What the engine looks like with everything fitted..
Alternator bracket...
Aug 10, 2020 21:43:26 GMT
So once the engine bits were mocked up and fitted on the spare engine, I transferred it over to the car. I then set about getting the condenser rad fitted. It’s quite small and I was concerned it may not be big enough, but unless I get one made, availability is limited as to what will fit in...
Aug 10, 2020 21:45:45 GMT
With a bit of research, I bought the kit to swage my own pipe fittings, from Latvia for £80, and it only took a week to arrive
Aug 11, 2020 21:53:28 GMT
Looking good! Would be interested to see what you have planned for the control panel and vents
Aug 11, 2020 22:18:14 GMT
So, the next part was to fit the evaporator unit. I was lucky in that this came up on Facebook pages, along with other bits for a t2 camper. It’s ideal in that it a long and slim unit, and fits under the dash nicely. I had to fabricate some brackets, and I made up hoses to suit once it was in place.
Aug 11, 2020 22:19:11 GMT
Aug 11, 2020 22:20:16 GMT
Aug 11, 2020 22:24:46 GMT
elfman
very impressive
Aug 12, 2020 14:18:37 GMT
Nice work. My only concern would be having the drier in the cab. Most a/c systems only have the evaporator in the cab as that is low pressure when running (granted it can go up to 10bar when off depending on temperature). The Drier is in the high pressure side of the circuit so can be up to 30bar when running depending on the pressure switch. Is the evaporator designed for a txv system or orifice tube?
Aug 11, 2021 17:07:55 GMT
Looks like its coming on a treat! Spotted someone else putting air con in a Volvo, this time an Amazon, might give you more ideas,
