Hi all
First time post so apologies if I've put this in the wrong place.
I've got a '95 Renault Campus 1.4 which I've just had to swap out the radiator, top hose and thermostat on. When it initially failed it developed a tapping noise when running idle and since I've addressed everything it is still tapping. I've reset the rocker settings and it's still tapping, albeit slightly less. Someone has recommended that it could be the ignition sequence which is causing it but I was wondering if anyone else had any ideas?
Thanks
Thanks
