in the oil when you turn it off. With the head gasket the combustion pressure opens it up. I continue to learn from you. Things like referee leverage with the junior hacksaw frame. We all do little hacks like that, but you keep reminding and showing us what can be done. Amazing work as always. Head gasket or a cracked head? Exchange it for a 1.8 or 2.0tr Ford Focus (built till 2012or so). Very dull but no flimsy stuff to go wrong. Great work on that LT! Deep bow and respect! Thom My experience is that as a general rule most petrol, non turbo, non direct injection cars are pretty reliable. (But often somewhat dull to!) My experience is that as a general rule most petrol, non turbo, non direct injection cars are pretty reliable. (But often somewhat dull to!) Trying to find something that meets that criteria is blooming hard! Even if you go direct injection. We are trying to find a modern (2015 or newer) 5dr hatchback for my Mrs and just about the only thing we can find (that she doesnt hate) is the Suzuki swift. If you do then expect the mirror motors to break, and their paint is apallingly soft also. Drive ok though Firstly, sorry for the late replies. I do like to try reply to everyone that's taken the time to comment, but for some reason, this week has been so busy in all areas of life that I've only just found the time to do so. norman , Morris63 and grizz .......thanks chaps 👍. for some reason, I struggle to use a junior hack saw in it correct state. I always end up bending, twisting or snapping the blade. Hence why this particular hack saw handle was just sitting there ready to be put to a different use. austinpowers ....thanks mate, as for the Vauxhall, it was never going to be good news.....after all...I own it! 😭😭. The thought of me owning a Jag is both delightful and terrifying at the same time. I would love nothing more than to waft around in one....but would be in constant fear of something very expensive going wrong with it. I know the Vauxhall is worlds apart from a Jag.....but at least I'm to fix it myself relatively cheaply........okay.....ignore the 'cheaply' bit......I'm lying!😁😁 jjeffries I was advised buy a few full time mechanic mates to do a combustion gas test. But....in my haste to find the root of the problem, I had already removed the water pump and other cooling related parts. The kits for that my mates were on about require the car to running....so that was out of the question buy that point. A lot of people, including my mechanic mates, keep coming back to the oil-to-coolant oil cooler. Thing is, I had the oil-to-coolant oil cooler go on my BMW and there was no over heating involved?? So I've been doubtful about that diagnosis. But saying that....I'm so far into the engine right now, that I'm going to replace the oil cooler as a matter of precaution 👍 kevins and thomfr Head gasket or the cam chain cover gasket was my thoughts.....although a cracked head is also a real possibility. These engines have a big gasket that seals the cam chain cover against the engine block. The water pump sits in the cam chain cover and the water and oil channels also pass through the gasket. They are well know for causing trouble apparently. When I removed the water pump, I sprayed a load of Fairy Liquid into the water pump recess and put the air line down the dip stick hole. When I let the air in, a lot of bubbles appeared at the water pump recess. Now.....this still could be either a head gasket oil to water channel issue....or the cam chain cover gasket. Because the cam chain cover gasket sits behind the cam chains ( brilliant idea Vauxhall !!! ), all of the cam chain assembly has to come off. Once you've done that, you're half way to a head gasket renewal. So.....I've decided to go the whole hog and do the head gasket and anything thing else along the way. thomfr .....a very good friend of mine swears by the older Ford Focus. To be fair, the example he has owned for many years has never let him down...it just seems to keep going! thomfr , kevins , joem83 and 75swb I thought I'd hit the nail on the head with the Meriva where reliability was concerned....but clearly not. The earlier Ford Focus does have a good reputation for reliability, as does a lot of Japanese motors......if they're not diesel. My dad bought a brand new Mazda E2000 van back in 1991. It was a 2ltr petrol. It never let him down once.....ever. He finally let go of it in 2019....a few years before he passed away. Even then it was still going strong. The big problem was that the body was crumbling away at a rate of knots....even worse than the my LT!!!! on the other hand....another good friend of mine had a Mazda 5 people carrier. It was a 2ltr turbo diesel. In his own words......it was the most unreliable p.o.s he's ever owned??? ( big problems with the D.P.F ) Thanks everyone 👍 Dan
Opel Commodore A Coupe Opel Rekord C Coupe Opel Rekord C Saloon Vauxhall Magnum Coupe V8 (Magnumania) Mk1 Scirocco GLS Mk1 Scirocco GLS (early chrome bumper) Corrado G60 Mk1 Cortina 2 door Pre Airflow Mk2 Escort 1300 2 Door VW LT35 Tipper Truck BMW 320D E91 Tourer
Jun 17, 2023 17:48:22 GMT
So.....time for another update I thought. Thing is, the PC had the same idea the moment I switched the blooming thing on. So 45 minutes later, the P.C is now refreshed and useable once again! Now.....this update is fairly significant. It brings to an end the mountain of welding and fabrication work carried out on this truck. Knowing the date at which I started taking the truck apart for the big 'weldathon'....( page 8 of this thread )....about mid way through, I thought I would challenge myself to get it all rust free in 2 years.....or there about. So....did I do it? .........lets find out........ Next on the hit list was the drivers side seat mount. It looked okay...ish from the top....... But from underneath........ So off it came.....to reveal more rust...... A new panel was made. I got over excited with the folder and made one of the channels too long. So I corrected it as best I could. I wasn't too worried about the small details on this panel as it was going to be covered buy a mat on the top and stone chip underneath..... Then weld it in....... Then clean up and reinstate the seat mount...... For next bit.....I'll let the pictures do most of the talking. The weld spots you can see on the back of the cab is where there was once a dent. I popped the dent out, but the metal was stretched. So one technique I use to shrink the steel back into place, is to hit it with the welder and cool it straight away with the air line. It works a treat.....but you must be careful not to over do it!! ..........and there we have it........all the welding DONE!!!!!!!!! So......did I hit my deadline of years? .......dam right I did..... 2 days early!!!! This picture, from page 8, was taken on the 31.08.2020..... ....and this one, of the truck rust free and all welding done, was taken on the 28.08.2022...... I was super happy about being able to put the welding torch down for a while. Of course, there's still the rear bed to fabricate, but for now, it was time move onto the next stage. .......which I'll show you next time 😁😁 That's it for now.......more soon. Thanks for looking in, Dan
Jun 17, 2023 18:46:23 GMT
Stirling work. It’s amazing how long these things take. I’ve been doing my Escort for over a year and I only wanted to weld a patch in the floor.
Jun 17, 2023 18:57:23 GMT
Superb. You sir can feel extremely proud of what you've achieved. Well done!
Jun 17, 2023 20:51:19 GMT
Fantastic work Dan, what a milestone
Ich habe kein Geld!
Norman
Jun 17, 2023 22:11:02 GMT
Hi Dan, That IS a milestone, hope I can achieve it before I snuff it. Great fabrication skills as always, looking forward to the next instalment. Norman
Jun 17, 2023 22:22:24 GMT
All that work in just two years, alongside everything else life throws at you is pretty darn impressive. 👍👍
tofufi
South West
Fab work! (Sorry...) And what a milestone
Great achievement, one still a distant dream for me.
Knowing your personal/work schedule as a senior team member, and all the responsibilities you have away from this thread, I think you are a whole lot better and quicker than this timeline implies.
Amazing work all the way, and we all know you improved massively over the two years, however, the work you started out with is amazing. So once again, the whole job to date is incredible.
The fact that you chose to restore the truck you did, adds even more credibility to it all.
Well done Dan, we certainly doff our collective caps to you, or is that at you.
teaboy
Make tea, not war.
Amazing work all the way, and we all know you improved massively over the two years, however, the work you started out with is amazing. So once again, the whole job to date is incredible. The fact that you chose to restore the truck you did, adds even more credibility to it all. Well done Dan, we certainly doff our collective caps to you, or is that at you. I have been thinking about what to write about this milestone but I think grizz has hit the nail on the head. Fantastic job dude.
Jun 23, 2023 20:31:07 GMT
Stirling work. It’s amazing how long these things take. I’ve been doing my Escort for over a year and I only wanted to weld a patch in the floor. Thanks 👍🏻......when I first started all of this, it was only meant to be a few patches and a tidy up for the MOT. It's funny how these things escalate! Superb. You sir can feel extremely proud of what you've achieved. Well done! Thanks Dave 👍🏻.....it was certainly good to know the rust is out and the welding has come to an end.....for now. Fantastic work Dan, what a milestone Thanks 👍🏻....onwards to the next milestone. There's surely got to be a least one more before it's anywhere near finished 😁 Hi Dan, That IS a milestone, hope I can achieve it before I snuff it. Great fabrication skills as always, looking forward to the next instalment. Norman Thanks Norman 👍🏻........I think we're all on the side of hoping you can finish your build and enjoy it way before....as you say....you snuff it! 😁 All that work in just two years, alongside everything else life throws at you is pretty darn impressive. 👍👍 Thanks Glen 👍🏻....yeah, it's not been easy. It actually feels like a lot longer than two years. Unfortunately, due to different things ( real life ) ....progress slowed down quite a bit not long after this. I'm still chipping away it though! Fab work! (Sorry...) And what a milestone 😁😁.....thanks Jim 👍🏻 F.A.B.....wasn't that something to do with International Rescue..🤔 I could of done with them right at the start! 😁😁 Great achievement, one still a distant dream for me. Thanks 👍🏻.....keep going like you are, and you'll be there in no time. That little van of yours is coming along a treat! Knowing your personal/work schedule as a senior team member, and all the responsibilities you have away from this thread, I think you are a whole lot better and quicker than this timeline implies. Amazing work all the way, and we all know you improved massively over the two years, however, the work you started out with is amazing. So once again, the whole job to date is incredible. The fact that you chose to restore the truck you did, adds even more credibility to it all. Well done Dan, we certainly doff our collective caps to you, or is that at you. Thanks Rian....I really appreciate that 👍🏻. It was certainly very challenging at times. Progress has slowed up this year, as I've had a whole mountain of other stuff to catch up on. Plus, I've tried to spend more time with the family as they've seen very little of me over the last two years. All I've got to do now is paint it and put it back together.....Am I right in thinking that's the easy bit?? Amazing work all the way, and we all know you improved massively over the two years, however, the work you started out with is amazing. So once again, the whole job to date is incredible. The fact that you chose to restore the truck you did, adds even more credibility to it all. Well done Dan, we certainly doff our collective caps to you, or is that at you. I have been thinking about what to write about this milestone but I think grizz has hit the nail on the head. Fantastic job dude. Thanks Mr Tea 👍🏻..... appreciated as always. I'm always lost for words whenever I read through your thread! I've got to say though, as much as I enjoy fabrication and welding....it was nice to put the hammers and welder into hibernation....for now.
Jun 24, 2023 17:45:16 GMT
Right....for anyone that's interested....I think I've found the problem with my everyday car. Quick recap.... I was getting oil and air in the water system.....but no water in the oil. The car would over heat/ boil over once up to temperature. A lot of the symptoms pointed towards a head gasket. so.....I just took the whole thing apart looking for the problem.....including taking the head off.... After all that.....there was still no real sign of what was causing the problem!! The head gasket looked fine.....there was no evidence of any breach between the channels or cylinders. The cam chain gasket didn't look too good.....but again, nothing obvious. When I took the oil cooler apart, I had the first sign of something a miss. The rubber seal between the oil cooler and the oil filter housing was all chewed up and twisted. I cleaned up the oil cooler and stuck an air line in it and pressurized it.....but no leaks? So....maybe it was just a bad oil seal between the oil cooler and filter housing I thought. Turns out, this was an issue caused by something else. Now.....when I took the turbo off, I checked it for play etc. I'll put my hands up and say, I'm not a turbo expert....so I don't know what's an acceptable amount of play. Plus, when I took the lower boost hose off, about two cups of oil poured out of it. This lead me to think that the turbo was knackered. So off to the local turbo specialist for a rebuild. but when I got there, I was told by the very helpful chap who ran the place, that my turbo was in perfect condition and that I be wasting money on a rebuild. So of I went again with concern as to what was going on here.......and then it came to me! Once I got home, I checked to see if my theory was right......and lo and behold....I was on the the right track. It turns out, the problem was a one-way valve in the inlet manifold. It lets oil vapour pass through from one side of the inlet manifold to the other on tick over, when the engine is relying on vacuum. Then, when the turbo creates pressure, the valve closes and recirculates the oil vapour to just in front of the turbo air intake. But......the valve on mine had broken and disappeared!! Causing the turbo to create excess crankcase pressure, which in turn blow a the rubber gaskets between the oil cooler and filter housing, and forced oil out of the turbo oil rings! It's been an absolute headache....but hopefully I'm on the right side of it now. Anyway......enough of that.....that's not what we're here for 😁😁 In my last update, I showed how the welding had come to an end. Which meant, it was time seal it all in with epoxy. Now....I took a week off work to get this next bit done as it was heading toward Autumn and I wanted to get some paint on it. I spent 4 days cleaning, degreasing, keying up and prepping the inside and underneath of the cab ready for paint. It was with out doubt the most boringly painful part of the restoration yet. So boring....that not a single picture exists of this process. All I can offer you is the result!........epoxy and seam sealer..... Then on with some stone chip. My preference is Dinitrol 447 as it's rubberised and sticks like the proverbial to a blanket. It's not cheap....but it's the best I've used....and I've used a few disappointing products in the past. ......and once all that was done....there was only one thing left to do......2k acrylic top coat.....in white... While I was there.....I masked up the engine bay and painted satin black ( rattle can )....... One thing I was really pleased about was, there is absolutely no filler used anywhere while completing this bit. There are a few small imperfections, but its all going to get covered with either sound deadening, floor matts or interior trim. Welll, once again......we come to the end of another update. More soon.....thanks for looking in 👍 Dan.
misteralz
Jun 24, 2023 18:04:04 GMT
That is looking fantastic.
Norman
Jun 24, 2023 18:16:34 GMT
Looks great Dan, you must be pleased. Great attention to detail which shows up in the finish. All the best, Norman
