Oct 24, 2007 21:12:46 GMT
ok people here is the story . after a half an hour conversation with an elderly lady that owns the car . the car is kept in a hangar , its been off the road for a few years but been moved around ,engine has been ran regularly . again engine is running and there are no known mechanical problems . been declared SORN apparently it needs bodywork in terms of a full respray will find that out when i actually go to view the car . the car is in dark blue ,guessing its the same color as VAMBO"s 240k . i have no idea what engine is in there etc ,from what this lady is saying ,its a "put your foot down and off it goes " kinda beast . i am guessing its v6 of some variety on a RWD basis ? VAMBO(or anyone in the know ) : i would appreciate if you could give me the specs of these cars ?? engine size ,type , management ,transmission etc etc also i could not get a price out of the witches mouth . i would appreciate any advise on what sort of price these cars would go
Snoozin
Toyophile
Oct 24, 2007 21:20:09 GMT
Given it's a 240K, the motor should be an L24, 2.4l straight 6 non-crossflow. Sound awesome with an open exhaust.
Last Edit: Oct 24, 2007 21:20:27 GMT by Snoozin
vambo
Ratrods, Muscle Cars, Pornography and Death Metal!
Oct 24, 2007 21:50:10 GMT
Unless its been converted it a 2.4 straight 6, it runs on mechancal fuel injection, mines on a 6 branch manifold with a big bore stainless system, and as Snoozin says, sounds awsome, they go well to, big 6 is very torquey and pulls like a train. Mines an Auto, but they come in manual to. The interiors are well cool, they get lots of electric extras and there are billions of dials n stuff, real nice late 70s porno style!! good car to mod, as alot of the Datsun/Nissan stuff is very swappable.
any questions giz a shout!
Last Edit: Oct 24, 2007 21:50:39 GMT by vambo
1970 Hillman Avenger 1980 Datsun 240K Skyline 1992 Volvo 240 Torslanda 1992 Toyota Hilux Turbo Bizzle 1995 Volvo 850 T5
Oct 24, 2007 21:59:25 GMT
Straight out of my 1980 Observer's book of cars:
Identification: High-specification two-door four seater coupe introduced in 1978 as replacement for 240K GT and offering lower-cost alternative to 280ZX coupe.
Engine: Frount-mounted six-cylinder in-line with chain driven overhead camshaft and Bosch mechanical fuel injection. Bore x stroke 83 x 73.7mm, displacement 2393cc. Output 95kW (127bhp) @ 5600rpm, torque 182 Nm (132 lb ft) @ 4400 rpm.
Transmission: Single dry-plate clutch and five speed manual gearbox, three-speed automatic transmission optional extra. Rear wheel drive.
Suspension: Front, independent with MacPherson struts, coil springs, telescopic shock absorbers and anti-roll bar. Rear, independent with semi-trailing arms, coil springs, telescopic shock absorbers and anti roll bar.
Steering: Recirculating ball, power-assisted.
Brakes: Discs front and rear, servo assisted.
Tyres: 185/70 HR-14.
Dimensions: Length 4600mm (181.1in), width 1636mm (64.4in), height 1369mm (53.9in), wheelbase 2616mm (103in).
Unladen weight: 1230kg (2712 lb).
Notes: Standard equipment includes electric windows, radio / cassette player, headlamp and rear screen washers, alloy wheels and electronic ignition.
Last Edit: Oct 24, 2007 22:06:30 GMT by angle
vambo
Oct 24, 2007 22:00:55 GMT
Good work!
Oct 24, 2007 22:01:51 GMT
Yep, it's a straight 6 - fuel injection is actually electronic, but it's pretty reliable. Most of the running gear is very similar to the 280z of the same era. They do rust, but nothing that can't be sorted. Watch out for the fuel pipes, as the fuel system is at a fair old pressure, and at that age the rubber hoses will be breaking up, potentially giving a 'fuel fountain' under the bonnet. Vambo - you can get a new front screen still - it's from a place called heated windscreen I think. The car has had a T-bar conversion some time in it's early life - a company called Hurst Hatch did it. It looks like it was a bit of a job to do...
Snoozin
Toyophile
Oct 24, 2007 22:05:43 GMT
^ What an effort that must have been! Looks like a nice tidy conversion though, and a real point of difference for the car.
Oct 24, 2007 22:12:36 GMT
It looks tidy from the top. This is underneath... There's noticable movement in the body when the roof is off - the steering wheel judders in your hands. Some sill reinforcement is on it's way during the refit...
vambo
Oct 24, 2007 22:14:28 GMT
Oops, my mistake, tis indeedy electronic, i knww that, obviously, hah hahh, was just testing you!
dude, do you have a contact number or any details of this place with the windscreen?
The T top looks awsome, very special a total one off maybe, love the glass panels that have been made for it. does it have strengthend sills? how is work progressing on it?
Oct 24, 2007 22:18:01 GMT
Religious!
Wow well its certainly special, and you say they go and handle quite well?
Oct 24, 2007 22:22:25 GMT
The place was www.heatedwindscreen.com. Give them a call - seemed pretty good when I got mine a couple of years ago. The sills on the 240 aren't reinforced, so I'll be dropping some box section along them somehow. A bit of careful planning required... Current status is this: I'm just sorting the rust around the engine compartment, then working my way back. Nothing too bad uncovered so far.
bollock chops !!!! only 127bhp from a v6 with efi sound bit of torque there mind also way too heavy for my liking ,i hate to say i will probably not have this mainly because i have no place to sort the bodywork in the middle of hot welsh winter and also i am not a datsun man after all (will stick with my rusty renaults for now ) i will try and get more info on this ,in fact still want to view the thing and take some pictures for interested people on here . so start creaming yourselves people i will be back ;D
bollock chops !!!! only 127bhp from a v6 with efi Straight 6.
Oct 25, 2007 10:08:09 GMT
bollock chops !!!! only 127bhp from a v6 with efi Straight 6. either way its ghey imo . was probably one of the fastest in its day though
bigrod
Oct 25, 2007 10:56:16 GMT
It looks tidy from the top. This is underneath... There's noticable movement in the body when the roof is off - the steering wheel judders in your hands. Some sill reinforcement is on it's way during the refit... Looks exactly like the Hurst conversion on one of my T/A's. Worked a treat and leaked less than factory fit one's, however they were smaller than factory. Didn't realise they did them for other cars too. Neat addition to your Skyline though!!
If I have to explain, you won't understand. Maximum signature image height = 80 pixels
vambo
Oct 25, 2007 11:20:24 GMT
Thanks for the windscreen info, will check them out.
really into the 240K project you are on with, its gonna make a great car, keep us posted on progress.
I'm not really doing much on mine at the moment as I'm not really using the thing and I'm mainly doing work on my Toyota CROWN and my truck, but will be giving the car a full respray and lowering slightly in the future.
Just incase this helps, apparently Ford Cortina MK4/5 sills fit the 240K!
Oct 25, 2007 16:33:31 GMT
Not sure about the power outputs being quoted - I've got a little plate under the bonnet saying 142HP / 5600RPM. Can't find my camera right now, I'll put a picture on later...
The 280Z engine, which is much the same, but with US emissions control puts out 145HP.
Hard to say how much it actually has, but it'll smoke the tyres in first. Which is big. And clever.
Oct 25, 2007 17:38:08 GMT
Oct 25, 2007 17:47:09 GMT
*CTRL+P, ENTER* I'm off to the loo...Might be some time... *n
vambo
Oct 25, 2007 18:42:25 GMT
Oooooooomphh!!!! and a suggestion of gayness from a Renault owner!! hah hah hah!
