Oct 13, 2021 14:02:16 GMT
out of curiosity , can one swap in the discovery tdi box and tranfer box and use that ? The same basic gearbox (LT77) in Defender specification can be made to fit, but requires chassis mods to get the handbrake and front prop to clear, custom props, modifications to make it part time 4wd (or modifications to the front axle to make it permanent 4wd) and thats the historical reason landrover stretched the 88 inch series3 to 90 inch ninety (the moniker land rover ninety was born) but it wasnt enough to fix inclement prop angles, so 90s are actually 92.7 wheel base
Last Edit: Oct 13, 2021 14:04:05 GMT by darrenh
Oct 13, 2021 14:18:21 GMT
i had just come on here to say "wind the boost up" but on reading, thats basically whats happened glad its sorted and performance is back now the obvious cure to your black smoke, is more air, so time the wind the boost up I’m already running 15 psi, which is a jump up from the 10psi stock. I’m more than happy with the way it goes now, and as this pump is only temporary, I’ll dial it back a bit on the fuelling to kill the smoke. When the original pump comes back from Diesel Bob with his patent tweaks, then I’ll play with boost levels if I need to. 😃
mrbig
Semi-professional Procrastinator
Finally caught up with this thread. As always I've learnt a lot and am grateful for you sharing Glen. Fingers crossed the latest works come good and you can have a breather from unforeseen jobs for a while!
1969 German Look Beetle - in progress
Oct 14, 2021 10:06:14 GMT
Got the wheel off last night… With it out of the way (and it was covered in soot from the exhaust, yuk), I could see the back of the wheel cylinder. Hmmm… that might be the root cause of the issue: No idea how I could have missed that. A 1/4 turn to nip it up and it’s all sorted. Then I, obviously, had to clean up all the mess. The twice contaminated brake shoes were, I felt, beyond any worthwhile efforts to clean up, so I took a rumble through the stores and found a replacement set (I did both sides). The nice big hole in the side of the tailpipe shows that the whole exhaust is on its last legs. I also dialled back the boost pin to its original position. That’s cut a lot of the smoke down without noticeably harming the performance, but it’s still smokier than I’m comfortable with, so I think someone has been playing with the fuel screw. I will do my best to get the original pump and injectors off to be reconditioned in the next day or so in order to get back to a known good base point. Regardless, the swap has been totally worthwhile as it’s definitely confirmed the issues with the original pump. Next little job I’ve been putting off for a bit, but that needs doing now that the nights are drawing in, is to sort the headlights. I have Wipac Crystal units on here. They’ve been brilliant. I originally fitted them in 2003, and they were a huge improvement over the basic halogen units I had before. However, 18 years of service has seen them go very cloudy. I did give them a sand and polish 18 months or so ago, which restored them briefly, but they’re looking tired again so I bought a pair of replacements earlier this year. New next to old: So, a few minutes work with a screwdriver saw them swapped and lighting levels restored. 👍
Oct 14, 2021 10:17:10 GMT
Finally caught up with this thread. As always I've learnt a lot and am grateful for you sharing Glen. Fingers crossed the latest works come good and you can have a breather from unforeseen jobs for a while! Thanks mrbig hopefully I can move back to “planned” work rather than “reactionary” now. The list, as it currently stands: 1. Fit new door seals. 2. Cure leak from joint in the riveted seam between roof panel and roof gutter. 3. Get original pump and injectors rebuilt and refitted. 4. Swap manifolds and turbo for 300 Tdi setup, and fit new exhaust. 5. Rebuild spare steering box, and swap over. 6. Fit power steering kit, swapping alternator mount etc. 7. Revise switchgear and wiring for column switches, make a new auxiliary panel for the area around the steering wheel, relocating gauges to where they can be better seen. Fit relays to headlight circuit. 8. Wait for something else to break.
Oct 14, 2021 11:11:04 GMT
i reckon an italian tune up down the A2 would sort out the rest of the particulate issues p.s the void where the governor pin sits (that you freed up) what normally lubricates it? is it air in there, or fuel ?
Last Edit: Oct 14, 2021 11:14:48 GMT by darrenh
Oct 14, 2021 11:58:31 GMT
i reckon an italian tune up down the A2 would sort out the rest of the particulate issues p.s the void where the governor pin sits (that you freed up) what normally lubricates it? is it air in there, or fuel ? I will certainly be exercising that option. 😃 The area is usually lubricated with a finger full of Vaseline or similar.
Oct 14, 2021 12:07:00 GMT
The area is usually lubricated with a finger full of Vaseline Oh my
Oct 15, 2021 17:25:43 GMT
and thats the historical reason landrover stretched the 88 inch series3 to 90 inch ninety (the moniker land rover ninety was born) but it wasnt enough to fix inclement prop angles, so 90s are actually 92.7 wheel base I suppose Land Rover 92.7 didn't have the same ring as ninety.
Last Edit: Oct 15, 2021 17:26:19 GMT by Zebedee
Oct 17, 2021 23:48:32 GMT
The list, as it currently stands: 1. Fit new door seals. 2. Cure leak from joint in the riveted seam between roof panel and roof gutter. 3. Get original pump and injectors rebuilt and refitted. 4. Swap manifolds and turbo for 300 Tdi setup, and fit new exhaust. 5. Rebuild spare steering box, and swap over. 6. Fit power steering kit, swapping alternator mount etc. 7. Revise switchgear and wiring for column switches, make a new auxiliary panel for the area around the steering wheel, relocating gauges to where they can be better seen. Fit relays to headlight circuit. 8. Wait for something else to break. One and two done. Pictures to follow. Door seals aren’t like conventional push on ones like you’d find on most vehicles (although very late Series 3s and 90/110s do have them), oh no, each door has six individual rubber mouldings, each with a steel inner stiffener, and each needing at least five pop rivets to hold them in place. Despite having spent a significant amount of money on a full set of genuine seals, each and every one needs trimming both ends to make them fit properly. The best part of two days it’s taken me to get them all on. You can’t fit the ones to the bulkhead without taking the doors off either, which is a pain in the posterior. Anyway, it’s done, and as I had the riveter handy, and I had to loosen off the side panel to hardtop joint to adjust one of the end finisher/seal holding bits, it seemed like a good idea to drill out the five rivets that had sprung along the join between the hardtop frame and the top skin and replace them with some suitable sealed pop rivets. I did buy a proper aircraft type rivet squeezer to set the original type semi-tubular rivets, but couldn’t find a reasonably priced source of the rivets, and sealed pop ones are probably better anyway. I used some Captain Tolley’s along the visible crack in the seal afterwards, so with luck I’ll have at least stemmed the flow of the water ingress even if I’ve not cured it. Last job job of the weekend was to swap the basic manual controller for the night heater for one that can be triggered remotely. That was a simple plug and play, and means that I can set it off when I get up for work and things should be nice and toasty by the time I’m ready to leave for work. Onwards and upwards. Going to be away for a few days (in the Land-Rover), so fingers crossed it behaves. Catch up when I get back. 😀
Oct 18, 2021 12:17:44 GMT
and thats the historical reason landrover stretched the 88 inch series3 to 90 inch ninety (the moniker land rover ninety was born) but it wasnt enough to fix inclement prop angles, so 90s are actually 92.7 wheel base Likely not the only reason. On leaf sprung utility cars the LWB cab was larger and had more internal room. This is highlighted by the need for a filler plate to go in the gap between the rear bulkhead and a truck cab if you have one fitted. With the 90 they wanted to have the larger cab space of the LWB models and also the same size load space as the SWB. This stretched the body length some to get everything in. Also noticable with the fact that SWB sides are interchangeable with a LWB and 110 Station wagon but not on a 90
Oct 18, 2021 19:02:24 GMT
New headlights: Door seals: The only ones I didn’t replace were the very bottom ones on the front, as they’re way easier to do with the sill bars off, and I have another pair that I want to get re-galvanised at some point. The ones that are on there are ancient, but there’s a bit of life left in them yet. This is how they’re secured: Five of the rivets on this side had let go. Ideally, I’d split the entire joint all the way around, and reseal it all properly, but it’s too big a job to contemplate just at the moment.
Oct 19, 2021 22:25:33 GMT
What are your thoughts on replacing with the modern type of push on seal? I've just done that with the rear door on my Series 3 which is replacing a tailgate. Managed to get it on without having to grind off the lip, so reversible if needs be.
My logic is that a one-piece seal should work better, and was cheaper (in fact free!). But wondered if you had come across downsides (I'm a relative newbie to Series ownership, although not to leaky Land Rovers...)?
Sometimes, others may not understand why you like a car so much. Sometimes, you may not even understand why you like a car so much. But none of that matters; all that matters is that you like the car, and having it makes you happy.
Oct 19, 2021 22:39:25 GMT
The disadvantages of one piece seals is that they are one piece. The original setup, you can swap any part and have any configuration of roof, without having to swap seals around. I’m also surprised that you managed to get a one piece seal on without modifying the folded lip; cutting the return off of every panel, the bulkhead, screen, roof, side and tub, rendering what may otherwise be mint and irreplaceable, and introducing points for corrosion to start on the bulkhead and screen edges, has always been an anathema to me.
Don’t get me wrong, loads of people have done it, but personally I’d sooner have no seals at all (like I have for about 20 years) than chop things up to fit one piece seals. If I had a late series 3, with the right bulkhead, screen and tub for one piece seals, then I’d probably happily trim the hard top parts to suit if I was wanting to fit a different roof setup, but I’d not cut earlier hard to find bits. My bulkhead came from a scrapyard in Australia, at what seemed at the time to be a ridiculous amount of money, and I paid almost as much again to get it blasted, hot metal sprayed, primed, painted and waxoyled. There’s no way I’d consider modifying it. 🤣
Oct 19, 2021 22:51:55 GMT
That's a good point about configurations, hadn't considered taking the hardtop off.
The seal I used had quite a wide channel, but even so needed teasing open slightly to fit. Hopefully the body lip will keep the seal in place, but I'm wary of whether the U channel will provide a path for water to track along in.
Oct 19, 2021 22:54:05 GMT
matfenwick All that negativity notwithstanding, the later seals are probably much better at actually keeping the weather out. 🤣 Just bear in mind, at some point when Series 2/2A/3 prices have climbed to match those of Series 1s, a potential purchaser may look at trimmed seal retainers and one piece seals with horrors and either drop their asking by the cost of restoring them to standard, or walk away entirely. I’ve weighed in panels that have had their edges trimmed because nobody would buy them…
Oct 20, 2021 19:48:20 GMT
I can see what you mean about originality, and everything I've done/will do will be either reversible, or actually bringing it closer to original - although not that I'm thinking of selling.
I'm very envious of yours as unfortunately mine is the opposite of what I'd prefer, as it's been both under and over restored - over restored cosmetically, but under restored mechanically. Gradually working through the oily bits...
Oct 20, 2021 19:51:24 GMT
Nobody could accuse mine of being cosmetically over-restored. 🤣🤣
Oct 20, 2021 20:09:52 GMT
That's *exactly* what I like about it, and how a 'proper' LR should be!
