danhrc
Yeah it not a true coil over kit like my last car but they were a fortune a might just go decent springs and those pads looking for a prox 50-60mm drop all together
Al keep havin a look on ebay and the likes for a decent spring kit
And also a diff at same time Al have to wait tI'll payday tho as spent this month's budget on mine and also the misses car
How are your springs and what sort of drop have you got
Cheers Dan
Apr 10, 2020 19:28:36 GMT
The springs seem great, the usual Eibach (Pro kit), dropped car about 30 mm I think, but I wasn't too concerned as I was adjusting the final height with spring pads. There's also Eibach Sportline springs, they will drop the car by 45 mm, if I recall correctly. There's a photo of the front arch gap back in this thread, that was the height alround. See here. www.eibachshop.co.uk/info-part-list?make=MERCEDES-BENZ&model=C-CLASS%20(W202)&spec=C%20240%20(202.026)%201997-06%20-%202000-05Don't mind the prices, shop around. I got mine for around €150/£120. No doubt you're aware there's other brands besides Eibach so, you might have a look at those, especially when on a budget which I was. I just kept shopping around and leaving searches on eBay. Maybe, do your shocks first as they'll have more ware than the springs (if everything is original) and adjust the height with the spring pads for the time being?
Last Edit: Apr 10, 2020 22:02:53 GMT by Woofwoof
Apr 10, 2020 19:40:53 GMT
Now that this thread is fully up to date and I've no shortage of time I've decided to do a few bits & pieces that I had put on the long finger. 1. Rewire the extra gauges - tidy up of the loom, aux fuse box & relay etc in the engine bay. DONE2. Refurb a spare rear wheel and fit - current wheel is leaking due to a previous poor repair. 3. Engine oil & filter - otherwise it's been recently serviced including all oils, fuel filter & plugs. 4. Finalise the ride height - just waiting on different size spring insulators. 5. Have the car tracking adjusted so the steering is straight - car had a full wheel alignment last month and the st.wheel is now off. 6. Book a N.C.T.(MOT) when the test centres reopen, are all shut up due to C-19. 7. And maybe, just maybe I might even give the car a good scrub... Hopefully, that will be it for this year. Gauges done! One down, six to go... The black junction box has a permanent live feed from the battery, used that and an ignition live from the far fusebox for the relay. IMG_20200410_124633277 by Johnny Slow, on Flickr Used a cheapo stainless steel plate for the gauges ( Oil temp, AFR, Boost/vacuum) and fitted them where the stereo was. Moved the stereo down to where a storage cubbyhole use to be. I've also mounted the OBD, which is handy for live data like IAT, Fuel trims etc and any engine fault codes that pop up. IMG_20200410_124550966 by Johnny Slow, on Flickr
Last Edit: Apr 10, 2020 19:59:00 GMT by Woofwoof
Apr 14, 2020 20:59:51 GMT
Now that this thread is fully up to date and I've no shortage of time I've decided to do a few bits & pieces that I had put on the long finger. 1. Rewire the extra gauges - tidy up of the loom, aux fuse box & relay etc in the engine bay. DONE2. Refurb a spare rear wheel and fit - current wheel is leaking due to a previous poor repair. nearly DONE3. Engine oil & filter - otherwise it's been recently serviced including all oils, fuel filter & plugs. 4. Finalise the ride height - just waiting on different size spring insulators. 5. Have the car tracking adjusted so the steering is straight - car had a full wheel alignment last month and the st.wheel is now off. 6. Book a N.C.T.(MOT) when the test centres reopen, are all shut up due to C-19. 7. And maybe, just maybe I might even give the car a good scrub... Hopefully, that will be it for this year. Wheel refurb. The n/s/r wheel suffered damage (guilty) and the repair was solid but not air tight and needed the pressure checked far too often, probably every week. So, I got a used rim again for cheap via eBay. I gave it a good clean & painted it. I've 8x16's ET36 225/50 on the rear and standard 7X16 ET37 205/55 on the front. Increasing the rear width to 8'' doesn't seem to make any difference, none that I noticed. I just went with the wider wheel because they were an option on the CLK & SLK which use the C-Class chassis, the thinking being if they are an improvement on those models, why not on the C-Class? And hands up, I like the looks of the wider rears anyway. I'm currently using Yokohama Advan tyres, previous it was Bridgestones which I was very happy with but I can't fault the Yoko's. 8x16 IMG_20200407_153923665 by Johnny Slow, on Flickr 8x16 IMG_20200409_092819608 by Johnny Slow, on Flickr 8x16 IMG_20200414_211825566 by Johnny Slow, on Flickr 7x16 205/55 IMG_20200414_212306532 by Johnny Slow, on Flickr
Last Edit: Apr 18, 2020 1:07:36 GMT by Woofwoof
Apr 16, 2020 20:20:07 GMT
The 3 nib/dot front spring insulators arrived at last. I got on and fitted them. Removed the 2 nib one's, this has raised the ride height on the front by 7-8 mm (with a 5mm thicker spring insulator ) bringing it nearer to the rear ride height. Also, this will reduce the negative camber a little as it's slightly excessive by 0.5 - 1.0 degrees. The front is now only 5 mm lower than the rear. Not ideal but it's the closest I can get to having front & rear level, leaving the 2 nib on the front and fitting 3 nib in place of the 4 nib on the rear, left the rear too low. Hard to win, still it's not too bad. Typical spring insulator (on the right) , this one is the old 2 nib, 9mm thick. They're available in 5/9/13/17 & 21 mm. IMG_20200409_161300857 by Johnny Slow, on Flickr Anyway here's a few gratuitous photo's. Thankfully my poor phone camera skills ended up improving the car's looks somehow! InkedIMG_20200416_174934050_LI by Johnny Slow, on Flickr InkedIMG_20200416_174844589_LI by Johnny Slow, on Flickr InkedIMG_20200416_174820433_HDR_LI by Johnny Slow, on Flickr InkedIMG_20200416_174820433_HDR_LI by Johnny Slow, on Flickr InkedIMG_20200416_174820433_HDR_LI (2) by Johnny Slow, on Flickr
Last Edit: Apr 16, 2020 22:57:24 GMT by Woofwoof
Apr 17, 2020 20:22:07 GMT
Now that this thread is fully up to date and I've no shortage of time I've decided to do a few bits & pieces that I had put on the long finger. 1. Rewire the extra gauges - tidy up of the loom, aux fuse box & relay etc in the engine bay. Done2. Refurb a spare rear wheel and fit - current wheel is leaking due to a previous poor repair. partly Done 3. Engine oil & filter - otherwise it's been recently serviced including all oils, fuel filter & plugs. Done4. Finalise the ride height - just waiting on different size spring insulators. Done5. Have the car tracking adjusted so the steering is straight - car had a full wheel alignment last month and the st.wheel is now off. 6. Book a N.C.T.(MOT) when the test centres reopen, are all shut up due to C-19. 7. And maybe, just maybe I might even give the car a good scrub... sort of DoneHopefully, that will be it for this year. Further progress. Oil & filter today. Drove the car a couple of miles to let the front suspension settle and ended up with these settings which were taken from wheel centre to wheel arch. Happy enough even if it would nice to get the rear down by 5 mm or so. Anyway, it will do as I've had enough of removing & refitting springs for this year. N/S/F 345 mm --------- O/S/F 342 mm N/S/R 353 mm ---------- O/S/R 350 mm
juggs
Apr 18, 2020 12:53:17 GMT
Nice little w202 project this & a lot of work put in for what it is. Know the feeling I’ve got a couple of w202’s & my mates think I’m bonkers spending money tinkering with them!
Out of interest what intercooler setup did you settle on, was the boost drop from the aftermarket i/c noticeable when driving ie did it actually feel slower?
Also what kind of figures are you getting from the wideband as it is?
Seen a few people who are running higher boost on the chargers also fitting adjustable fuel pressure regulators to stop them leaning out. That said no one seems to know if they actually are as very few using a wideband to monitor it in the first place
Also did you end up trialing the different MAF sensors again to any success?
Currently cut down the fleet, Pulsar gti-r, sierra v6, E36 328i.. currently looking for crude oil...
Apr 18, 2020 14:07:42 GMT
Nice little w202 project this & a lot of work put in for what it is. Know the feeling I’ve got a couple of w202’s & my mates think I’m bonkers spending money tinkering with them! Out of interest what intercooler setup did you settle on, was the boost drop from the aftermarket i/c noticeable when driving ie did it actually feel slower? Also what kind of figures are you getting from the wideband as it is? Seen a few people who are running higher boost on the chargers also fitting adjustable fuel pressure regulators to stop them leaning out. That said no one seems to know if they actually are as very few using a wideband to monitor it in the first place Also did you end up trialing the different MAF sensors again to any success? Thanks. Yep, too much work put into really, still no regrets. As I said previously, it's a slippery slope but also an enjoyable one. A couple of my mates think the same as your mates but mine go quiet when they can't shrug off the old Merc in their more modern stuff. The I.C. currently fitted is from a C250 TD. Same size as the original one but all alloy, i.e. no plastic end tanks. The far larger I.C. that I tried had a boost drop of 1.4-1.5 psi with better I.A.T.'s. Temps were down by maybe 6-8C and it was taking longer to get heat soaked. There was no noticeable different in power when actually driving (meaningless in a sense as I can't back that up with figures). I just removed that I.C. as I prefer to have the boost pressure and I couldn't get the larger I.C. to fit 100% behind the bumper. It was good bit heavier too being a bar & plate design.. A/F/R's are good. 11's @ wide open throttle. Plug colour always looks spot on as well. When this Covid business is over or there's less restrictions on movement I'll double check the figures and post them up. The new I.C. plus a tested system with no leaks, a new S/C belt (old one was slipping) ,different new plugs and a later T/B inlet may have changed things? I've tried the stock 3.8 and a 4.0 Bar FPR and found no performance gains, the only difference with 4 Bar is that fuel trims change. LTFT is more negative which is not an issue, all it means is the ECU is reducing the fuel amount as it's not required. The only time you'd need to go above 3.8-4.0 Bar is with a smaller S/C pulley, 12-13 psi. I'm only running 10 psi. I reckon the people that do fit a higher FPR or the adjustable type with just a larger crank pulley do so to be safe and accept everything they read on the net or don't read between the lines. Also, since it's so easy and inexpensive to change the FPR they decide it's a good idea. I have the injector flow figures somewhere using different FPR's and according to those figures my engine is very safe with the 3.8 and the gauge AFR's seem to back that up. Hope I'm correct! Yes, as I said in this thread I've had limited success with a BMW E60 M5 MAF. It made a big difference, most noticeable was the increase in torque right from the off. The downside was I need to clear the ECU memory every 250 miles as the S/C wouldn't engage after that mileage. Basically what I think was happening is, the ECU had reprogrammed itself by then and decided it didn't like the MAF voltage ouput signal. I've also got an E39 M5 MAF to try out and then there's two possible MAF locations, the original at the I.C. outlet and where my MAF is currently located near the T/B. I'll get back to the MAF's sometime in the future and experiment, just that this year has mainly been all about getting the suspension right or trying to get it right. Hope that answers most of your questions, just don't take everything I've said as gospel.
Last Edit: Apr 19, 2020 10:44:43 GMT by Woofwoof
Apr 19, 2020 23:31:30 GMT
Pulled the plugs just to check. They look a touch light in colour, I expecting a light brown'ish colour. The AFR's and fuel trims are good according to the OBD & AFR gauge. The plugs are new and they are one heat range cooler with only 175 miles on them. Also, I had the battery disconnected a while back, that sends the ECU into reprogramme mode for engine operating parameters which takes about 250 miles to complete. It's probably best I inspect the plugs again after covering the 250 miles and go from there. What do you think?
Apr 25, 2020 22:05:44 GMT
The stater motor decided it wouldn't engage sometimes without a bit of encouragement from a hammer. Not really surprised as I had the same problem once back in 2016. I shopped around online. What a minefield that was. Between different brands, non brands, power outputs of 1.1-1.3 kw, recon'ed units, new and exchange units. Then the massive difference in pricing anything from £45 to £350! Normally, I'd never bother with all of this and just get the old starter motor reconditioned locally but the C-virus has put paid to that. Anyway, I settled on a recon Hella, recon'ed in China. Just hoping that Hella demanded some reasonable quality from the factory there. It was 52 quid which seems reasonable, some retailers were asking as much as £108 for the exact same motor. I reckoned it was worth the risk and if it packs up I'll get the old starter to repaired. IMG_20200425_223735635 by Johnny Slow, on Flickr So, not a very interesting post I must admit but it does highlight it's worth shopping around if nothing else.
Last Edit: Apr 25, 2020 22:11:11 GMT by Woofwoof
juggs
Pulled the plugs just to check. They look a touch light in colour, I expecting a light brown'ish colour. The AFR's and fuel trims are good according to the OBD & AFR gauge. The plugs are new and they are one heat range cooler with only 175 miles on them. Also, I had the battery disconnected a while back, that sends the ECU into reprogramme mode for engine operating parameters which takes about 250 miles to complete. It's probably best I inspect the plugs again after covering the 250 miles and go from there. What do you think? Agreed they are a little light, but like you say maybe leave it until the 250 mile reset period is over to pull them & check again. I didn’t know that the Ecu on these had that reset function to be honest. I also have a C230 Kompressor but mine is a really early one, as in late 1995 early 1996 build. The one with the metal inlet manifold & cable throttle body if you know the type I mean? Seems mine runs a different Ecu setup among other things & information seems even more scarce regarding tuning these pre plastic inlet M111 engines. I checked my intercooler as well after reading your post , seems that these early ones also have the alloy end tanks fitted so that’s a bonus Not done much to mine so far really bar the usual full service, fuel filters water pump etc. Only aftermarket bits so far is the speer tuning crank pulley & open air box, it made 207bhp with just that though which I suppose isn’t bad for the ease of use. Think the early ones are 190ps or 187bhp I read somewhere. The tiny stock 2.1” exhaust with twin cats & x3 huge silencer box’s can’t be helping but kind of like that it’s whisper quiet of throttle Have ideas of either porting the charger & fitting a solid smaller pulley or potentially a turbo conversion in the future. That said I’m not willing to invest into standalone management & not sure how to effectively fool it or if the stock Ecu can be tailored around boost cuts with a maf clamp / larger maf housing etc. Some people seem to report boost cut / limp mode as low as 11-12psi others report 17psi with no issue so who knows. Thinking that I will get a wideband fitted & some way to measure the inlet air temps before doing much more. My car seems to make around 0.9 bar (measured at the inlet manifold) midrange but tails off somewhat at the top end. Did your car do this as well? Fingers crossed your going to say yes & that the other charger belt you fitted solved this , or perhaps that’s just wishful thinking!? Any more plans for the future on your car as to what direction to go with it? Mine is due a full rear beam overhaul at some point, hopefully a friend with a ramp will be willing to help as it’s doesn’t look fun!
Apr 27, 2020 14:57:21 GMT
Double post.
Last Edit: Apr 27, 2020 15:30:05 GMT by Woofwoof
Apr 27, 2020 15:27:43 GMT
Last Edit: Apr 27, 2020 20:57:45 GMT by Woofwoof
Apr 27, 2020 21:04:16 GMT
Sorry about the Double Posting, not to sure what happened there.
Yep, the earlier cars have a different engine management system, non Canbus too. I don't know if you can reset your ECU ( I think you can), my one resets itself if the battery is disconnected and reconnected for something like 30 mins or it can be reset via the OBD diagnostic port with a Merc Star or similar OBD reader.
Your M111 was 190 BHP/193 PS from the factory, the same as mine. It seems our exhaust systems are different. I've a 2.25''/57 mm pipe, two cats, a central resonator (which has been removed) and a large back box. Supersprint make a slightly bigger system, it really looks the business too, they also make an exhaust manifold but it won't fit R/H/D cars. The only downside is cost. The Cat back system alone is big bucks but by all accounts there's a definite improvement in top end power. I think just fitting a better flowing back box would help things.
207 BHP seems a little low, I'd expect 210 - 215 if everything was in rude health. I had 214 BHP with a failing fuel pump on the first dyno run after having a generic remap done. I replaced the pump, had injectors cleaned and fitted a 4 BAR FPR. The car performed better at the top end but I couldn't get back to the same dyno in Hampshire. Ended up using another place (which will remain nameless) and they dyno'ed it at 231 BHP which was bullsh1te. It's more like 220 BHP. Possibly 225 BHP on a good day but I'm doubtful. Anyway, it doesn't really matter. I'm very happy with the way the car performs for just fitting a larger pulley, remap and the slightly higher FPR.
Anything above 10 - 11 psi boost pressure will require either the ECU to be reprogrammed or a piggyback ECU will be required from what I understand, but you could possibly get away with an adjustable FPR to run up to 12 psi with a milled down S/C pulley. A 6mm reduction is the norm. I wouldn't be surprised if you'd need a MAF clamp as well. I've stuck with 10-10.5 psi as I just don't want the complications to make the engine run safe at any higher boost pressure and as sure as the day is long, higher boost pressures will bring on head gasket failure far sooner.
You're spot on right, get readings first before doing any other modifications. I always keep an eye on fuel trims, IAT's, boost pressure and timing.
As for your 0.9 Bar pressure, I doubt it. More like 9 psi taken from after the I.C., I've my boost gauge plumed into the FPR vacuum line. Yep, I was losing boost pressure nearing max rev's and that was due to a couple of things. I had boost leaks, two small one's at the hose clamps and the S/C belt started slipping. Some new silicone hose, good quality wide hose clamps and a new belt solved the issues. All good now and hitting 10.5 psi @ 6000 RPM which is just before the limiter. Better again I've an instant 7 PSI at the touch of the throttle. If you haven't replaced the S/C belt tensioner I'd reckon it would be a good move to get a new one. Also check the tensioner belt marks and see if it's max'ed out (photo's in this thread).
Ah, being candid I don't know what the future plans are for the car. I know how to improve it further but it all costs and makes it difficult to justify considering the car is worth the price of a Mars bar & a packet of crisps. More weight reduction is one of them. I do have a Water Meth kit which I haven't fitted, that would help but I'm not really too happy about it's control system. I might at some stage buy a new more modern controller and fit the kit. The other item I've been making up is an I.C. sprayer kit, it's almost complete, at some stage I'll fit it. But, what our cars would benefit from is a larger I.C regardless. 25-40% bigger. No power increase per se, it would just help to keep maximum power.
If you're going to overhaul the rear suspension, the most important parts are the lower control arm inner & outer bushes and the front sub frame mounts and them there's no need to pull out the complete sub frame. You're right, doing a full overhaul was a pain, especially if you do like I did, on the ground with just axle stands. Still, I'm glad I did do it, well worth the trouble.
Last Edit: Apr 27, 2020 22:20:25 GMT by Woofwoof
Apr 27, 2020 21:25:15 GMT
others report 17psi with no issue so who knows. I find that hard to believe, I wouldn't pay much attention to those type of claims unless they did a lot of work on the engine. I knew a guy who ran a C200 Kompressor (only 2.0l not 2.3l like ours) with 1.2 BAR boost, close enough to 17 PSI. To run at that boost level he had to fit an AEM piggy back to control a couple of extra injectors and adjust the timing. Also the engine had the full works: ported S/C, large S/C intake pipe, large & small pullies, MAF clamp, modified exhaust system etc. That car put out 265 BHP. So, there will be loads of issues if it's not done correctly.
Last Edit: Apr 27, 2020 22:55:15 GMT by Woofwoof
juggs
Apr 30, 2020 12:52:49 GMT
Sorry about the Double Posting, not to sure what happened there. Yep, the earlier cars have a different engine management system, non Canbus too. I don't know if you can reset your ECU ( I think you can), my one resets itself if the battery is disconnected and reconnected for something like 30 mins or it can be reset via the OBD diagnostic port with a Merc Star or similar OBD reader. Your M111 was 190 BHP/193 PS from the factory, the same as mine. It seems our exhaust systems are different. I've a 2.25''/57 mm pipe, two cats, a central resonator (which has been removed) and a large back box. Supersprint make a slightly bigger system, it really looks the business too, they also make an exhaust manifold but it won't fit R/H/D cars. The only downside is cost. The Cat back system alone is big bucks but by all accounts there's a definite improvement in top end power. I think just fitting a better flowing back box would help things. 207 BHP seems a little low, I'd expect 210 - 215 if everything was in rude health. I had 214 BHP with a failing fuel pump on the first dyno run after having a generic remap done. I replaced the pump, had injectors cleaned and fitted a 4 BAR FPR. The car performed better at the top end but I couldn't get back to the same dyno in Hampshire. Ended up using another place (which will remain nameless) and they dyno'ed it at 231 BHP which was bullsh1te. It's more like 220 BHP. Possibly 225 BHP on a good day but I'm doubtful. Anyway, it doesn't really matter. I'm very happy with the way the car performs for just fitting a larger pulley, remap and the slightly higher FPR. Anything above 10 - 11 psi boost pressure will require either the ECU to be reprogrammed or a piggyback ECU will be required from what I understand, but you could possibly get away with an adjustable FPR to run up to 12 psi with a milled down S/C pulley. A 6mm reduction is the norm. I wouldn't be surprised if you'd need a MAF clamp as well. I've stuck with 10-10.5 psi as I just don't want the complications to make the engine run safe at any higher boost pressure and as sure as the day is long, higher boost pressures will bring on head gasket failure far sooner. You're spot on right, get readings first before doing any other modifications. I always keep an eye on fuel trims, IAT's, boost pressure and timing. As for your 0.9 Bar pressure, I doubt it. More like 9 psi taken from after the I.C., I've my boost gauge plumed into the FPR vacuum line. Yep, I was losing boost pressure nearing max rev's and that was due to a couple of things. I had boost leaks, two small one's at the hose clamps and the S/C belt started slipping. Some new silicone hose, good quality wide hose clamps and a new belt solved the issues. All good now and hitting 10.5 psi @ 6000 RPM which is just before the limiter. Better again I've an instant 7 PSI at the touch of the throttle. If you haven't replaced the S/C belt tensioner I'd reckon it would be a good move to get a new one. Also check the tensioner belt marks and see if it's max'ed out (photo's in this thread). Ah, being candid I don't know what the future plans are for the car. I know how to improve it further but it all costs and makes it difficult to justify considering the car is worth the price of a Mars bar & a packet of crisps. More weight reduction is one of them. I do have a Water Meth kit which I haven't fitted, that would help but I'm not really too happy about it's control system. I might at some stage buy a new more modern controller and fit the kit. The other item I've been making up is an I.C. sprayer kit, it's almost complete, at some stage I'll fit it. But, what our cars would benefit from is a larger I.C regardless. 25-40% bigger. No power increase per se, it would just help to keep maximum power. If you're going to overhaul the rear suspension, the most important parts are the lower control arm inner & outer bushes and the front sub frame mounts and them there's no need to pull out the complete sub frame. You're right, doing a full overhaul was a pain, especially if you do like I did, on the ground with just axle stands. Still, I'm glad I did do it, well worth the trouble. Try to remember everything stated but will fail on most but I agree that the 207 seemed a little low , but saying that 5bhp or so between dyno’s is a variation I can swallow. It drives well & perhaps the tailing off at the top end explains it a bit. I will give the charger tensioner & belt swap a go along with FPR & hopefully return when everything opens back up again. Also could you give me the part number & details for the belt you used & where you got the Ecu done? Out of interest does your later car also have a limiter when on idle of around 4500ish rpm (from memory) & a rev limit when in gear of 5800rpm? Regarding my boost pressure of 0.9bar, that’s what it measured on my gauge & it’s not a cheap Chinese one but does sound a bit high so would like to double check it with another. As I said that’s what it peaks at at a certain RPM point but it does not hold that to the limiter. Approximately what RPM does your car now hit peak boost & what does rpm does it hold it to? Can you not measure your boost from the inlet manifold after the throttle body, my early car had a little nipple with a blank on there just perfect for picking up a feed. So with the modifications you currently have what sort of AFR readings are you getting? Sorry if I’ve made a tuning biased reply I’m just very interested in the potential or possibly lack of with the 2.3k engines. Will PM if that’s better
Apr 30, 2020 15:23:09 GMT
The S/C belt is a Continental Elite (4060555) 1410 mm, a similar design to a Goodyear Gatorback belt. See, a previous post for photo. You can use a standard 6 rib belt too, just make sure it's a good quality one as the belts are under a fair bit of strain. Again, don't forget to check the tensioner, if in doubt fit a new one.
The generic remap was an Evolve Remap, I used Devil Developments (Ford Focus RS specialists) in Littlehampton, they have a conservative rolling road by all accounts and a good reputation among the RS boys.
Yep, max rev's are limited while stationary to 4000 rpm and max rev's are 5800 according to the rev counter but the limiter doesn't cut in till 6000.
Trust me, you can't get 0.9 BAR/13 PSI at the inlet manifold (after the throttle body) from just fitting a Speer crank pulley. 9.5-10.5 PSI is the norm. If you're getting what seems to be a boost spike, them maybe there's an issue with the boost pressure control valve? But I've never heard of that issue on these engines. The valves operate on gradual closure, they don't snap shut 100% straight away.
On my car peak boost is 10 PSI, possibly 10.5 PSI. That occurs at around 5200-5500 RPM, I think. I'd need to check it to be sure. It holds max boost to 6000, then the rev limiter cuts in. I reckon another few hundred rev's wouldn't go amiss. As I previously mentioned, importantly I have 7 PSI a the touch of the throttle, 7 PSI is max pressure from a stock engine so the car is now far more lively. You can measure boost pressure anywhere that suits after the T/B, the handiest place on these later engines is to tap into the FPR vacuum line.
AFR's are good, very low 12's, high 11's @ wide open throttle.
No problem with the questions you're asking, ask away.
The potential of these engines is very good, of course it depends on how far you want to go. But, you're not going to see huge power gains without some work and more cost. The main cost would be sorting out additional fueling. The head and bottom end don't need to be touched, the motor will handle up to 400 BHP. There's several converted to turbos, 350 BHP is common. I'm happy with 220-225 BHP for the amount of work involved and the cost. Having some weight reduction too is an added bonus. Personally, I'd chase more weight reduction, fit a better I.C., exhaust and air filter system than increasing boost pressure.
HTH.
Last Edit: Apr 30, 2020 19:03:24 GMT by Woofwoof
I accidentally came across an air filter/bypass valve modification which was for sale in Poland. It allows the fitment of a cone filter while deleting the complete air filter housing while still using both original intake hoses and PCV breather hose. I couldn't resist buying it as I always wanted to try this mod. (Sorry about the small photo's but can't do anything about it.) dolot-mercedes-kompressor-cold-air-intake iii by Johnny Slow, on Flickr Here it's fitted to a 190E that has a 230 Kompressor engine transplanted. My car's setup will look very similar, except I'll box in the filter and have two cold air feeds. As it is currently with the stock filter housing. IMG_20200503_213544104 by Johnny Slow, on Flickr I'm just hoping there's a noticeable difference in the IAT's (which I can check) and better air flow to the supercharger. I do know when this engine is tuned for 240 BHP or more this type of C.A.I. system produces great results. I suppose if you're not in you can't win. So, I'll try it as I've nothing much to lose.
Last Edit: May 4, 2020 0:21:00 GMT by Woofwoof
I started mocking up for CAI jobbie using good old cardboard for the new air box. I sealed any holes from the original air filter housing mounts and covered a gap at the chassis rail but leaving a hole for the second air feed pipe to come in. I left myself in for more time consuming work than I reckoned, nothing new there and I should know better. Just hope it's worth the effort... The wheel arch intrudes a fair bit and one of the mounting brackets for the air filter housing is in the way thus making a template a bit tricky. The hose from the rad to auxiliary heater pump is in the way at two locations and the header tank to thermostat hose isn't ideally located either. I'll need to get another hose with a 90 degree bend and a hose joiner to sort the heater hose out and re-route the header tank hose. The list of parts/items needed is growing and no doubt I've forgotten something! 1. 1.5 x 800 x 800 mm alloy sheet. ordered2. 25 & 20 mm Grommets. ordered3. 52 mm hose inlet flange. ordered4. 75 mm hose inlet flange. 5. 1000 mm Rubber/Foam seal. ordered6. 19 mm 90 degree silicone coolant hose. ordered7. 19 mm alloy joiner. ordered.8. 19 mm P-clips. tick9. Cone filter (70 mm neck) 10. 600 x 600 mm insulation sheet. 11. 4 x brackets. tick.12. 600 mm lower edge trim. tick Original air filter housing with modified inlets. S/C valve, S/C inlet and PCV outlet positions. The start... getting there... still getting there... covering the gap... not too sure but I did do something here...
Last Edit: May 5, 2020 23:52:54 GMT by Woofwoof
May 14, 2020 20:44:50 GMT
Winning'ish...but the list of bits and pieces is growing. That sort of implies I don't know what I'm really doing. Nothing new there.
Last Edit: May 14, 2020 20:46:05 GMT by Woofwoof
